coq-club - Re: [Coq-Club] Need help for manual induction scheme definition
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Need help for manual induction scheme definition
  • Date: Tue, 24 Sep 2019 18:15:10 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=janno AT mpi-sws.org; spf=Pass smtp.mailfrom=janno AT mpi-sws.org; spf=None smtp.helo=postmaster AT jupiter.mpi-klsb.mpg.de
  • Autocrypt: addr=janno AT mpi-sws.org; prefer-encrypt=mutual; keydata= mQENBFNx+loBCAC52t5xTWGjj9DMTCyTP3vL0cLh63ZNGTD7Ut5F3zVEyA1wlCRziuDVg+4b 7U7UBd2GpE4tY0YzRMlQElFP7XpkkEXC+JY+Vnor+4GyHvvbvRLKaB6mbQTsZ5R7I0O1gOy4 yCvljA9NrnFUI4f2HIZyOnjjgXlGjs4JgYCes/hgfvCLmtWq7Gve9xtEGq4IEKw9qz07Homh ExBDCwx8nfVphUnnt+PosxJuO/7rFN2v6wdL8PeQFMUsm9MADpNssuvSI+XC0QO0cK45g1zb ZTpaAzc3dXTjYjZm5tLo6ChWI8QpZRCfJUztaLIWiPd2NZLyr5OoM6HnUaj5vJZrEa4ZABEB AAG0JUphbi1PbGl2ZXIgS2Fpc2VyIDxqYW5ub0BtcGktc3dzLm9yZz6JAVQEEwEIAD4CGyMF CwkIBwIGFQgJCgsCBBYCAwECHgECF4AWIQT/HCVoRd2YP5nVLNFZLRd4BiFNXAUCXMwQ/QUJ CztKIwAKCRBZLRd4BiFNXGO4B/0Z6bkJ1KDroeCely6usOSCWI6cHwJBdvlh2mn2aCvUWBIQ nDqvJZRMVd/SsSSTWruCKG61DVN36Jge15BK25SESKYB2/vOs4DWcNOtyQYY3ndPkn18/Jzj 4saQiN47C7AfDLUSLChHFaXzwyUD/rjIl2kyoYSAduFO3XhBwBwiCOpspv3Pl8jRiwxrGA3w eYZvz7P+vLtUMYA/iXEB22Mx6/KQ6k5HGiQyMt5CXiPkpgBCPNLyFdoGm3USG/EFb3wZfpFM dTC/3ovvaokRRF4xROQgTnfq3wa9YwQqYk7tstoNKlSGspei7GGG/tiYiHX/yFbwUALZH3fb FsTZo/AOuQENBFNx+loBCADFP9jeSh2FgvmAdA09KAgLArhzMnZs9zslNsmO0dwDtItE0V5B z+SuMPg0KahEiFMVBQjRYE23PKJ7Bx3xxlXYEIHoKqq+IWHOTOV36PbYdPyCWBYMRW4rfuse xx0UBx69r2MFV13VGfpzDAyNnQRArtG/EaS4ACkdehnJX5duH53O/Km/4QBTajeWrThx1TyS iBc2BvMZJSsRXaKWsXg7ZIZgOe8Cj/KGcSCOOUcB3mj5dd+hsKUS4RSux+xrDuGx3pA2+pWE hyGg20i9Ghpse8gqLQpi+KinMK0oaue09Y5uhHl2ssqtYomjgAW528h0qJ77fI7o4CEn53Ed 7vvrABEBAAGJATwEGAECACYCGwwWIQT/HCVoRd2YP5nVLNFZLRd4BiFNXAUCXMwRAQUJCztK JwAKCRBZLRd4BiFNXIteB/9Gfp7TVIMZOj9C7Z8CuSz3hxyZnRD5Vd7DPHrUSV70P+1g0dIA eNUJeXBQ4OccrsP1TiPHeZoTGH10vLT1OZ0H+57fhARpqADeeZ/d9gzusNllVoxiYIO7T+7R sx4OUxk+qB/IyDTvPRmeangmnE4MEzPaPs7OPaCtxf39tgxeJv0DCXPNOOlafIY4QuSCl/h4 bALca8a4j70w+qmBGo05kV8a/WcWgQsrF1TkbeaQ2RXqcYpfe4Z0D4LHuxjXKJq+1nEZeeWl /t3t+urSqjot/kOwiE+c26yb/eI1Hq/MoVKXWDVMY+7wqhgjKdCu1Mpz/pYDGr6LjjCvAgMD T3Bc
  • Ironport-phdr: 9a23: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
  • Openpgp: preference=signencrypt
I can't say what exactly is wrong with your approach. While trying to fix it, I got confused by the way it was written. Below is a working implementation written in a way that I vaguely understand. The first match return type annotation is optional. Coq is smart enough to figure that one out. The other annotations are not optional, AFAICT.
Require Import List.
Inductive t : Set :=
| Base : t
| Rec : list (option t) -> t -> t
Section All.
Variables (T: Set) (P: T -> Prop).
Fixpoint All (l : list T) : Prop :=
match l with
| nil => True
| hd :: tl => P hd /\ All tl
end.
End All.
Section Induc.
Parameter P: t -> Prop.
Parameter HBase : P Base.
Definition Ret x := match x with Some e => P e | None => True end.
Parameter HRec: forall l x,
All
(option t)
Ret
l ->
P x ->
P (Rec l x).
Fixpoint induc (e : t) { struct e } : P e :=
match e as e return P e with
| Base => HBase
| Rec l x =>
let induc_rec :=
fix induc_rec l : All (option t) Ret l :=
match l with
| nil => I
| hd :: tl =>
conj
(match hd as hd return Ret hd with
| Some e => induc e
| None => I
end)
(induc_rec tl)
end
in
HRec l x (induc_rec l) (induc x)
end.
End Induc.
On 9/24/19 6:10 PM, Vincent Siles wrote:
I tried to prove it using tactics and check the proof term and that's what is happening, but I can't managed to replicate it, now I get:
In environment
induc : forall u : t, P u
u : t
l : list (option t)
x : t
induc_rec :
forall l : list (option t),
All (option t)
  (fun x : option t => match x with
                       | Some x0 => P x0
                       | None => True
                       end) l
l0 : list (option t)
hd : option t
tl : list (option t)
The term
 "match hd as o return match o with
                       | Some x0 => P x0
                       | None => True
                       end with
  | Some e => induc e
  | None => I
  end" has type "match hd with
                 | Some x0 => P x0
                 | None => True
                 end" while it is expected to have type
"?A@{l0:=l; l:=l0}" (unable to find a well-typed instantiation for
"?A": cannot ensure that "Type" is a subtype of "Prop").
I guess I'll go with the tactic solution, it's a bit more readable anyway :D
PS: sorry for the dup, first answer got sent with the wrong address...
Le mar. 24 sept. 2019 à 17:50, Matthieu Sozeau <matthieu.sozeau AT inria.fr <mailto:matthieu.sozeau AT inria.fr>> a écrit :
Hi Vincent,
  You should write a return clause `match e as e’ return match e’
with None => True | Some t => P t end with ...` for the match on the
option value, I guess. Coq cannot infer its type automatically. The
error message is sadly misleading.
Best,
-- Matthieu
> Le 24 sept. 2019 à 17:41, Vincent Siles
<vincent.siles AT ens-lyon.org
<mailto:vincent.siles AT ens-lyon.org>>
a
écrit :
> Hi !
> I'm facing an somehow complex inductive type, for which I have to
write the induction scheme by hand. Here is a stripped down example
of what I'm doing:
> | Base : t
> Section All.
>        match l with
>        | nil => True
>        | hd :: tl => P hd /\ All tl
>        end.
> End All.
> Section Induc.
>        All
>          (option t)
>          (fun x => match x with Some e => P e | None => True end)
>          l ->
>        P x ->
>        P (Rec l x).
>        match e with
>        | Base => HBase
>        | Rec l x => HRec l x
>                ((fix induc_rec l := match l with
>                   | nil => I
>                   | hd :: tl =>
>                           conj (match hd with
>                                 | Some e => induc e  (* error here *)
>                                 | None => I
>                                 end) (induc_rec tl)
>                end) l) (induc x)
>        end.
> End Induc.
> Coq complains that:
> In environment
> induc : forall e : t, P e
> e : t
> l : list (option t)
> x : t
> induc_rec : list (option t) -> True
> hd : option t
> e0 : t
> The term "induc e0" has type "P e0" while it is expected to have type
> "?P@{l0:=l; l:=l0; h0:=Some e0}" (cannot instantiate
> "?P" because "e" is not in its scope: available arguments are
> "induc" "e" "l" "x" "induc_rec" "l" "hd" "tl" "Some e").
> I'm still investigating, but I think I need some external help on
that one :D
> Best regards,
> V.
