coq-club - Re: [Coq-Club] BigOp equality over differing indices
  • To: Kiran Corbett Gopinathan <e0427802 AT u.nus.edu>, Laurent Thery <Laurent.Thery AT inria.fr>, "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] BigOp equality over differing indices
  • Date: Thu, 28 Nov 2019 16:43:23 +0100
  • Autocrypt: addr=thery AT sophia.inria.fr; prefer-encrypt=mutual; keydata= mQENBE3a3V8BCADTeORKU7I7UmBBcs4VhSCq1IgKD8vdmdrGAlF3IJSFng7Fk8+MgS2gWYcS Ukf5t+rjNM3Z6brfYXc1naZlf2JPGHvAGiz8+TkXL+/ZA6+gAoIKy/iKyD+hCD8m92WH3rPH vCX6EJ44FEI7gUJ37GlTjvuP0I55vaFcwEg8nDgkALaCJvrSHtePuPKR1Q+9q2dgR7fTObal HYGMAsgT6k6n2ofe4Q6VFRLJhruU02qAfV5zgIoa3xgrTwSr4RRDILHttAw7EN6aLG6JycJ7 sPsPsiQzrd/tFsNbiHYeojJCkU2pDSQ3pBtXAJL/z2pMWTeTXvA60l9w0sDO7M3mkC3vABEB AAG0J0xhdXJlbnQgVGjDqXJ5IDxMYXVyZW50LlRoZXJ5QGlucmlhLmZyPokBOAQTAQIAIgUC TdrdXwIbAwYLCQgHAwIGFQgCCQoLBBYCAwECHgECF4AACgkQHHaWvRTi0tpIgggAnSUYcU2N uchXkGGwmPuLmvSUMiLkyFPs9GF2YF1ONOuJtpnQMcpsseCkcmIjESz0h5OpknpyraUXvbh0 ZdFqaLC2E+GyV8/YQi71wSsTPgWP450u0XUt0ysjwkKW6aIxIhSzrtgNp4E6w5KzXVJxA/yM V5RNFHg/5uifgfv4b7xaGHV8L93NbSvedk1O7yje5Hqgfab0t6J5Kf0M3sG+pB3gEkDVK9B7 +0fhe7/5u1Nj5HoLWid8UNZfFzJzb18Xe2ckzNye0KdDtQFac8qGUzhLbEYt3ScYjRYTq9/d V4Cin39j7Oo64Nk71iiLBISyuk0Q9D+Jq7nwwcQr/R8s1rkBDQRN2t1fAQgA7H6aX6BfdO/X Vlf4EGEoyFQ5u/JDe+giIHWSS34YWDWVUYyp320CrAYAkh9lQ1Nvh1tsmgiUh5xnY7wY0tOi wJSm94XlYAmHrddmWVNXRn09GvZJhfI2LdVBg3oxPfc8+bV+Hz83z/5BMPLOogxB22QMPJ6e iD2EsUMPNsuCVQ8WNo6ZmueuuYe7vEUXLYdRXNumJJgekEuG/q1BD4xgfzWpWfUODm6WygWZ oov50DomcDcAHW03bgnHlqnYu20Qg00GqgR3FKlORTvnOxD5TMCXe+eLUxkQfvnjbIPhtrnJ hgJMKVkRBEoaQ/XA4FdvxloInYPbqxNZ72yd09BbewARAQABiQEfBBgBAgAJBQJN2t1fAhsM AAoJEBx2lr0U4tLaWNQH/2/fIaF9ngbKPBJbDxYa7glJuCfamJgy3R8mJ//VYsS4RbdroSX3 29EgWlTx2reu1b4C5n5k7l4KpLgsRIc3bLUasGv15nf8BqmKIMulidzsxJv86S2imY/0870Q NOiO9SElHE7/2q4J1m2ew77SegiqGVWHl6Zs+4ROfOILTy24o26BQMAZhPX7jEs04Atv6yjw OUIPbzFO+XRuKqkBwHn9S8+GQelT0Gh84Dc5D2jIF0+kWY7uHqe2O+2LPfgO2CYhqmVfr/Ym mZv2xUyhJ7gui2hYaggncQ96cM2KhnKlgMw8nStY0GTqVXLEjPYblz8mqtF8aBPRSk/DjjrF QeI=
Maybe you can use partition_big to split your sum in bits that
correspond to your mappping.
On 11/28/19 4:28 PM, Kiran Corbett Gopinathan wrote:
> Hi Laurent,
> Apologies, my example wasn't quite clear enough to exactly capture the
> difficulty in my situation.
> One problem is that my summation doesn't split quite as nicely as the
> one in the example, and the corresponding elements on each summand may
> be interleaved, ruling out the possibility of simply splitting the
> summation. Additionally, the size of the mapping between summands (2 in
> the example) is actually given by an expression on the index of the sum
> - i.e rather than 2 * f(even(i)), I have something like g(i) * f(even(i)).
> Now, in my case, I can prove there exists a mapping between the summands
> of each summation - for each element in one sum, I can find g(i)
> distinct unique elements in the other sum, but I'm not sure how to
> manipulate the goal such that applying this mapping is possible.
> Thanks,
> Kiran Gopinathan.
> *From:*
> coq-club-request AT inria.fr
> <coq-club-request AT inria.fr>
> on behalf
> of Laurent Thery
> *Sent:* 28 November 2019 21:17
> *To:*
> *Subject:* Re: [Coq-Club] BigOp equality over differing indices
>         - External Email -
> Hi,
> I am not sure this will help you in your general problem.
> But in your particular example, you can split the sum to make
> the reindexing possible.
> Lemma example: forall f, \sum_(0 <= i < 4) (2 * f (even i)) = \sum_(0 <=
> i < 8) (f (even i)).
> Proof.
> move=> f.
> rewrite [RHS](big_cat_nat _ _  _ (_ : 0 <= 4)) //=.
>  rewrite -[4]/(0 + 4) big_addn /= add0n.
> rewrite  [X in _ = _ + X](eq_bigr (fun i => f (even i))) => [|i _]; last
> first.
>   by rewrite addnC /=;  case: i => [|i]; rewrite  ?negbK.
> rewrite -big_split.
> by apply: eq_bigr => i _ ; rewrite /= mul2n addnn.
> Qed.
> Laurent
> Ps : this 8.10 code
