- From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Best bet for computing with floats
- Date: Fri, 1 Dec 2017 00:28:14 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay2-d.mail.gandi.net
- Ironport-phdr: 9a23:ZFsE0R3MvEXjREDRsmDT+DRfVm0co7zxezQtwd8ZsesQLfad9pjvdHbS+e9qxAeQG96Eu7QZ06L/iOPJZy8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tLw6annrn5jkLXx77KABdJ+LvG4eUgd7k+fq1/sj8aoZUjTyKTrJ2JhissU2FucAbnYJkbKkwzhHEuGdgYOdH3mBpIFeehVD669vmr80ryDhZp/90r50Iaq79ZaltFbE=
On 16/08/2017 15:33, Guillaume Melquiond wrote:
> On 15/08/2017 08:05, karsar wrote:
>> What would be a natural choice of float number library if you want to do
>> some
>> computations with floats inside Coq (like it's done for integers and nats,
>> I know it could be slow) , as well as reason about their properties?
>> It would be nice to provide a minimal example script showing how you
>> import the library
>> and example of the addition of two floats as a demonstration.
> Both the Flocq and Interval libraries contain computationally effective
> floating-point components. Which one to use and how to use it depend on
> your use case. Do you need the floating-point numbers to be compliant
> with the IEEE-754 standard? What kind of reasoning do you want to
> perform on them? How efficient do you want the computations to be?
> Best regards,
> Guillaume
To all: if this is a question which tends to come up regularly is there some way we could make the answer easier to find?
Gaëtan Gilbert
On 01/12/2017 00:23, Kevin Sullivan wrote:
What library or libraries should I consider as I need to represent concrete floating point numbers, do calculations with them, and prove properties about them using the current version of Coq?
- [Coq-Club] Best bet for computing with floats, Kevin Sullivan, 12/01/2017
- Re: [Coq-Club] Best bet for computing with floats, Gaëtan Gilbert, 12/01/2017
- Re: [Coq-Club] Best bet for computing with floats, Benjamin Pierce, 12/01/2017
- Re: [Coq-Club] Best bet for computing with floats, Kevin Sullivan, 12/01/2017
- Re: [Coq-Club] Best bet for computing with floats, Bas Spitters, 12/01/2017
- Re: [Coq-Club] Best bet for computing with floats, Théo Zimmermann, 12/04/2017
- RE: [Coq-Club] Best bet for computing with floats, Soegtrop, Michael, 12/04/2017
- Re: [Coq-Club] Best bet for computing with floats, Kevin Sullivan, 12/04/2017
