- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] run recursive programs in coq
- Date: Thu, 1 Nov 2018 18:05:59 -0400 (EDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=snp AT mit.edu; spf=Pass smtp.mailfrom=snp AT mit.edu; spf=None smtp.helo=postmaster AT dmz-mailsec-scanner-3.mit.edu
- Ironport-phdr: 9a23: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
Good point Li-yao, I feel really silly for writing "Program Fixpoint" for the nat-fueled version. I copied it over by analogy from the BinNat-fueled version I tried to get to work when I saw Klaus's original suggestion to use fuel. I got stuck on the BinNat version, and somehow had a moment of silliness and forgot that obviously Program Fixpoint's features are completely unnecessary with a plain nat for fuel.
Daniel's sugar for making this easier to write also looks great.
Not to hijack the thread, but I'm really curious if anyone has any leads on getting the BinNat-fueled version (appearing below the nat-fueled one in my gist) to work? The great thing about such a version is that you can just past in some obscene value like 2^200 for the fuel in every case and never worry about it, while with a nat for fuel I'm quite constrained on how much fuel I can provide. (I figure this isn't really thread hijacking, because I think getting a BinNat-fueled version working would basically practically solve this issue for OP.)
I looked at the "Type classes for efficient exact real arithmetic in Coq" paper that was linked, but I'm not sure the laziness suggested via eta expansion solves this problem, as I'm 98% sure that the output of Program Fixpoint actually really does need to compute through the opaque parts of N.lt_pred_l and N.lt_wf_0, although maybe I'm missing the point.
If there were some generic mechanism that could take an opaque term and trace all the dependencies Print Opaque Dependencies style and make a transparent version (or somehow override the opacity) then it would completely solve the problem...
Thanks,
-snp
On Thu, 1 Nov 2018, Daniel Schepler wrote:
On Thu, Nov 1, 2018 at 9:35 AM Li-yao Xia
<lysxia AT gmail.com>
wrote:
If you're using fuel it is fairly easy to make it structurally
decreasing with a simple Fixpoint because fuel can just decrease by 1,
instead of using a Program and proving decreasingness with respect to lt.
Or, to put a bit of monad-type synactic sugar around it:
Definition fuelled (X : Type) : Type :=
nat -> option X.
Definition return_ {X : Type} (x : X) : fuelled X :=
fun _ => Some x.
Definition bind {X : Type} (x : fuelled X)
{Y : Type} (f : X -> fuelled Y) :
fuelled Y :=
fun fuel => match x fuel with
| Some x0 => match f x0 fuel with
| Some y0 => Some y0
| None => None
end
| None => None
end.
Notation "'do' x0 <- x ; y" := (bind x (fun x0 => y))
(x0 ident, at level 20, right associativity).
Definition recursive_call {X:Type} (x : fuelled X) :
fuelled X :=
fun fuel => match fuel with
| S fuel_pred => x fuel_pred
| O => None
end.
Definition ackermann_fuel : nat -> nat -> fuelled nat :=
fix F (m n:nat) (fuel : nat) {struct fuel} : option nat :=
match m with
| O => return_ (S n)
| S m' => match n with
| O => recursive_call (F m' 1)
| S n' =>
do x <- recursive_call (F m n');
recursive_call (F m' x)
end
end fuel.
Definition run_with_fuel {X:Type} (x : fuelled X)
(fuel : nat) :=
x fuel.
Compute (run_with_fuel (ackermann_fuel 3 3) 100)
Daniel Schepler
- [Coq-Club] run recursive programs in coq, Thorsten Altenkirch, 11/01/2018
- <Possible follow-up(s)>
- Re: [Coq-Club] run recursive programs in coq, Klaus Ostermann, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Peter E Schmidt-Nielsen, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Bas Spitters, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Li-yao Xia, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Daniel Schepler, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Gaëtan Gilbert, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Jean-Christophe Léchenet, 11/09/2018
- Re: [Coq-Club] run recursive programs in coq, Anton Trunov, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Jan Bessai, 11/01/2018
