- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Mutual induction schemes and recursive function arguments
- Date: Tue, 16 Apr 2019 13:56:01 +0200 (CEST)
Hi again,
This is what to expect as the most general induction principle from the mutual
fixpoint. Hope this helps,
D.
Section foo_rec_mutual_rect.
Variable (foo_pre foo_post bar_pre bar_post : Higher -> Type).
Hypothesis F01 : forall f, (forall x, foo_post (f x)) -> foo_post (Ctor
(fun x => f x)).
Hypothesis F02 : forall f, foo_pre (Ctor f) -> forall x, foo_pre (f x).
Hypothesis F11 : forall x, bar_post x -> foo_post (Rec x).
Hypothesis F12 : forall x, foo_pre (Neg x) -> bar_pre x.
Hypothesis F21 : forall x, foo_post x -> foo_post (Rec x).
Hypothesis F22 : forall x, foo_pre (Rec x) -> foo_pre x.
Hypothesis B01 : forall f, (forall x, bar_post (f x)) -> bar_post (Ctor
(fun x => f x)).
Hypothesis B02 : forall f, bar_pre (Ctor f) -> forall x, bar_pre (f x).
Hypothesis B11 : forall x, foo_post x -> bar_post (Rec x).
Hypothesis B12 : forall x, bar_pre (Neg x) -> foo_pre x.
Hypothesis B21 : forall x, bar_post x -> bar_post (Rec x).
Hypothesis B22 : forall x, bar_pre (Rec x) -> bar_pre x.
Fixpoint foo_spec h : foo_pre h -> foo_post (foo h)
with bar_spec h : bar_pre h -> bar_post (bar h).
Proof.
+ destruct h as [ f | x | x ]; simpl.
* intros H; apply F01.
intros x; apply foo_spec, F02, H.
* intros H; apply F11, bar_spec, F12, H.
* intros H; apply F21, foo_spec, F22, H.
* intros H; apply B01.
intros x; apply bar_spec, B02, H.
* intros H; apply B11, foo_spec, B12, H.
* intros H; apply B21, bar_spec, B22, H.
Qed.
End foo_rec_mutual_rect.
----- Mail original -----
> De: "Dominique Larchey-Wendling"
> À: "coq-club"
> Envoyé: Mardi 16 Avril 2019 13:23:29
> Objet: Re: [Coq-Club] Mutual induction schemes and recursive function
> arguments
> Hi John,
> Why not try to use regular fixpoints and prove properties
> by mutual fixpoints mimicking the def of foo/bar. See below
> Best,
> Dominique
> Section Foo.
> Variable a : Type.
> Inductive Higher :=
> | Ctor (f : a -> Higher)
> | Neg (x : Higher)
> | Rec (x : Higher).
> Fixpoint foo (h : Higher) : Higher :=
> match h with
> | Ctor f => Ctor (fun x => foo (f x))
> | Neg x => Rec (bar x)
> | Rec x => Rec (foo x)
> end
> with
> bar (h : Higher) : Higher :=
> match h with
> | Ctor f => Ctor (fun x => bar (f x))
> | Neg x => Rec (foo x)
> | Rec x => Rec (bar x)
> end.
> Fixpoint foo_spec h : foo_pre h -> foo_post h
> with bar_spec h : bar_pre h -> bar_post h.
> Proof.
> Admitted.
> End Foo.
>> De: "John Wiegley"
>> <johnw AT newartisans.com>
>> À: "coq-club"
>> Envoyé: Mardi 16 Avril 2019 09:11:53
>> Objet: [Coq-Club] Mutual induction schemes and recursive function arguments
>> Hello,
>> I have a data structure, one of whose constructors takes a function whose
>> result is of the same type. I'd like to be able to recusively apply an 'f'
>> to
>> this structure, and prove that this 'f' preserves certain properties.
>> However,
>> the induction hypothesis generated by 'Function' is too weak. What is the
>> best
>> way to match the strength given by the data structure's own induction
>> hypothesis? The reason I'm unable to use it directly is that I need to take
>> mutual recursion into account. A reduced code example showing the
>> difficulty
>> follows.
>> Thank you,
>> John
>> Require Import FunInd.
>> Require Import Program.
>> Section Foo.
>> Variable a : Type.
>> Inductive Higher :=
>> | Neg (x : Higher)
>> | Rec (x : Higher).
>> Function foo (h : Higher) : Higher :=
>> match h with
>> | Ctor f => Ctor (foo ∘ f)
>> end
>> with
>> match h with
>> | Ctor f => Ctor (bar ∘ f)
>> end.
>> (* foo is defined
>> bar is defined
>> foo, bar are recursively defined (decreasing respectively on 1st,
>> 1st arguments)
>> foo_equation is defined
>> foo_ind is defined
>> foo_rec is defined
>> foo_rect is defined
>> bar_equation is defined
>> bar_ind is defined
>> bar_rec is defined
>> bar_rect is defined
>> R_foo_correct is defined
>> R_bar_correct is defined
>> R_foo_complete is defined
>> R_bar_complete is defined *)
>> (** Note the induction hypothesis for Ctor:
>> (forall f : a -> Higher, (forall a : a, P (f a)) -> P (Ctor f)) *)
>> Print Higher_ind.
>> (** It is missing for foo_ind:
>> (forall (h : Higher) (f : a -> Higher),
>> h = Ctor f -> P (Ctor f) (Ctor (foo ∘ f))) *)
>> Print foo_ind.
>> Functional Scheme foo_ind2 := Induction for foo Sort Prop
>> with bar_ind2 := Induction for bar Sort Prop.
>> (** And also for foo_ind2:
>> (forall (h : Higher) (f2 : a -> Higher),
>> h = Ctor f2 -> P0 (Ctor f2) (Ctor (bar ∘ f2))) *)
>> Print foo_ind2.
>> Function foo' (h : Higher) : Higher :=
>> match h with
>> | Ctor f => Ctor (fun x => foo' (f x))
>> | Neg x => Rec (bar' x)
>> | Rec x => Rec (foo' x)
>> end
>> with
>> bar' (h : Higher) : Higher :=
>> match h with
>> | Ctor f => Ctor (fun x => bar' (f x))
>> | Neg x => Rec (foo' x)
>> | Rec x => Rec (bar' x)
>> end.
>> (** Why does it now fail to build the graph?
>> foo' is defined
>> bar' is defined
>> foo', bar' are recursively defined (decreasing respectively on 1st,
>> 1st arguments)
>> Warning: Cannot define graph(s) for foo', bar'
>> [funind-cannot-define-graph,funind]
>> Warning: Cannot build inversion information
>> [funind-cannot-build-inversion,funind] *)
>> End Foo.
>> John Wiegley GPG fingerprint = 4710 CF98 AF9B 327B B80F
> > http://newartisans.com 60E1 46C4 BD1A 7AC1 4BA2
- [Coq-Club] Mutual induction schemes and recursive function arguments, John Wiegley, 04/16/2019
- Re: [Coq-Club] Mutual induction schemes and recursive function arguments, Pierre Courtieu, 04/16/2019
- Re: [Coq-Club] Mutual induction schemes and recursive function arguments, Jean-Francois Monin, 04/16/2019
- Re: [Coq-Club] Mutual induction schemes and recursive function arguments, Dominique Larchey-Wendling, 04/16/2019
