- From: mukesh tiwari <mukeshtiwari.iiitm AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Invitation to join the Codewars Coq community
- Date: Fri, 28 Jun 2019 19:40:39 +1000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mukeshtiwari.iiitm AT gmail.com; spf=Pass smtp.mailfrom=mukeshtiwari.iiitm AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm1-f54.google.com
- Ironport-phdr: 9a23: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
Hi Vincent,
I just tried Require Import Psatz. for invert (A+A=B+B so A=B? Prove
it!), and lia works without any problem.
Cheers,
Mukesh
On Fri, Jun 28, 2019 at 7:31 PM Vincent
<vincent.siles AT gmail.com>
wrote:
> I'll definitely try lia ! I tried with the Require Import but got an error.
> Maybe it was disable for this particular (very simple) exercise. Will try
> again :)
> Le ven. 28 juin 2019 à 10:57, Théo Zimmermann
> <theo.zimmi AT gmail.com>
> a écrit :
>> Hi Vincent,
>> "omega" is available actually: you just need to import it "Require
>> Import Omega."
>> Most people nowadays use "lia" though since "omega" is about to be
>> deprecated in favor of "lia". (Using "lia" requires you to "Require
>> Import Lia.")
>> Théo
>> Le ven. 28 juin 2019 à 10:47, Vincent Siles
>> <vincent.siles AT ens-lyon.org>
>> a écrit :
>> > I played a bit with it this morning, it's nice. I have the same remark
>> > as Agnishom plus a minor one: could Omega be available ? That would be
>> > helpful to discharge some annoying arithmetic proofs :D
>> > Le ven. 28 juin 2019 à 10:30, Agnishom Chattopadhyay
>> > <agnishom AT cmi.ac.in>
>> > a écrit :
>> >> This is great. Somewhat similar to Proof Ground and Proving for Fun.
>> >> It is actually quiet difficult to work with the web interface since it
>> >> does not provide the interactive Coq environment. So maybe we can have
>> >> a Coq IDE or links for downloading the ``Preloaded" files?
>> >> --Agnishom
>> >> On Fri, Jun 28, 2019 at 7:13 AM Donald Leung
>> >> <i.donaldl AT me.com>
>> >> wrote:
>> >>> I hereby write to you to invite you to sign up for an account on
>> >>> Codewars: https://www.codewars.com
>> >>> Codewars is a training platform where programmers of all disciplines
>> >>> train on code challenges called Kata in order to improve their
>> >>> programming skills. The Coq proof assistant was recently added to
>> >>> Codewars (approx. April 2019) and there are currently insufficient Coq
>> >>> users to push newly authored Coq challenges out of the Beta (testing)
>> >>> phase; therefore, it would be an honor to have a seasoned Coq user
>> >>> like you on Codewars to test them out and contribute more interesting
>> >>> Coq challenges to the community.
>> >>> Should you choose to create an account on Codewars, you are also
>> >>> welcome to ask any questions about the Codewars platform in general or
>> >>> simply chat with other Codewarriors via our Gitter channel:
>> >>> https://gitter.im/Codewars/codewars.com
>> >>> Yours sincerely,
>> >>> Donald Sebastian Leung
>> >>> A Year 2 CSE undergraduate at The Hong Kong University of Science and
>> >>> Technology
- [Coq-Club] Invitation to join the Codewars Coq community, Donald Leung, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Agnishom Chattopadhyay, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Vincent Siles, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Théo Zimmermann, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Vincent, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, mukesh tiwari, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Donald Leung, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Bas Spitters, 06/28/2019
