- From: Mario Alvarez Picallo <mario.alvarez739 AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] finite data types
- Date: Mon, 18 Mar 2019 14:21:26 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mario.alvarez739 AT gmail.com; spf=Pass smtp.mailfrom=mario.alvarez739 AT gmail.com; spf=None smtp.helo=postmaster AT mail-it1-f176.google.com
- Ironport-data: A9a23:cC7HmKLmgIzn3kjGFE//H55ysdRLeRNe4xZit3CvOc3KTyvbaWc81o JN0lWefBZU0H4URbifKpi/rvDKcfeUZEdLqG9QbvKUW2ZQdCgmGO4odiCghcQ5V/cF0+CP6l bg7bfAsqtQm7y5oQSiXLblKtEp/54XjIQs+CIhaSoT3MOfFfwHGXzTAchh7GRv8COovnhBtf 1CKdngG3HEL/11bvB0sqtzZZm7tglyBO+KWjFYIrgK+LAmy91eqgrpkGGE8rCJ9ULi0ioDLo Rtn48iAN5xDjXO+w/weqPVFJm8xvOemRhCo3s4gjkYcGaa1y8oz+S2PJ3wiXkY0HD/Xo8c+s gp3pk0lcy46gSt0nXa1UQ3SfOd5HBCEOC4Wk56hm8jbuZQ+Qo3bIcC3zGhZcHUckOyEwMoGk fFxDdAF9bvPthFNbsd9oBfN7gloXR+b4lxb1+XVb984pZodn/PxJ7+MMih3FsaxLVvVu3XKG 7/SSLvMLKeRzEs90QMQmoQ6U/HP7leu+rzDNX7c1WKk8JTBcZ9+bol3bZWuMK1XIQWfL30/u MecTI92cKiC14CsfutSGUAvp7YwVpNxp+NTEO43z3XbDu+ebHZhQFKlHHPgJEZuwXcQvG1lq HHkVoBTzHqz/XtH8hHmnj/v2JjKFfplXdsQ8JmVXmMJxZ7P/0bou4pk2nae+L/bwcx8B47EN 6GgGVeUkqYZpuy/hS6QRJzWsghRN+z2Q3UxTR9Oa+5xJ6ytqset8Tc4BdX6XIzj9o7u3w/n3 5Akv/6X5/qqveTz4Cgjv1KTlyGUM/IZp5M4uXx0dmPXjl8HDJFhxSwhX9cJCP8U0SevqxT5e x9cCSFyyuWfuviVJH35XIuS29mIfcA02plq8vt6Op8GKW3a+7HjNyNsX0rIaTHNfgVdUec0r unUJc4vExx3K3GBcc=
- Ironport-phdr: 9a23:WL5C7RIn3xwDWIT/59mcpTZWNBhigK39O0sv0rFitYgRL/rxwZ3uMQ Tl6Ol3ixeRBMOHsqoC07OempujcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs 1DUFh44yPzahANS47xaFLIv3K98yMZFAnhOgppPOT1HZPZg9iq2+yo9JDffhlEiCChbb9vMR 67sRjfus4KjIV4N60/0AHJonxGe+RXwWNnO1eelAvi68mz4ZBu7T1et+ou+MBcX6r6eb84Ta FDAzQ9L281/szrugLdQgaJ+3ART38ZkhtMAwjC8RH6QpL8uTb0u+ZhxCWXO9D9QLYpUjqg8q hrUgflhygJNzE78G/ZhM9+gr9Frh29vBFw2ZLYbZuPOfZiYq/Qf9UXTndBUMZLUCxBB5uxYY wVAOobPOZYqJT2qkcKrRugHwasHv3gyz5VjXHs3K01z/4uEQXC3AwnAtkDt3HUo8/vNKcTVu C51rPHzTHdb/xMwzfy9onJfxIvrPyIRr9wfs/RxlMuFwPBlFmftYvlPzaM2+kLrmOV7PJgWP qxh2I7rwx9uDuiy8c2hoXUh48Yy0rI+Th7zYs0I9CzVVR1bsS+EJRKsiGXL4t2Td0mQ2FvoC s6z6cJuZ+/fCQTyZQn2wPTZ+WJc4SV4B/uVfydITh/hHJid7K/gwi9/VK8xe37U8m4yFdKri xbndnQrn0ByQDf58ydRvZ+/kqtwyuD2gHS5+1ePEw5l6vWJ4YkwrEql5oTtUrDHjXxmEXzlK KWc18r+vKp6+TgeLnpvJucN5FuhQHkLKsvm86yDOo8PwUVUGib/P6z1Lzn/UHjXLpKifg2nr HDsJ/GPcQburK5AwhN34k/7Ba/Fi6q38gcnXkaN11IYwmHjojsO1HWOv/0F/a/g1K2kDdq3f /KJLPhAo+eZkTExbzmZPN271NW4As119FWoZxOWZ8bJ/emf0brtduQJxsnOha50a7fCd500o cZETaKC7WYN+XbtUGB/O89fLLdTIAQsTf5bfMi4qi93jcChVYBcPzxjtMsY3eiE6E+ehTLUT /Xmt4EVFwykE87Re3uhkeFVGcKNXm3VqM4oDo8DdD/VNuRdsWWmLWEmRyDMNhOfGkfUwKDFH 7pc8OPXPJeMHvPcP8kqSQNUP2ac6Fk1Ryqs1Wkmb9uL+6R+zFB8Jy6i4Yz6OrUmhU/szdzCp bF3g==
I'm sure someone has a better representation but, if you're only interested in n-bit binary numbers, you could define them inductively as:
| Empty : Unsigned 0
| One : forall n, Unsigned n -> Unsigned (S n)
| Zero : forall n, Unsigned n -> Unsigned (S n)
This has the advantage that it will let you write definitions and proofs by induction on the number of bits (which may or may not be what you want).
Cheers,
MAP
On Mon, Mar 18, 2019 at 2:11 PM <fritjof AT uni-bremen.de> wrote:
Hi,
I want to create a finite data type, like *Unsinged 8*,
which containes values from 0 to 2^8 -1.
I came up with an idea like:
Definition unsigned (max:Z) : Set :=
{ x : Z | x >= 0 /\ x < max}.
Definition unsigned_8 := unsigned (2^8).
But I'm not sure, if this is the right way.
Does someone know if there is a better way to define
finite types?
--f.
Now I do not know whether I was then a lambda _expression_ emulating a Turing machine, or whether I am a Turing machine emulating a lambda _expression_.
- [Coq-Club] finite data types, fritjof, 03/18/2019
- Re: [Coq-Club] finite data types, Mario Alvarez Picallo, 03/18/2019
- Re: [Coq-Club] finite data types, Jan Bessai, 03/18/2019
- Re: [Coq-Club] finite data types, Maximilian Wuttke, 03/18/2019
- Re: [Coq-Club] finite data types, Gregory Malecha, 03/19/2019
- Re: [Coq-Club] finite data types, Alix Trieu, 03/19/2019
- Re: [Coq-Club] finite data types, Xavier Leroy, 03/19/2019
- Re: [Coq-Club] finite data types, Gaëtan Gilbert, 03/19/2019
- Re: [Coq-Club] finite data types, Fritjof Bornebusch, 03/20/2019
- Re: [Coq-Club] finite data types, Emilio Jesús Gallego Arias, 03/20/2019
