coq-club - Re: [Coq-Club] Mutual induction schemes and recursive function arguments
  • From: Jean-Francois Monin <jean-francois.monin AT univ-grenoble-alpes.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Mutual induction schemes and recursive function arguments
  • Date: Tue, 16 Apr 2019 12:40:00 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jean-francois.monin AT univ-grenoble-alpes.fr; spf=Pass smtp.mailfrom=jean-francois.monin AT univ-grenoble-alpes.fr; spf=None smtp.helo=postmaster AT zm-mta-out-1.u-ga.fr
Hi,
The trick explained by D. Larchey-Wendling in this talk
at TYPES'2019 could be an option. It works on mutual
recursive finctiosn as well.
Jean-Francois
On Tue, Apr 16, 2019 at 10:41:03AM +0200, Pierre Courtieu wrote:
> Hi,
> In general Function does not deal well with higher order except in
> very simple cases. However in your case you are hitting a limit of
> inductive scheme generation of coq itself if i understand well.
> Function generates the graph of foo (Print R_foo) correctly imho, but
> the induction scheme of R_foo does not have the recursion hypothesis
> you want either.
> I suppose you can give a try to the Equation plugin (but higher order
> may lead to axioms?) or prove you scheme by hand.
> Le mar. 16 avr. 2019 à 09:13, John Wiegley
> <johnw AT newartisans.com>
> a écrit :
> > Function foo' (h : Higher) : Higher :=
> > match h with
> > | Ctor f => Ctor (fun x => foo' (f x))
> > | Neg x => Rec (bar' x)
> > | Rec x => Rec (foo' x)
> > end
> > with
> > bar' (h : Higher) : Higher :=
> > match h with
> > | Ctor f => Ctor (fun x => bar' (f x))
> > | Neg x => Rec (foo' x)
> > | Rec x => Rec (bar' x)
> > end.
> > (** Why does it now fail to build the graph?
> This time you hit a limtation of Function itself with higher order.
> Hope this helps,
> Pierre
> > Warning: Cannot define graph(s) for foo', bar'
> > [funind-cannot-define-graph,funind]
