- From: Matthieu Sozeau <matthieu.sozeau AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Need help for manual induction scheme definition
- Date: Tue, 24 Sep 2019 17:48:29 +0200
Hi Vincent,
You should write a return clause `match e as e’ return match e’ with None
=> True | Some t => P t end with ...` for the match on the option value, I
guess. Coq cannot infer its type automatically. The error message is sadly
misleading.
Best,
-- Matthieu
> Le 24 sept. 2019 à 17:41, Vincent Siles
> <vincent.siles AT ens-lyon.org>
> a écrit :
> Hi !
> I'm facing an somehow complex inductive type, for which I have to write the
> induction scheme by hand. Here is a stripped down example of what I'm doing:
> Require Import List.
> Inductive t : Set :=
> | Base : t
> | Rec : list (option t) -> t -> t
> Section All.
> Variables (T: Set) (P: T -> Prop).
> Fixpoint All (l : list T) : Prop :=
> match l with
> | nil => True
> | hd :: tl => P hd /\ All tl
> end.
> End All.
> Section Induc.
> Parameter P: t -> Prop.
> Parameter HBase : P Base.
> Parameter HRec: forall l x,
> All
> (option t)
> (fun x => match x with Some e => P e | None => True end)
> l ->
> P x ->
> P (Rec l x).
> Fixpoint induc (e : t) { struct e } : P e :=
> match e with
> | Base => HBase
> | Rec l x => HRec l x
> ((fix induc_rec l := match l with
> | nil => I
> | hd :: tl =>
> conj (match hd with
> | Some e => induc e (* error here *)
> | None => I
> end) (induc_rec tl)
> end) l) (induc x)
> end.
> End Induc.
> Coq complains that:
> In environment
> induc : forall e : t, P e
> e : t
> l : list (option t)
> x : t
> induc_rec : list (option t) -> True
> l0 : list (option t)
> hd : option t
> tl : list (option t)
> e0 : t
> The term "induc e0" has type "P e0" while it is expected to have type
> "?P@{l0:=l; l:=l0; h0:=Some e0}" (cannot instantiate
> "?P" because "e" is not in its scope: available arguments are
> "induc" "e" "l" "x" "induc_rec" "l" "hd" "tl" "Some e").
> I'm still investigating, but I think I need some external help on that one
> :D
> Best regards,
> V.
- [Coq-Club] Need help for manual induction scheme definition, Vincent Siles, 09/24/2019
- Re: [Coq-Club] Need help for manual induction scheme definition, Vincent Siles, 09/24/2019
- Re: [Coq-Club] Need help for manual induction scheme definition, Matthieu Sozeau, 09/24/2019
- Re: [Coq-Club] Need help for manual induction scheme definition, Vincent, 09/24/2019
- Re: [Coq-Club] Need help for manual induction scheme definition, Jan-Oliver Kaiser, 09/24/2019
- Re: [Coq-Club] Need help for manual induction scheme definition, Dominique Larchey-Wendling, 09/24/2019
