- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Induction Principle
- Date: Tue, 12 Jun 2018 14:52:20 +0200 (CEST)
Formally my question can be formulated as
" given an inductive type \alpha, (like the one I wrote previously)
what is its induction principle \alpha_ind?
and what is a term with type \alpha_ind? "
Coq Art is useful as it shows many examples
(and maybe I can try to write the rule by myself),
but is there some reference showing a general rule?
Thanks,
Carmine
----- Original Message -----
> From: "Pierre Courtieu"
> <pierre.courtieu AT gmail.com>
> To: "coq-club"
> Sent: Tuesday, 12 June, 2018 14:19:42
> Hi,
> I don't know what you mean by "write the term". Do you mean "prove"?
> If yes then you can look at the definition of, say, nat_ind by doing:
> "Print nat_ind."
> You get something like this.
> fix F (n : nat) : P n :=
> match n as n0 return (P n0) with
> | 0 => f
> | S n0 => f0 n0 (F n0)
> end.
> Notice the form "fix F n .. := match n with ....end"
> This Fix + match is the core structure of the proofs of induction
> principles: it is the nominal application of the elimination mechanism
> at the heart of CIC.
> Hope this helps.
> P.
- [Coq-Club] Induction Principle, Carmine Abate, 06/12/2018
- Re: [Coq-Club] Induction Principle, Pierre Courtieu, 06/12/2018
- Re: [Coq-Club] Induction Principle, Carmine Abate, 06/12/2018
- Re: [Coq-Club] Induction Principle, karsar, 06/12/2018
- Re: [Coq-Club] Induction Principle, Ambrus Kaposi, 06/12/2018
- Re: [Coq-Club] Induction Principle, Matej Košík, 06/12/2018
