- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Best bet for computing with floats
- Date: Thu, 30 Nov 2017 18:37:27 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=bcpierce AT cis.upenn.edu; spf=Pass smtp.mailfrom=bcpierce AT cis.upenn.edu; spf=None smtp.helo=postmaster AT hound.seas.upenn.edu
- Ironport-phdr: 9a23:AhnQKh2nxrQ7d3eRsmDT+DRfVm0co7zxezQtwd8ZsesQK/ad9pjvdHbS+e9qxAeQG96Eu7QZ06L/iOPJZy8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tLw6annrn5jkLXx77KABdJ+LvG4eUgd7k+fq1/sj5bgNKjT+8Z/tKLRispgiZ4sMdmYpvMK084hDIuT1VY+lQwyVlKU/FzEW03du54JM2q3cYgPkm7cMVCag=
StackOverflow?
- Benjamin
> On Nov 30, 2017, at 18:28, Gaëtan Gilbert
> <gaetan.gilbert AT skyskimmer.net>
> wrote:
> On 16/08/2017 15:33, Guillaume Melquiond wrote:
> > On 15/08/2017 08:05, karsar wrote:
> >> What would be a natural choice of float number library if you want to do
> >> some
> >> computations with floats inside Coq (like it's done for integers and
> >> nats,
> >> I know it could be slow) , as well as reason about their properties?
> >> It would be nice to provide a minimal example script showing how you
> >> import the library
> >> and example of the addition of two floats as a demonstration.
> > Both the Flocq and Interval libraries contain computationally effective
> > floating-point components. Which one to use and how to use it depend on
> > your use case. Do you need the floating-point numbers to be compliant
> > with the IEEE-754 standard? What kind of reasoning do you want to
> > perform on them? How efficient do you want the computations to be?
> > Best regards,
> > Guillaume
> To all: if this is a question which tends to come up regularly is there
> some way we could make the answer easier to find?
> Gaëtan Gilbert
>> On 01/12/2017 00:23, Kevin Sullivan wrote:
>> What library or libraries should I consider as I need to represent
>> concrete floating point numbers, do calculations with them, and prove
>> properties about them using the current version of Coq?
- [Coq-Club] Best bet for computing with floats, Kevin Sullivan, 12/01/2017
- Re: [Coq-Club] Best bet for computing with floats, Gaëtan Gilbert, 12/01/2017
- Re: [Coq-Club] Best bet for computing with floats, Benjamin Pierce, 12/01/2017
- Re: [Coq-Club] Best bet for computing with floats, Kevin Sullivan, 12/01/2017
- Re: [Coq-Club] Best bet for computing with floats, Bas Spitters, 12/01/2017
- Re: [Coq-Club] Best bet for computing with floats, Théo Zimmermann, 12/04/2017
- RE: [Coq-Club] Best bet for computing with floats, Soegtrop, Michael, 12/04/2017
- Re: [Coq-Club] Best bet for computing with floats, Kevin Sullivan, 12/04/2017
