coq-club - Re: [Coq-Club] Fwd: "Lean is like Coq but better"
  • From: Sylvain Boulmé <Sylvain.Boulme AT univ-grenoble-alpes.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Fwd: "Lean is like Coq but better"
  • Date: Wed, 8 Jan 2020 09:42:12 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=Pass smtp.mailfrom=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=None smtp.helo=postmaster AT zm-mta-out-2.u-ga.fr
Hello,
Le 08/01/2020 à 02:50,
jonikelee AT gmail.com
a écrit :
[decloaking from lurker mode to add my $0.02]
Does having LEM built into Lean interfere with the user's ability to exploit
the Curry-Howard isomorphism?
If so, that seems like a bad trade off: a small convenience for a
small group of people (Fields Medal wanabees) that imposes a large
inconvenience for a large group of people (software engineers).
Actually, I guess that a classical interpretation of "Prop" is compatible with *many* certified software development in Coq. For example, consider the CompCert compiler: currently, it is intented to be used through Coq extraction, and since the current Coq extraction removes Prop contents, it is consistent with proof-irrelevance and classical propositions.
Thus, as I understand it, supporting non-classical propositions is motivated by higher-order mathematics or by programming on propositions in the proof assistant... Hence, the picture is quite the opposite: currently, most people using maths (including software engineers) do not care of constructive propositions, and simply use classical logic, because it is convenient.
But, this does not mean that proof assistants should only care about the majority. For example, it would be great to have an enhanced Coq extraction, able to deal with an univalent version of equality (this would provide a powerful mechanism of "coercion"). Is there any progress in this direction ?
Sylvain.
