- From: Thorsten Altenkirch <t.altenkirch AT googlemail.com>
- To: coq-club AT inria.fr
- Cc: Alexander McKenna <psyam11 AT exmail.nottingham.ac.uk>
- Subject: [Coq-Club] run recursive programs in coq
- Date: Thu, 1 Nov 2018 11:19:12 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=t.altenkirch AT googlemail.com; spf=Pass smtp.mailfrom=t.altenkirch AT googlemail.com; spf=None smtp.helo=postmaster AT mail-yw1-f51.google.com
- Ironport-phdr: 9a23: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
Is there a way to run possibly non-terminating programs in the coq type checker. In Agda you can just switch off the termination checker.
I think this is useful if you want to use something whose termination you haven't yet proven but want to exploit reduction.
Hence it is not enough to add the assumption that it terminates as an axiom because this won't reduce.
Thorsten
- [Coq-Club] run recursive programs in coq, Thorsten Altenkirch, 11/01/2018
- <Possible follow-up(s)>
- Re: [Coq-Club] run recursive programs in coq, Klaus Ostermann, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Peter E Schmidt-Nielsen, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Bas Spitters, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Li-yao Xia, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Daniel Schepler, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Gaëtan Gilbert, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Jean-Christophe Léchenet, 11/09/2018
- Re: [Coq-Club] run recursive programs in coq, Anton Trunov, 11/01/2018
