coq-club - Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}
  • Date: Fri, 21 Feb 2020 21:00:59 -0600
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-ed1-f46.google.com
  • Ironport-phdr: 9a23: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
> What is the intuition behind this?
The intuition is that all indexed types are isomorphic to corresponding parametric types that use proofs of equality in the constructors.  So
Inductive B : Type -> Type :=
| bar : B nat.
is equivalent to
Inductive B2 (T : Type) : Type :=
| bar2 : T = nat -> B2 T.
This equivalence should be quite straightforward, unless I'm imagining things incorrectly.  But then the image of [bar] under this isomorphism is [@bar2 nat refl].  So now we need to ask what the equality type here is.  Well, this should be the same as asking about the loop space based at (nat; refl) in the sigma type { T : Type | T = nat }, because this is the data the constructor carries.  I don't quite have all the details of this part of the proof worked out in my head, so it's about to get more hand-wavy.  My intuition here is that certainly from any loop based at (nat; refl), we can project out a loop nat=nat.  The question that now remains is whether we can go back the other way: can we turn a loop based at nat into a loop based at (nat; refl).  I have conflicting intuitions about this.  My initial intuition was that we could.  But now I'm thinking that maybe we can't, because { T : Type | T = nat } is contractible, so we shouldn't be about to find any higher structure here.
So it looks like I was actually wrong, initially, and perhaps this gives you the sort of structure/proof you were wanting?
On Fri, Feb 21, 2020, 13:20 Talia Ringer <tringer AT cs.washington.edu> wrote:
Interesting feedback. Does anyone have any examples that don't use SSReflect? I am really not used to SSReflect, and I find it hard to understand what is happening in proofs written in that style.
Is there a useful induction principle for { l : list T & length l = n } that people use in general? For example if you'd like to write your list functions and proofs separately from the invariants about their lengths and proofs about those invariants. Is there an easy way to glue them together in general? Could I define this as a single induction principle, something that takes separately a proof about lists and a proof about its lengths?
It should be pretty easy to show that the equality type [bar = bar] is isomorphic to the equality type [nat = nat], which is nontrivial if you assume univalence.  Does this help?
Interesting, so the type of your index really matters, not just the structure? What is the intuition behind this? It's just weird to me because I could define another type:
Inductive C : unit -> Type :=
| baz : C tt.
and then you could define indexer functions between B and C that let you prove an equivalence between B and C at those indices. It should be very easy to work over equalities between C (because all proofs of unit are equal to each other). What happens when you transport those equalities to proofs about equalities between B?
Talia
On Fri, Feb 21, 2020 at 9:04 AM Valentin Robert <valentin.robert.42 AT gmail.com> wrote:
Very nice, indeed fixing `n`, unlike in the more general `Vector.caseS`, makes the problems I had go away!
- Valentin
On Fri, 21 Feb 2020 at 17:34, Daniel Schepler <dschepler AT gmail.com> wrote:
On Fri, Feb 21, 2020 at 2:42 AM Valentin Robert
> Or I have to painfully roll my own inversion:
> Goal forall T (P : Vector.t T 2 -> Type) v, P v.
>   move => T P v.
>   pose goal :=
>       fun n v =>
>         match n as n' return Vector.t T n' -> Type with
>         | 2 => P
>         | _ => fun _ => True
>         end v
What if instead, you rolled the basic vectorS_inv and vector0_inv
once, and then used those as building blocks?  e.g.
Definition vectorS_inv {X:Type} {n:nat} :
  forall P : Vector.t X (S n) -> Type,
  (forall (h : X) (t : Vector.t X n), P (Vector.cons _ h _ t)) ->
  forall v : Vector.t X (S n), P v.
Admitted.
Definition vector0_inv {X:Type} :
  forall P : Vector.t X O -> Type,
  P (Vector.nil _) -> forall v : Vector.t X O, P v.
Admitted.
Goal forall {X:Type} (P : Vector.t X 2 -> Type),
  (forall a b : X, P (Vector.cons _ a _ (Vector.cons _ b _ (Vector.nil _)))) ->
  forall v : Vector.t X 2, P v.
intros X P f v. destruct v as [a0 v'] using @vectorS_inv.
destruct v' as [b0 v''] using @vectorS_inv.
inversion v'' using @vector0_inv. apply f.
Defined.
Daniel Schepler
