- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Best bet for computing with floats
- Date: Fri, 1 Dec 2017 10:18:04 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=b.a.w.spitters AT gmail.com; spf=Pass smtp.mailfrom=b.a.w.spitters AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f171.google.com
- Ironport-phdr: 9a23:NDdenBSeqQHdEwN7CwcwQIJK49psv+yvbD5Q0YIujvd0So/mwa67bReN2/xhgRfzUJnB7Loc0qyN7PCmBDRIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnY6Uy/yPgttJ+nzBpWaz4Huj7jzqNXvZFBjgyP1SrdvJl3ipgLI88ISnIFKK6AryxKPrGEeKMpMwmY9D1uI1y3k59us8YR4u3Ba/ftn6IhbSaTmY6kiVpRXCT0nNyY+48i95kqLdheG+nZJCjZeqRFPGQWQqUiiBpo=
> To all: if this is a question which tends to come up regularly is
there some way we could make the answer easier to find?
Search "float":
https://github.com/coq/coq/wiki
On Fri, Dec 1, 2017 at 12:28 AM, Gaëtan Gilbert
<gaetan.gilbert AT skyskimmer.net>
wrote:
> On 16/08/2017 15:33, Guillaume Melquiond wrote:
>> On 15/08/2017 08:05, karsar wrote:
>>> What would be a natural choice of float number library if you want to do
>>> some
>>> computations with floats inside Coq (like it's done for integers and
>>> nats,
>>> I know it could be slow) , as well as reason about their properties?
>>> It would be nice to provide a minimal example script showing how you
>>> import the library
>>> and example of the addition of two floats as a demonstration.
>> Both the Flocq and Interval libraries contain computationally effective
>> floating-point components. Which one to use and how to use it depend on
>> your use case. Do you need the floating-point numbers to be compliant
>> with the IEEE-754 standard? What kind of reasoning do you want to
>> perform on them? How efficient do you want the computations to be?
>> Best regards,
>> Guillaume
> To all: if this is a question which tends to come up regularly is there some
> Gaëtan Gilbert
> On 01/12/2017 00:23, Kevin Sullivan wrote:
>> What library or libraries should I consider as I need to represent
>> concrete floating point numbers, do calculations with them, and prove
>> properties about them using the current version of Coq?
- [Coq-Club] Best bet for computing with floats, Kevin Sullivan, 12/01/2017
- Re: [Coq-Club] Best bet for computing with floats, Gaëtan Gilbert, 12/01/2017
- Re: [Coq-Club] Best bet for computing with floats, Benjamin Pierce, 12/01/2017
- Re: [Coq-Club] Best bet for computing with floats, Kevin Sullivan, 12/01/2017
- Re: [Coq-Club] Best bet for computing with floats, Bas Spitters, 12/01/2017
- Re: [Coq-Club] Best bet for computing with floats, Théo Zimmermann, 12/04/2017
- RE: [Coq-Club] Best bet for computing with floats, Soegtrop, Michael, 12/04/2017
- Re: [Coq-Club] Best bet for computing with floats, Kevin Sullivan, 12/04/2017
