- From: Thorsten Altenkirch <Thorsten.Altenkirch AT nottingham.ac.uk>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Cc: Kevin Buzzard <kevin.m.buzzard AT gmail.com>
- Subject: Re: [Coq-Club] Fwd: "Lean is like Coq but better"
- Date: Tue, 7 Jan 2020 10:12:55 +0000
- Accept-language: en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=exmail.nottingham.ac.uk; dmarc=pass action=none header.from=exmail.nottingham.ac.uk; dkim=pass header.d=exmail.nottingham.ac.uk; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=kcyA+UtkV4osdwJE7Y7D1bVjyHNSMayaJCmID5k/vEU=; b=N6HnXSY3ULhR8E9QWke71srwR6zyWIKvNG9emPo7fqOVtCbAxSGBQYGi4TMtRst7blcZtNd+I7d5RX3Ke+YjiO0cSFiQg55kBaOMyJChvIwUqaKO6IzXO0vTpY4jkj6sboIwppV0+C3REtlFiERHzxle2+KOoRfn01Qy3Vm+KR5KwiUwhSmtId0VnrS1EMoEXrqfRRYscZKBHT3vh/dZf83QT1ddCbrisol93LR3mVvlmRYXgqpTa1JWqHlWQR/oiWhqi1aBYklF/wu6tMH5f0dtbL0VVgNynZJDHNuppez7uxQjAmPcuK1mGK8SVKI/4jWPpQAArSYo132v26XnzA==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=iyP47fy7cXw4aS8M6gWGPd2z470RHp2t/SO/jLdAKtNW7Xug3xfK2R1y+w0NAO3GBEeKn5et90kRd7/1XOmup9+O6kJXqiciv2aIpiwlrl+rN6wTXUEbHydqHqi8PNmExI0hHwOLB4eg2acnV5cbjDKd6SNbjz17UnCtfyVx7q6mARtiapDapcPDoWfrKL0l8wAHVXy072r7w6NeXGqOJS9Nv5ZenrWwRxQbDdMc5KYcliJyq1vMFmcFRBDle2SmA8is7aj6SwJzUpuoAWr70XdnPsw9FGEH/3UWXUfih83/6O/zFB7lrf/TdQgDyIRS4EEfRasSvlDANy4H7xpOEg==
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Thorsten.Altenkirch AT nottingham.ac.uk; spf=Pass smtp.mailfrom=Thorsten.Altenkirch AT nottingham.ac.uk; spf=None smtp.helo=postmaster AT uidappmx05.nottingham.ac.uk
- Ironport-phdr: 9a23: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
Intuitionism does not reject the excluded middle (this is a theorem). All I was suggesting is to be aware when you are using it.
Thorsten
From: <coq-club-request AT inria.fr> on behalf of Kevin Buzzard <kevin.m.buzzard AT gmail.com>
Yes, Diaconescu is formalised in the Lean standard library and this is how excluded middle is proved in Lean: https://leanprover.github.io/theorem_proving_in_lean/axioms_and_computation.html#the-law-of-the-excluded-middle
While I'm here let me respond to something Thorsten said:
> Now let me get to the point that most Mathematicians are not aware of constructive Mathematics. This may well be true but does this mean that they are right and that constructive Mathematics is irrelevant for Mathematics? This seems rather a sociologically issue than anything else. And fashions can change faster than you think especially once a new generation of Mathematicians take over who are not only influenced by the older Mathematicians but who are often also excellent programmers acquiring new intuitions. To not educate them as well in constructive Mathematics reflecting these intuitions is a criminal omission.
It is certainly true, and I would also argue that the law of the excluded middle is completely embedded in "Fields Medal mathematics". The bright young mathematicians look up to the Fields Medallists, and are taught on day one that Prop = bool and hence that the law of the excluded middle is an axiom. This will be an extremely hard cycle to break. I agree that young people are more and more coming into mathematics departments with a knowledge of programming and this is what I want to tap into, but rejecting LEM would not be a suggestion which would be taken seriously by anybody in our department. In fact I do not know of a mathematics department anywhere in the world where undergraduates are not told that LEM is true right from the start, and most lecturers. It would be interesting to find examples of International Mathematical Olympiad questions which would be unsolvable without LEM.
Kevin
On Mon, 6 Jan 2020 at 09:40, Bas Spitters <b.a.w.spitters AT gmail.com> wrote:
This message and any attachment are intended solely for the addressee and may contain confidential information. If you have received this message in error, please contact the sender and delete the email and attachment. Any views or opinions expressed by the author of this email do not necessarily reflect the views of the University of Nottingham. Email communications with the University of Nottingham may be monitored where permitted by law. |
- [Coq-Club] Fwd: "Lean is like Coq but better", (continued)
- [Coq-Club] Fwd: "Lean is like Coq but better", Kevin Buzzard, 01/02/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Gaëtan Gilbert, 01/03/2020
- Message not available
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Ramkumar Ramachandra, 01/04/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Bas Spitters, 01/06/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Kevin Buzzard, 01/06/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Conor McBride, 01/06/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Stefan Monnier, 01/06/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Xuanrui Qi, 01/07/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Bas Spitters, 01/07/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Thorsten Altenkirch, 01/07/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Ramkumar Ramachandra, 01/07/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", jonikelee AT gmail.com, 01/08/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Mario Carneiro, 01/08/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Jason Gross, 01/08/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Sylvain Boulmé, 01/08/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Ramkumar Ramachandra, 01/08/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Kevin Buzzard, 01/09/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Florent Hivert, 01/09/2020
