- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Induction Principle
- Date: Tue, 12 Jun 2018 21:08:18 +0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=karen.sarkisyan AT gmail.com; spf=Pass smtp.mailfrom=karen.sarkisyan AT gmail.com; spf=None smtp.helo=postmaster AT mail-ot0-f172.google.com
- Ironport-phdr: 9a23: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
You may find useful information in http://adam.chlipala.net/cpdt/cpdt.pdf where author talks about induction principles
associated with the induction types, illustrates how to construct induction principle manually (you may get an understanding
what in essence automatic generation performs). He also brings an example where automatically generated induction
principle is not good enough and manually created one solves the task. And a plenty of other material.
Best,
Karen
On Tue, Jun 12, 2018 at 8:52 PM Carmine Abate <carmine.abate AT inria.fr> wrote:
Formally my question can be formulated as
" given an inductive type \alpha, (like the one I wrote previously)
what is its induction principle \alpha_ind?
and what is a term with type \alpha_ind? "
Coq Art is useful as it shows many examples
(and maybe I can try to write the rule by myself),
but is there some reference showing a general rule?
Thanks,
Carmine
----- Original Message -----
> From: "Pierre Courtieu" <pierre.courtieu AT gmail.com>
> To: "coq-club" <coq-club AT inria.fr>
> Sent: Tuesday, 12 June, 2018 14:19:42
> Hi,
> I don't know what you mean by "write the term". Do you mean "prove"?
> If yes then you can look at the definition of, say, nat_ind by doing:
> "Print nat_ind."
> You get something like this.
> fix F (n : nat) : P n :=
> match n as n0 return (P n0) with
> | 0 => f
> | S n0 => f0 n0 (F n0)
> end.
> Notice the form "fix F n .. := match n with ....end"
> This Fix + match is the core structure of the proofs of induction
> principles: it is the nominal application of the elimination mechanism
> at the heart of CIC.
> Hope this helps.
> P.
- [Coq-Club] Induction Principle, Carmine Abate, 06/12/2018
- Re: [Coq-Club] Induction Principle, Pierre Courtieu, 06/12/2018
- Re: [Coq-Club] Induction Principle, Carmine Abate, 06/12/2018
- Re: [Coq-Club] Induction Principle, karsar, 06/12/2018
- Re: [Coq-Club] Induction Principle, Ambrus Kaposi, 06/12/2018
- Re: [Coq-Club] Induction Principle, Matej Košík, 06/12/2018
