coq-club - Re: [Coq-Club] Need help for manual induction scheme definition
  • From: Vincent Siles <vincent.siles AT ens-lyon.org>
  • To: Coq-Club Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Need help for manual induction scheme definition
  • Date: Tue, 24 Sep 2019 18:32:36 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=vincent.siles AT ens-lyon.org; spf=None smtp.mailfrom=SRS0=tghc=XT=ens-lyon.org=vincent.siles AT bounce.ens-lyon.org; spf=Pass smtp.helo=postmaster AT sonata.ens-lyon.org
  • Ironport-phdr: 9a23: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
Jan's version seems closer to mine but I'll try both, thanks !
V.
Le mar. 24 sept. 2019 à 18:28, Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr> a écrit :
Maybe you could use this one ...
Best,
D.
Require Import List Extraction.
Unset Elimination Schemes.
Inductive t : Set :=
| Base : t
| Rec : list (option t) -> t -> t
Set Elimination Schemes.
Section t_rect.
  Let R t t' :=
    match t' with
      | Base     => False
      | Rec l t' => In (Some t) l \/ t = t'
    end.
  Let Fixpoint R_wf t : Acc R t.
  Proof.
    destruct t as [ | l t ]; constructor; simpl; intros x Hx.
    + destruct Hx.
    + destruct Hx as [ Hx | Hx ].
      * induction l as [ | [ y | ] l IHl ].
        - destruct Hx.
        - destruct Hx as [ | Hx ].
          ++ generalize (R_wf y); inversion H; trivial.
          ++ apply IHl, Hx.
          ++ discriminate H.
          ++ apply IHl, Hx.
      * generalize (R_wf t); subst; trivial.
  Qed.
  Variables (P : t -> Type)
            (HP0 : P Base)
            (HP1 : forall l t, (forall k, In (Some k) l -> P k) -> P t -> P (Rec l t)).
  Fixpoint t_rect t : P t.
  Proof.
    generalize (R_wf t).
    revert t.
    refine (fix loop x Hx { struct Hx } := _).
    destruct x as [ | l t ].
    + apply HP0.
    + apply HP1.
      2: apply loop, (Acc_inv Hx); simpl; right; trivial.
      intros k Hk; apply loop, (Acc_inv Hx); simpl; left; trivial.
  Qed.
End t_rect.
Recursive Extraction t_rect.
De: "Vincent Siles" <vincent.siles AT ens-lyon.org>
À: "coq-club" <coq-club AT inria.fr>
Envoyé: Mardi 24 Septembre 2019 18:10:46
Objet: Re: [Coq-Club] Need help for manual induction scheme definition
I tried to prove it using tactics and check the proof term and that's what is happening, but I can't managed to replicate it, now I get:
In environment
induc : forall u : t, P u
u : t
l : list (option t)
x : t
induc_rec :
forall l : list (option t),
All (option t)
  (fun x : option t => match x with
                       | Some x0 => P x0
                       | None => True
                       end) l
l0 : list (option t)
hd : option t
tl : list (option t)
The term
 "match hd as o return match o with
                       | Some x0 => P x0
                       | None => True
                       end with
  | Some e => induc e
  | None => I
  end" has type "match hd with
                 | Some x0 => P x0
                 | None => True
                 end" while it is expected to have type
"?A@{l0:=l; l:=l0}" (unable to find a well-typed instantiation for
"?A": cannot ensure that "Type" is a subtype of "Prop").
I guess I'll go with the tactic solution, it's a bit more readable anyway :D
PS: sorry for the dup, first answer got sent with the wrong address...
Le mar. 24 sept. 2019 à 17:50, Matthieu Sozeau <matthieu.sozeau AT inria.fr> a écrit :
Hi Vincent,
  You should write a return clause `match e as e’ return match e’ with None => True | Some t => P t end with ...` for the match on the option value, I guess. Coq cannot infer its type automatically. The error message is sadly misleading.
Best,
-- Matthieu
> Le 24 sept. 2019 à 17:41, Vincent Siles <vincent.siles AT ens-lyon.org> a écrit :
> Hi !
> I'm facing an somehow complex inductive type, for which I have to write the induction scheme by hand. Here is a stripped down example of what I'm doing:
> Require Import List.
> | Base : t
> Section All.
>    Variables (T: Set) (P: T -> Prop).
>    Fixpoint All (l : list T) : Prop :=
>        match l with
>        | nil => True
>        | hd :: tl => P hd /\ All tl
>        end.
> End All.
> Section Induc.
>    Parameter P: t -> Prop.
>    Parameter HBase : P Base.
>    Parameter HRec: forall l x,
>        All
>          (option t)
>          (fun x => match x with Some e => P e | None => True end)
>          l ->
>        P x ->
>        P (Rec l x).
>    Fixpoint induc (e : t) { struct e } : P e :=
>        match e with
>        | Base => HBase
>        | Rec l x => HRec l x
>                ((fix induc_rec l := match l with
>                   | nil => I
>                   | hd :: tl =>
>                           conj (match hd with
>                                 | Some e => induc e  (* error here *)
>                                 | None => I
>                                 end) (induc_rec tl)
>                end) l) (induc x)
>        end.
> End Induc.
> Coq complains that:
> In environment
> induc : forall e : t, P e
> e : t
> l : list (option t)
> x : t
> induc_rec : list (option t) -> True
> hd : option t
> e0 : t
> The term "induc e0" has type "P e0" while it is expected to have type
> "?P@{l0:=l; l:=l0; h0:=Some e0}" (cannot instantiate
> "?P" because "e" is not in its scope: available arguments are
> "induc" "e" "l" "x" "induc_rec" "l" "hd" "tl" "Some e").
> I'm still investigating, but I think I need some external help on that one :D
> Best regards,
> V.
