- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Invitation to join the Codewars Coq community
- Date: Fri, 28 Jun 2019 16:57:26 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=b.a.w.spitters AT gmail.com; spf=Pass smtp.mailfrom=b.a.w.spitters AT gmail.com; spf=None smtp.helo=postmaster AT mail-yw1-f51.google.com
- Ironport-phdr: 9a23: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
Just checking with regard to the IDE. Are you aware of jscoq, a
webinterface for Coq:
https://github.com/ejgallego/jscoq
On Fri, Jun 28, 2019 at 4:11 PM Donald Leung
<i.donaldl AT me.com>
wrote:
> @Agnishom: Many thanks for your feedback and links to similar websites
> hosting recreational theorem-proving challenges. Unfortunately, since the
> Codewars platform was designed to support a wide variety of programming
> languages, the maintainers decided that it was impractical to support
> Coq-specific IDE features such as interactively stepping through a proof
> script. The current recommended way of solving a Coq challenge on Codewars
> is to simply copy the provided template into an IDE of your choice such as
> CoqIDE or Proof General and develop your solution locally. The preloaded
> code is often displayed within the Kata description itself so you may wish
> to copy those code snippets into your local environment as well in a
> separate file “Preloaded.v”.
> @Vincent: The “omega” tactic (as is the rest of the Coq standard library
> plus a few external libraries) is available on Codewars - you can use it in
> your solution by adding “From Coq Require Import omega.Omega” to the top of
> your solution file.
> More information about the Coq environment on Codewars can be found at
> https://github.com/Codewars/codewars.com/wiki/Language-Coq
> Cheers,
> Donald
- [Coq-Club] Invitation to join the Codewars Coq community, Donald Leung, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Agnishom Chattopadhyay, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Vincent Siles, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Théo Zimmermann, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Vincent, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, mukesh tiwari, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Donald Leung, 06/28/2019
- Re: [Coq-Club] Invitation to join the Codewars Coq community, Bas Spitters, 06/28/2019
