coq-club - Re: [Coq-Club] Separate/incremental extraction of parts of a Coq library
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Separate/incremental extraction of parts of a Coq library
  • Date: Wed, 30 Oct 2019 22:49:45 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=e.mdorel AT gmail.com; spf=Pass smtp.mailfrom=e.mdorel AT gmail.com; spf=None smtp.helo=postmaster AT mail-ot1-f46.google.com
  • Ironport-phdr: 9a23:lPxEGRZZGdbLJonNAR1ZjoT/LSx+4OfEezUN459isYplN5qZr864bnLW6fgltlLVR4KTs6sC17ON9fm4AidZvMjJmUtBWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYdFRrlKAV6OPn+FJLMgMSrzeCy/IDYbxlViDanbr5+MRu7oR/MusUKj4ZuJbs9xxvIr3BVZ+lY2GRkKE6JkR3h/Mmw5plj8ypRu/Il6cFNVLjxcro7Q7JFEjkoKng568L3uxbNSwuP/WYcXX4NkhVUGQjF7Qr1UYn3vyDnq+dywiiaPcnxTbApRTSv6rpgRRH0hCsbMTMy7WfagdFygq1GuhKsvxNww4DWb4GPNPRwcKDTc84ES2VdRcteTTBND5mmYocTE+YMP+BVpJT9qVsUqhu+ABGhCuz1yj9JhX/9wKo03P47EQHa3QwgGcsCvnrTrNXvKqgSVf2+wa7WwjnZavNZxDD96JLWfRAluvyMUrdwftDQyUkrDQ/KklKQqYn8Mj6Ty+8DvW+b7+96WuKujW4qswBxoj61xsctkIbFnIwVykrc+SV82ok1P8G4SE99YdK9DZRQsDuaOJVyQs84RGFooik6x7sbspC4ZCgH0IorywLbZvCdcIWF4gjvWPiMLTtknn5od7OyihCv+ka60OL8TNO70FNSoypFjNbMsncN2gTW6sedS/t9+l6t2TGT1wzO8+1EL085mKvBJ54uxb4wkZUTsUDdESPshEr2i6qWel0l+uiu9evnfq3rqoGAO4JwkA3zMaQjltahDeglLgQCRWeW9OWk2L3m50L5QbFKjvMskqnetZDXPdoUqrS8AwBI1YYj8QiwDzO93dQXmHkINlNFeBadg4f1PFHOJej0De2jjFS0jDdr2/fGM6X9DZXKN3jPiavufbJg60FH0wcz1tBe55dMCr4bOv7zW0nxtMbZDhAjKQC0zfznW51B0dYVXnvKCauEOovTt0WJ76QhObq2aZcRqQr6fvU/5v2oiHYjhV4bOKWux5YTQH2+BbFiMkKfJ332jYQvC2AP6yckTe+irVSYTT9VIlq1Ra84rmU2ToeqCp3OQqiihbWA2GGwGZgANTMOMUyFDXq9L9bMYPwLci/HepY9wAxBbqCoTsoa7T/rrBXzkuM1Ie/d+ylevpXmhoAsur/j0Coq/DkxNPyzlmGAS2YuwzENTj4ymadj+AlzlgnF3q9/jPhVU9dU4qERC1ZoBdvn1+V/TuvKdEfEd9aNRkyhR4z/Uz40R9M1hdQJZhQkFg==
Hello,
I'm unsure whether this would be useful for Clément's use case… but your discussion makes me think about OCaml's type-equation feature
(the corresponding grammar being http://caml.inria.fr/pub/docs/manual-ocaml/typedecl.html#type-equation ), for example:
module A = struct type nat = O | S of nat end
module B = struct type nat2 = A.nat = O | S of nat2 end
let a = A.(S O)
let b = B.(S O)
let () = assert (a = b)
My 2 cents,
Erik
Le mer. 30 oct. 2019 à 22:10, Stefan Monnier <monnier AT iro.umontreal.ca> a écrit :
> Structurally equal types are equal.  What you mean is "two inductive types
> that have the same constructors with the same argument types",
Nitpick: isn't this more or less the "definition" of "structurally equal"?
More to the point, if you take the "paper" definition of inductive types
with calculus like
    e ::= ... | Ind(x : e, \vec e) | Con(e, n) | Case(...)
then I believe you'd get that "two inductive types that have the same
constructors with the same argument types" would indeed be equal.
IOW the reason they're not equal is because Coq uses a kind of "name
equality" or "generativity" of inductive definitions.
[ The above may look like a statement, but it's really a question in
  disguise, because I'm not really sure this is handled by Coq.  ]
        Stefan
