coq-club - Re: [Coq-Club] Separate/incremental extraction of parts of a Coq library
  • From: Matthieu Sozeau <matthieu.sozeau AT inria.fr>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Separate/incremental extraction of parts of a Coq library
  • Date: Thu, 31 Oct 2019 18:32:16 +0100
Hi Clément,
> Le 30 oct. 2019 à 15:13, Clément Pit-Claudel
> <cpitclaudel AT gmail.com>
> a écrit :
> Hi all.
> I'm running out of ideas regarding a tricky Coq extraction question.
> I have a compiler from Foo to Bar written in Coq, then a compiler from Bar
> to Baz written in OCaml. Foo and Bar are ASTs defined as `Inductive`s in
> Coq; Baz is an AST defined in OCaml.
> I don't write programs directly in Foo; instead I use Gallina as a
> metaprogramming language to generate Foo ASTs. Then I extract these ASTs
> to OCaml and use the BarBaz compiler written in OCaml to generate Baz ASTs
> and write these to disk.
> Currently, the FooBar compiler is bundled with all my example Foo programs
> and extracted as one FooBar.ml file, and then the BarBaz compiler depends
> on FooBar.ml and compiles all the example Foo programs.
> I'm looking for a way to extract example programs separately from the
> compiler itself. This would allow me to distribute an OPAM package
> FooBarBaz including the whole compilation pipeline, and then users could
> write their program in Coq, like this:
> Definition prog : foo_ast := ….
> Module FooBarBaz.
> Axiom baz_ast: Type.
> Extract Constant baz_ast => "FooBarBaz.BarBaz.baz_ast".
> Axiom compile : forall (prog: foo_ast): baz_ast.
> Extract Constant compile => "FooBarBaz.compile_foo".
> Axiom write_to_disk : forall (compiled_prog: baz_ast): unit.
> Extract Constant compile => "FooBarBaz.write_to_disk".
> End FooBarBaz.
> Definition main : unit := FooBarBaz.write_to_disk (FooBarBaz.compile_foo
> prog) "prog.baz".
> Extraction "prog.ml" main.
> The generated prog.ml would be linked against the OPAM FooBarBaz package,
> and running prog.ml would produce "prog.baz".
> Unfortunately, this doesn't work: prog.ml has its own copy of the Foo and
> Bar ASTs, and these are not nominally the same types as those in the
> FooBarBaz package, so the call to FooBarBaz.compile_foo doesn't typecheck
> ("This expression has type foo_ast but an expression was expected of type
> FooBarBaz.FooBar.foo_ast)
> Is there an easy way around this issue? I guess I'd need to either:
> * Convince OCaml to accept to unify two structurally equal types; is this
> possible without an unsafe cast?
> * Tell Coq to extract only the definitions not provided by
> `FooBarBaz.FooBar`, and to add `open FooBarBaz.FooBar` at the top of
> `prog.ml`; is there a way to do that? Some form of incremental extraction?
We do something like this in the MetaCoq project: using `Separate Extraction`
or `Extraction Library` to extract module B, knowing that I have an mlpack
implementing A on which B depends, and then calling `ocamlc -open Myplugin.A
-I …/user-contrib/myplugin B.ml` to compile the « extension » code. With
`Separate Extraction`, it’s a matter of removing all the generated code for
`A` and its dependencies that is produced by extraction. With `Extraction
Library` the user has to be careful that he extracts all the libraries he
needs but doesn’t need . No unsafe type casts are inserted this way.
Best,
— Matthieu
