- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] finite data types
- Date: Mon, 18 Mar 2019 15:23:04 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jan.bessai AT tu-dortmund.de; spf=Pass smtp.mailfrom=jan.bessai AT tu-dortmund.de; spf=None smtp.helo=postmaster AT unimail.uni-dortmund.de
- Ironport-data: A9a23:tbRjA6hMIg8N6mGhvMPULz/kX17brhtdreyghKucuGPUa9ki9/l0or agTRSaX/W+fRq1BFUdNgHrUolxOTuXwxOUy1wmmh5Hxb/vT090tE0pDLp+nr2QzMQkI9C//y 0q5vdxGafuTTLT1UE3Kw86pM4Zr8UU4iQPkbsgIG+9775oTaNAkjZsbqFCniBnKTFe6Vr1rW Z7BjZBwIT0c+zSYdNPWQpSMnykmwyoFotbGC+AhcnaESIai2lYrYtJi2X4WyNQ4Q9qA8vl32 DOcUCNolHxVoeNRqRV/hDHhKi1+cccEoQmB0jxAqML+XkPwyafSFw0xJg+g2mqqMFvMzCKbn vq013vDGOrQjKQQVnjz0izZVv3Yr0HAV1eE7z6gkQWEqEJ0j7R3eu23QvZt7Xy8ln9Ro5isu yLOoIijYMYAoKBJ/5rO8VHQ9nKFAmAWpYsb/RnVdY1YGrcdT78n9GxFcUjfQEMMnh5Obo3l8 g2yxqv6rjIwnGsBFznwt0NnDTziTP+zkRsZG7RzH8eXNBEOemwQPVdnjAdImTecSGwFrV2Ra tHrymR2fc5hfEt1CdCBM8/+jpPIXyAqrePeTobbK2bvCvWJHVnpFVFM45ZIDH6JmMBRggNdE Mk/v59R3FOhSNebGLJhVZZm+qSkWHGiH1fRB5Uwys2TtFxGxnYGVIx/gAd8nb5cMZJbOtvZV vPZYU7pjL8JiEEomUN5iMODGemHE9qi7GGEPy4nSLN7culQVOjwaS79U2UPhIFPfJphFOxQ9 ZEouoITBL8qRiJUMb/gbmaVaEf+Etbffk0quZ9iYfrfG9CQLBa/KgUPGqqLZFRpA71qO8rpC XWCVy8zRbbEADI7wGCY/edX8bGNRnUwaqRkR2CYxUsyK2JIPvd4jCSmJojTcYQUMsHFC376j ShZj3MPbaJbIaOUwVQJnwVk2pGpcA=
- Ironport-phdr: 9a23:CLFnfhz/sQi7ktHXCy+O+j09IxM/srCxBDY+r6Qd2+gXIJqq85mqBk HD//Il1AaPAdyDraodw8Pt8InYEVQa5piAtH1QOLdtbDQizfssogo7HcSeAlf6JvO5JwYzHc BFSUM3tyrjaRsdF8nxfUDdrWOv5jAOBBr/KRB1JuPoEYLOksi7ze+/94DPbwlSmDaxfK55IQ mrownWqsQYm5ZpJLwryhvOrHtIeuBWyn1tKFmOgRvy5dq+8YB6/ShItP0v68BPUaPhf6QlVr NYFygpM3o05MLwqxbOSxaE62YGXWUXlhpIBBXF7A3/U5zsvCb2qvZx1S+HNsLxUL40RC+i77 91RxD0lCcJOTk58GTNhcxxiqJQvRatqhN7zoLRZoyeKfhwcb7Hfd4CS2RPXthfWTFCDIOyYI QAE/cOMuRWoITmu1sCsQGzCRWwCO711DNFgGL9060g0+QmFAHLxAguEMgIsH/Jsdj6KrwSUf uvw6nJ0D7OaPFW1i376ITSaR8uv+qMXalqfsrQ0kQvCx7FgkyNpoziJTOVyuENs3Wd7+V9T+ 6glnAophh3rzOyyMksjYzJiZgUylDC7Sh5z4c1JcG4SE5metGoCppQtyacOoBrQc0iW3lltD skxrACo5K3YjUGxZY9yxLCdfCKcJKE7xL+WOqJIjp1hGhpdKyhixqo9UWtzvfwWteo3FtFqC dOj8PCuWoX1xPJ78iKUvt98Vml2TaIzw3T9+dEIUExlaXBKp4hxqQ8locVsUTCByP5hUL2jL WKdkUh5+io7fnobq/7qZCCL4N0iwf+PboymsGnHOg0LAwDU3KF9eih1rDv51D1TKtJg/Eskq TVrYjWJcEBqa64Bw9V3Jwj6xG6Dzq+0tQXh38HIEhedx2ZlIjpIEvBIPHjAPejnlSgiSpkx/ fcPr39B5XNM37Dn6r7cblg9UFQ0BAzwsxH55JIFrEBJ+r+VVP2tNzBFxM2Lwi0w/v8B9hmzY MfWWePAreDP6/IsF+I4PgvI+iWa4MPtjb9Matt2/m7hngg3FQZYKOB3J0NaXn+EO41DV+eZC /Oi9FJO2oRpQM/BLjogVvEWzNIfH+zd74hoz08Ep6jEIHPAIyg1u/SlBynF4FbMzgVQmuHFm 3lItnVAqZeWGepOsZk1wc8e/2kQo4l2wupsVakmaZ6a+bT4DEdqJTvktR4tbSKyEMCsAdsBs HY6FmjCmF5mmRSGm0r2qF6qE15jEqF0O10hOZEEMFV67VFX1VibMKO/6lBE9n3Hzn5UJKRUl //HIe6HHQ9ScgtxsIIbwBxFof6gw==
Hi,
the mathematical components library has infrastructure for this:
http://math-comp.github.io/math-comp/htmldoc/mathcomp.ssreflect.fintype.html
Their book illustrates how to plug-in your own type in Part 2, Chapter
7.5.
-- Jan
On Mon, Mar 18, 2019 at 03:10:39PM +0100,
fritjof AT uni-bremen.de
wrote:
> Hi,
> I want to create a finite data type, like *Unsinged 8*,
> which containes values from 0 to 2^8 -1.
> I came up with an idea like:
> Definition unsigned (max:Z) : Set :=
> { x : Z | x >= 0 /\ x < max}.
> Definition unsigned_8 := unsigned (2^8).
> But I'm not sure, if this is the right way.
> Does someone know if there is a better way to define
> finite types?
> --f.
- [Coq-Club] finite data types, fritjof, 03/18/2019
- Re: [Coq-Club] finite data types, Mario Alvarez Picallo, 03/18/2019
- Re: [Coq-Club] finite data types, Jan Bessai, 03/18/2019
- Re: [Coq-Club] finite data types, Maximilian Wuttke, 03/18/2019
- Re: [Coq-Club] finite data types, Gregory Malecha, 03/19/2019
- Re: [Coq-Club] finite data types, Alix Trieu, 03/19/2019
- Re: [Coq-Club] finite data types, Xavier Leroy, 03/19/2019
- Re: [Coq-Club] finite data types, Gaëtan Gilbert, 03/19/2019
- Re: [Coq-Club] finite data types, Fritjof Bornebusch, 03/20/2019
- Re: [Coq-Club] finite data types, Emilio Jesús Gallego Arias, 03/20/2019
