- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Invitation to join the Codewars Coq community
- Date: Fri, 28 Jun 2019 22:10:22 +0800
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=i.donaldl AT me.com; spf=Pass smtp.mailfrom=i.donaldl AT me.com; spf=None smtp.helo=postmaster AT pv50p00im-ztbu10021601.me.com
- Ironport-phdr: 9a23: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
@Agnishom: Many thanks for your feedback and links to similar websites hosting recreational theorem-proving challenges. Unfortunately, since the Codewars platform was designed to support a wide variety of programming languages, the maintainers decided that it was impractical to support Coq-specific IDE features such as interactively stepping through a proof script. The current recommended way of solving a Coq challenge on Codewars is to simply copy the provided template into an IDE of your choice such as CoqIDE or Proof General and develop your solution locally. The preloaded code is often displayed within the Kata description itself so you may wish to copy those code snippets into your local environment as well in a separate file “Preloaded.v”.
@Vincent: The “omega” tactic (as is the rest of the Coq standard library plus a few external libraries) is available on Codewars - you can use it in your solution by adding “From Coq Require Import omega.Omega” to the top of your solution file.
More information about the Coq environment on Codewars can be found at https://github.com/Codewars/codewars.com/wiki/Language-Coq
Cheers,
Donald
- [Coq-Club] Invitation to join the Codewars Coq community, Donald Leung, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Agnishom Chattopadhyay, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Vincent Siles, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Théo Zimmermann, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Vincent, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, mukesh tiwari, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Donald Leung, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Bas Spitters, 06/28/2019
