- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Mutual induction schemes and recursive function arguments
- Date: Tue, 16 Apr 2019 13:23:29 +0200 (CEST)
Hi John,
Why not try to use regular fixpoints and prove properties
by mutual fixpoints mimicking the def of foo/bar. See below
Best,
Dominique
Section Foo.
Variable a : Type.
Inductive Higher :=
| Ctor (f : a -> Higher)
| Neg (x : Higher)
| Rec (x : Higher).
Fixpoint foo (h : Higher) : Higher :=
match h with
| Ctor f => Ctor (fun x => foo (f x))
| Neg x => Rec (bar x)
| Rec x => Rec (foo x)
end
with
bar (h : Higher) : Higher :=
match h with
| Ctor f => Ctor (fun x => bar (f x))
| Neg x => Rec (foo x)
| Rec x => Rec (bar x)
end.
Variable (foo_pre foo_post bar_pre bar_post : Higher -> Type).
Fixpoint foo_spec h : foo_pre h -> foo_post h
with bar_spec h : bar_pre h -> bar_post h.
Proof.
Admitted.
End Foo.
----- Mail original -----
> De: "John Wiegley"
> <johnw AT newartisans.com>
> À: "coq-club"
> Envoyé: Mardi 16 Avril 2019 09:11:53
> Objet: [Coq-Club] Mutual induction schemes and recursive function arguments
> Hello,
> I have a data structure, one of whose constructors takes a function whose
> result is of the same type. I'd like to be able to recusively apply an 'f'
> to
> this structure, and prove that this 'f' preserves certain properties.
> However,
> the induction hypothesis generated by 'Function' is too weak. What is the
> best
> way to match the strength given by the data structure's own induction
> hypothesis? The reason I'm unable to use it directly is that I need to take
> mutual recursion into account. A reduced code example showing the difficulty
> follows.
> Thank you,
> John
> Require Import FunInd.
> Require Import Program.
> Section Foo.
> Variable a : Type.
> Inductive Higher :=
> | Neg (x : Higher)
> | Rec (x : Higher).
> Function foo (h : Higher) : Higher :=
> match h with
> | Ctor f => Ctor (foo ∘ f)
> end
> with
> match h with
> | Ctor f => Ctor (bar ∘ f)
> end.
> (* foo is defined
> bar is defined
> foo, bar are recursively defined (decreasing respectively on 1st,
> 1st arguments)
> foo_equation is defined
> foo_ind is defined
> foo_rec is defined
> foo_rect is defined
> bar_equation is defined
> bar_ind is defined
> bar_rec is defined
> bar_rect is defined
> R_foo_correct is defined
> R_bar_correct is defined
> R_foo_complete is defined
> R_bar_complete is defined *)
> (** Note the induction hypothesis for Ctor:
> (forall f : a -> Higher, (forall a : a, P (f a)) -> P (Ctor f)) *)
> Print Higher_ind.
> (** It is missing for foo_ind:
> (forall (h : Higher) (f : a -> Higher),
> h = Ctor f -> P (Ctor f) (Ctor (foo ∘ f))) *)
> Print foo_ind.
> Functional Scheme foo_ind2 := Induction for foo Sort Prop
> with bar_ind2 := Induction for bar Sort Prop.
> (** And also for foo_ind2:
> (forall (h : Higher) (f2 : a -> Higher),
> h = Ctor f2 -> P0 (Ctor f2) (Ctor (bar ∘ f2))) *)
> Print foo_ind2.
> Function foo' (h : Higher) : Higher :=
> match h with
> | Ctor f => Ctor (fun x => foo' (f x))
> | Neg x => Rec (bar' x)
> | Rec x => Rec (foo' x)
> end
> with
> bar' (h : Higher) : Higher :=
> match h with
> | Ctor f => Ctor (fun x => bar' (f x))
> | Neg x => Rec (foo' x)
> | Rec x => Rec (bar' x)
> end.
> (** Why does it now fail to build the graph?
> foo' is defined
> bar' is defined
> foo', bar' are recursively defined (decreasing respectively on 1st,
> 1st arguments)
> Warning: Cannot define graph(s) for foo', bar'
> [funind-cannot-define-graph,funind]
> Warning: Cannot build inversion information
> [funind-cannot-build-inversion,funind] *)
> End Foo.
> John Wiegley GPG fingerprint = 4710 CF98 AF9B 327B B80F
> http://newartisans.com 60E1 46C4 BD1A 7AC1 4BA2
- [Coq-Club] Mutual induction schemes and recursive function arguments, John Wiegley, 04/16/2019
- Re: [Coq-Club] Mutual induction schemes and recursive function arguments, Pierre Courtieu, 04/16/2019
- Re: [Coq-Club] Mutual induction schemes and recursive function arguments, Jean-Francois Monin, 04/16/2019
- Re: [Coq-Club] Mutual induction schemes and recursive function arguments, Dominique Larchey-Wendling, 04/16/2019
