- To: Matej Košík <mail AT matej-kosik.net>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7
- Date: Sat, 4 Nov 2017 21:37:45 +0000
- Accept-language: en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=kendroe AT hotmail.com; spf=Pass smtp.mailfrom=kendroe AT hotmail.com; spf=Pass smtp.helo=postmaster AT NAM04-BN3-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23:mu8EbhbU7XEdNFfCO0Qi5xr/LSx+4OfEezUN459isYplN5qZpc24bnLW6fgltlLVR4KTs6sC0LWG9f24EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i76vnYuHUDaPBZ4JNPWHXxXjIzj0umz/7XWahlFhn++ZqhzL1OwoBmH8oFciox7b6011xHho31Seu0Qy3kibQaYmA+57cOt9rZi9T5RsrQv7ZgTf7/9evEbQLpeASgme1oy6YW/thTFQRGI61McVXkTmxtMRQPC6UepDd/KriLmu78li2GhNsrsQOVsVA==
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
I have
DECLARE PLUGIN "theplug"
at the top of the file. Changing it to
Declare ML Module "theplug"
- Ken
Sent: Saturday, November 4, 2017 11:46 AM
To: coq-club AT inria.fr; kendroe AT hotmail.com
Hi,
On 11/04/17 17:39, Kenneth Roe wrote:
> I got the code to compile. And the commands that I registered with "VERNAC COMMAND EXTEND" seem to work. However, the "arewrite" tactic that I registered with "TACTIC EXTEND" is not recognized. I
> get the error:
> *Error:*The reference arewrite was not found in the current environment.
I have a stupid question:
Did you do something like:
Declare ML Module "your_plugin".
in the *.v file you are trying to compile?
(somewhere before the position in which you are trying to use the tactic provided by that plugin)
> get the error:
- [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7, Kenneth Roe, 11/04/2017
- Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7, Hugo Herbelin, 11/04/2017
- Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7, Kenneth Roe, 11/04/2017
- Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7, Matej Košík, 11/04/2017
- Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7, Maxime Dénès, 11/04/2017
- Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7, Kenneth Roe, 11/05/2017
- Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7, Matej Košík, 11/05/2017
