- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] run recursive programs in coq
- Date: Thu, 1 Nov 2018 13:40:21 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jan.bessai AT tu-dortmund.de; spf=Pass smtp.mailfrom=jan.bessai AT tu-dortmund.de; spf=None smtp.helo=postmaster AT unimail.uni-dortmund.de
- Autocrypt: addr=jan.bessai AT tu-dortmund.de; prefer-encrypt=mutual; keydata= xsBNBEuo400BCADHE9QPhcgvwt5SnpGIM+6jvqwSrDPewbrG6pXYTMX1NMBVjXbsvTgjsLPQ lnkE4+OfafMKybDqCZvs1T60p+7LS1M09qjorGEllM4XFYvSoW/tEm7jPh+dF/OQSmRiEZ7y m5hKlyYpkgEI/I/w17pp8ecr9KSitZRygtWOIv+b8T5E8ofb7ymE9Ts8wGbWUdoBZ9HG3Pxn EwfJvqaXZ1hq9tknB2YPQCtaO7RGPIDnDxkChnsBHdMUL5cFVxnXMCgokFMGocyjNK+MkoQq 23IzZW1kHrH9G7Dyve1IwXmEUW9qXdf01zLbdysy+Bu94Y/JfNb245RVghGUq3/XYPYVABEB AAHNJkphbiBCZXNzYWkgPEphbi5CZXNzYWlAdHUtZG9ydG11bmQuZGU+wsB4BBMBAgAiBQJL qONNAhsDBgsJCAcDAgYVCAIJCgsEFgIDAQIeAQIXgAAKCRAjc0RRCV1tGB20B/9uUtH9ERZc oJvODEuugm+8kCrQrQAlJt5fqrrNNmb9E1DKISGgJZsKo0hxtokbbuoqrId1i6BjWlcZTW7Y SylS3+FmI2sUl/XoegJQC1wSKSUwedsxht9bXQYKw99K+RCEF+LPnpKEuDQDWQ+7zwgdJ+Mu LQ50Xwo+R1W+Vk54IVQbyXDI5K3IKaBp9Gzd6TU3v951tzSj8BrIjPVBx6tCXBkM6E7I/lwU Wgtf0WRNDm7VRabB6jL/aVz+Qs0Cu6Wh6Pw5IjzTmGX1i888Kw8RCFi9ZAVQYfJZKFBqh1AX kIag0nmrUC3nVJvWMBH9wIyc0TWZDHoANTy9lAnFfloSzsBNBEuo400BCAC9E2QVS95F7ZOS MK0hy5JSGYhr8ZafR/pkcr0ipjGaj/d6l6b0HJXj5qSLPZYHNS9+6pXk3mSNlFUnqJ+65tzk XDNmfhja/9f/HdDXsx87j7/ZqB/wHDi3IEHrPACxDkEHQ/800C83EsFawf6kYuWKCp/MoA84 u/50SJrFUNdrH9uwdhPSmzDzVYlzHKF4RsGG3/PmRpTGjcJwUjKomc9xMIp5kHOyIoqs88Sz zAn5k5UgpsX7V8Y2wkwGulZjo8mK3wSHtIKXTqM6SPEfMjANpKGiOG7RLaNOM3rIboM0o/ty T97IaxoAdZF7ufEh1APi1yAzITLUEGNd5pLE5k6NABEBAAHCwF8EGAECAAkFAkuo400CGwwA CgkQI3NEUQldbRjnlwf/fOxz1iUP4gGMNPO1NRxpJPLoLAVH7Maqm86I99pvusYU/iPAj4E9 hBCbQFK45R3a9JPrRgXlTytTX751t3nEdbvMJ7Qc9Xj+5k6CC7PCWVDVuQ6O6FEYT/5PK1/c +Wgz4GCGsaYU3wh6ZD72tUO6HHKUpixCkFyZi/6N07dSbFR2jCxzW2Nzm5Ya+J4Vtfce0CoY A1dpfEytKv1ySmQvb7QaEoLE6ZJgJHPF9p9NBGx/uN/e6PTJUE7zQaEJ8EJdHUS8bpiX9tN7 5IXKvCF4fCCuk3TUxaeY5EISHc4n63p3TZd1qCJLJVwptifIDyAmc08o+oXFGmB0BdPMu7gT bg==
- Ironport-phdr: 9a23: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
- Openpgp: preference=signencrypt
Thorsten,
perhaps the technique presented by Larchey-Wendling and Monin at Types
2018 "Simulating Induction-Recursion for Partial Algorithms" [1] can
help you. Their trick is to use an inductively defined relation instead
of a function and later show that the relation is in fact a terminating
function. In your case you might be able to prove facts about the
relation to proceed.
Or you could have a tactic (which doesn't require any termination proof)
to infer an instance of their termination predicate D, which makes the
recursive calls proceed for the specific case you are interested in.
Also, here [2] is a larger example, where I used it to implement an
algorithm for intersection type subtyping. I can send you a paper
(accepted and to appear soon) describing the code if you are interested.
-- Jan
[1]:
https://types2018.projj.eu/wp-content/uploads/2018/06/BookOfAbstractsTYPES2018.pdf
[2]: https://github.com/JanBessai/SubtypeMachine/blob/github/Types.v
On 01.11.18 12:21, Thorsten Altenkirch wrote:
> Is there a way to run possibly non-terminating programs in the coq type
> checker. In Agda you can just switch off the termination checker.
> I think this is useful if you want to use something whose termination you
> haven't yet proven but want to exploit reduction.
> Hence it is not enough to add the assumption that it terminates as an axiom
> because this won't reduce.
> Thorsten
> This message and any attachment are intended solely for the addressee
> and may contain confidential information. If you have received this
> message in error, please contact the sender and delete the email and
> attachment.
> Any views or opinions expressed by the author of this email do not
> necessarily reflect the views of the University of Nottingham. Email
> communications with the University of Nottingham may be monitored
> where permitted by law.
Jan Bessai (M.Sc.)
Wissenschaftlicher Mitarbeiter
Technische Universität Dortmund
Fakultät für Informatik - Lehrstuhl 14 Software Engineering
Otto-Hahn Straße 14
D-44227 Dortmund
Tel.: +49 231-755 77 64
Fax: +49 231-755 79 36
www.tu-dortmund.de
Wichtiger Hinweis: Die Information in dieser E-Mail ist vertraulich. Sie
ist ausschließlich für den Adressaten bestimmt. Sollten Sie nicht der
für diese E-Mail bestimmte Adressat sein, unterrichten Sie bitte den
Absender und vernichten Sie diese Mail. Vielen Dank.
Unbeschadet der Korrespondenz per E-Mail, sind unsere Erklärungen
ausschließlich final rechtsverbindlich, wenn sie in herkömmlicher
Schriftform (mit eigenhändiger Unterschrift) oder durch Übermittlung
eines solchen Schriftstücks per Telefax erfolgen.
Important note: The information included in this e-mail is confidential.
It is solely intended for the recipient. If you are not the intended
recipient of this e-mail please contact the sender and delete this
message. Thank you.
Without prejudice of e-mail correspondence, our statements are only
legally binding when they are made in the conventional written form
(with personal signature) or when such documents are sent by fax.
- [Coq-Club] run recursive programs in coq, (continued)
- [Coq-Club] run recursive programs in coq, Thorsten Altenkirch, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Klaus Ostermann, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Peter E Schmidt-Nielsen, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Bas Spitters, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Li-yao Xia, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Daniel Schepler, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Gaëtan Gilbert, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Anton Trunov, 11/01/2018
- Re: [Coq-Club] run recursive programs in coq, Jan Bessai, 11/01/2018
