coq-club - Re: [Coq-Club] Separate/incremental extraction of parts of a Coq library
  • From: Matthieu Sozeau <matthieu.sozeau AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Separate/incremental extraction of parts of a Coq library
  • Date: Thu, 31 Oct 2019 21:59:37 +0100
That’s the “sore” point, I basically make a list of all the modules in A
(extracted using Extraction Library, so they have everything) and remove all
that from B’s extracted files.
-- Matthieu
> Le 31 oct. 2019 à 20:17, Clément Pit-Claudel
> <cpitclaudel AT gmail.com>
> a écrit :
>> On 2019-10-31 13:32, Matthieu Sozeau wrote:
>> We do something like this in the MetaCoq project: using `Separate
>> Extraction` or `Extraction Library` to extract module B, knowing that I
>> have an mlpack implementing A on which B depends, and then calling `ocamlc
>> -open Myplugin.A -I …/user-contrib/myplugin B.ml` to compile the «
>> extension » code. With `Separate Extraction`, it’s a matter of removing
>> all the generated code for `A` and its dependencies that is produced by
>> extraction. With `Extraction Library` the user has to be careful that he
>> extracts all the libraries he needs but doesn’t need . No unsafe type
>> casts are inserted this way.
> Hi Matthieu,
> Thanks, that's very interesting feedback.
> How do you handle dependencies on part of the standard library of Coq? Do
> you make sure to include it all in the mlpack for A? More generally, how
> do you distinguish between modules that you need to keep in B and modules
> that are already in A?
> Clément.
