coq-club - Re: [Coq-Club] finite data types
  • From: Xavier Leroy <xavier.leroy AT college-de-france.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] finite data types
  • Date: Tue, 19 Mar 2019 16:54:10 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=xavier.leroy AT college-de-france.fr; spf=Pass smtp.mailfrom=xavier.leroy AT college-de-france.fr; spf=None smtp.helo=postmaster AT smtpout20.partage.renater.fr
On Tue, Mar 19, 2019 at 10:36 AM Alix Trieu <alix.trieu AT cs.au.dk> wrote:
CompCert provides a formalization of machine integers you might be interested to look at: https://github.com/AbsInt/CompCert/blob/master/lib/Integers.v
Actually, this formalization follows the same approach proposed by the original poster, using a subset of Z:
Definition unsigned (max:Z) : Set :=
  { x : Z | x >= 0 /\ x < max}.
Definition unsigned_8 := unsigned (2^8).
A nice property of this approach is that it computes relatively efficiently (like type Z) while the Fin.t type does not (like type nat).
To have a good notion of equality over type "unsigned" above, it's better to define it this way:
  { x : Z | -1 < x /\ x < max}.
so that proofs of the proposition "-1 < x /\ x < max" are unique.
Have fun,
- Xavier Leroy
> On 18 Mar 2019, at 15:10, fritjof AT uni-bremen.de wrote:
> Hi,
> I want to create a finite data type, like *Unsinged 8*,
> which containes values from 0 to 2^8 -1.
> I came up with an idea like:
> But I'm not sure, if this is the right way.
> Does someone know if there is a better way to define
> finite types?
> --f.
