coq-club - Re: [Coq-Club] speed of Coq 8.8 vs 8.7, 32-bit vs 64-bit
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>, Andrew Appel <appel AT cs.princeton.edu>
  • Subject: Re: [Coq-Club] speed of Coq 8.8 vs 8.7, 32-bit vs 64-bit
  • Date: Fri, 27 Apr 2018 23:59:35 +0000 (UTC)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jfehrle AT sbcglobal.net; spf=None smtp.mailfrom=jfehrle AT sbcglobal.net; spf=None smtp.helo=postmaster AT sonic309-24.consmr.mail.ne1.yahoo.com
  • Ironport-phdr: 9a23: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
fortunately, my VST proof development is itself much more efficient, so therefore I can do big things with a large collection of .v files that each take no more than 1 gigabyte (and usually much less) to process with coqc.
Sounds like a memory leak.  Directly or indirectly, I expect you have to Require all of the .v files for final proof in the series, and you've not mentioned problems with that.  So the compiled-then-loaded form of the .v files is not taking too much memory.  https://realworldocaml.org/v1/en/html/understanding-the-garbage-collector.html says that both the major and minor heaps use compaction, so heap fragmentation shouldn't be an issue either.
Are you using a separate coqc process to compile each .v?  If you compile many .v files in one coqc process, does it run out of memory?
