coq-club - Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7
  • Date: Sat, 4 Nov 2017 17:00:51 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mail AT maximedenes.fr; spf=Pass smtp.mailfrom=mail AT maximedenes.fr; spf=None smtp.helo=postmaster AT 3.mo5.mail-out.ovh.net
  • Ironport-phdr: 9a23:UyN+uBwXAWxJTwzXCy+O+j09IxM/srCxBDY+r6Qd0u8TIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2NBXupSi56idXERHiPyJ0IP70E8jclZeZzee3rrjacwRNiXKR4LXyN13iqAzQsuETiJtjL6s9xx3EuT1GYbIFlitTOVuPkkOktY+L95l5/nEItg==
Try adding `open Ltac_plugin` at the top of your file.
Maxime.
On 11/04/2017 04:52 PM, Kenneth Roe wrote:
> It looks like I'm getting closer.  My file compiles.  However, I get the
> following error:
> File "./src/Theory.v", line 74, characters 0-28:
> *Error:*
> while loading /Users/kendroe/FDS/engine/plugin/src/thepack.cmxs:
> error loading shared library:
> dlopen(/Users/kendroe/FDS/engine/plugin/src/thepack.cmxs, 138): Symbol
> not found: _camlTacenv
>   Referenced from: /Users/kendroe/FDS/engine/plugin/src/thepack.cmxs
>   Expected in: flat namespace
>  in /Users/kendroe/FDS/engine/plugin/src/thepack.cmxs
> I discovered the cause of this undefined symbol is this macro:
> TACTIC EXTEND AR2
> | ["arewrite"] -> [Stuff.arewrite]
> END
> When I comment it out, the resulting module loads.  What do I need to
> include or change?
>                  - Ken
> *From:* Matej Košík
> <mail AT matej-kosik.net>
> *Sent:* Saturday, November 4, 2017 6:30 AM
> *To:*
> coq-club AT inria.fr;
> kendroe AT hotmail.com
> *Subject:* Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7
> Hi,
> On 11/04/17 14:10, Kenneth Roe wrote:
>> Didn't work.
>> Does someone have a sample project that uses "VERNAC COMMAND EXTEND" (and
>> also "TACTIC EXTEND" or what ever it became) for Coq 8.7?
> The attached demo exercises some of those mechanisms.
> (Compiles with the "v8.7" branch of Coq).
> Let me know what you think.
> Matej
