- From: Thorsten Altenkirch <Thorsten.Altenkirch AT nottingham.ac.uk>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Cc: Alexander McKenna <psyam11 AT nottingham.ac.uk>
- Subject: [Coq-Club] run recursive programs in coq
- Date: Thu, 1 Nov 2018 11:21:17 +0000
- Accept-language: en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Thorsten.Altenkirch AT nottingham.ac.uk; spf=Pass smtp.mailfrom=Thorsten.Altenkirch AT nottingham.ac.uk; spf=None smtp.helo=postmaster AT uidappmx02.nottingham.ac.uk
- Ironport-phdr: 9a23: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
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
Is there a way to run possibly non-terminating programs in the coq type checker. In Agda you can just switch off the termination checker.
I think this is useful if you want to use something whose termination you haven't yet proven but want to exploit reduction.
Hence it is not enough to add the assumption that it terminates as an axiom because this won't reduce. Thorsten This message and any attachment are intended solely for the addressee and may contain confidential information. If you have received this message in error, please contact the sender and delete the email and attachment. Any views or opinions expressed by the author of this email do not necessarily reflect the views of the University of Nottingham. Email communications with the University of Nottingham may be monitored where permitted by law. |
- [Coq-Club] run recursive programs in coq, Thorsten Altenkirch, 11/01/2018
- <Possible follow-up(s)>
- Re: [Coq-Club] run recursive programs in coq, Klaus Ostermann, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Peter E Schmidt-Nielsen, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Bas Spitters, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Li-yao Xia, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Daniel Schepler, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Gaëtan Gilbert, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Jean-Christophe Léchenet, 11/09/2018
- Re: [Coq-Club] run recursive programs in coq, Anton Trunov, 11/01/2018
