- To: Jason Gross <jasongross9 AT gmail.com>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}
- Date: Sat, 22 Feb 2020 22:25:04 +0100
Hi,
That's an interesting question!
I think that Jason's initial intuition was actually right. All of
[B nat], [B2 nat] and [nat = nat] are easily shown equivalent in
CIC. And, by relying on a univalent model, they cannot be proved
equivalent to Talia's type [C tt] which is on the contrary equivalent
to [unit] (thanks to eta for unit as well as, indeed, that all proofs
of eta for unit are equal -- this is required since Coq has no
definitional eta for unit yet).
My own interpretation of what happens is that the image of [bar]
through the isomorphism between [B nat] and [B2 nat] is not just
[bar2 nat eq_refl] but [bar2 nat eq_refl] composed with a proof of
[nat=nat] (since the elimination from [B X] to [B2 X] tacitly includes
a coercion from [X] to [nat] for the [bar] case).
Best,
Hugo
On Fri, Feb 21, 2020 at 09:00:59PM -0600, Jason Gross wrote:
> > What is the intuition behind this?
> The intuition is that all indexed types are isomorphic to corresponding
> parametric types that use proofs of equality in the constructors. So
> Inductive B : Type -> Type :=
> | bar : B nat.
> is equivalent to
> Inductive B2 (T : Type) : Type :=
> | bar2 : T = nat -> B2 T.
> This equivalence should be quite straightforward, unless I'm imagining
> things
> incorrectly. But then the image of [bar] under this isomorphism is [@bar2
> nat
> refl]. So now we need to ask what the equality type here is. Well, this
> should be the same as asking about the loop space based at (nat; refl) in
> the
> sigma type { T : Type | T = nat }, because this is the data the constructor
> carries. I don't quite have all the details of this part of the proof
> worked
> out in my head, so it's about to get more hand-wavy. My intuition here is
> that
> certainly from any loop based at (nat; refl), we can project out a loop nat=
> nat. The question that now remains is whether we can go back the other way:
> can we turn a loop based at nat into a loop based at (nat; refl). I have
> conflicting intuitions about this. My initial intuition was that we could.
> But now I'm thinking that maybe we can't, because { T : Type | T = nat } is
> contractible, so we shouldn't be about to find any higher structure here.
> So it looks like I was actually wrong, initially, and perhaps this gives you
> the sort of structure/proof you were wanting?
> On Fri, Feb 21, 2020, 13:20 Talia Ringer
> <tringer AT cs.washington.edu>
> wrote:
> Interesting feedback. Does anyone have any examples that don't use
> SSReflect? I am really not used to SSReflect, and I find it hard to
> understand what is happening in proofs written in that style.
> Is there a useful induction principle for { l : list T & length l = n }
> that people use in general? For example if you'd like to write your list
> functions and proofs separately from the invariants about their lengths
> and
> proofs about those invariants. Is there an easy way to glue them
> together
> in general? Could I define this as a single induction principle,
> something
> that takes separately a proof about lists and a proof about its lengths?
> It should be pretty easy to show that the equality type [bar = bar]
> is
> isomorphic to the equality type [nat = nat], which is nontrivial if
> you
> assume univalence. Does this help?
> Interesting, so the type of your index really matters, not just the
> structure? What is the intuition behind this? It's just weird to me
> because
> I could define another type:
> Inductive C : unit -> Type :=
> | baz : C tt.
> and then you could define indexer functions between B and C that let you
> prove an equivalence between B and C at those indices. It should be very
> easy to work over equalities between C (because all proofs of unit are
> equal to each other). What happens when you transport those equalities
> to
> proofs about equalities between B?
> Talia
> On Fri, Feb 21, 2020 at 9:04 AM Valentin Robert <
> valentin.robert.42 AT gmail.com>
> wrote:
> Very nice, indeed fixing `n`, unlike in the more general
> `Vector.caseS
> `, makes the problems I had go away!
> - Valentin
> On Fri, 21 Feb 2020 at 17:34, Daniel Schepler
> <dschepler AT gmail.com>
> wrote:
> On Fri, Feb 21, 2020 at 2:42 AM Valentin Robert
> <valentin.robert.42 AT gmail.com>
> wrote:
> > Or I have to painfully roll my own inversion:
> > Goal forall T (P : Vector.t T 2 -> Type) v, P v.
> > move => T P v.
> > pose goal :=
> > fun n v =>
> > match n as n' return Vector.t T n' -> Type with
> > | 2 => P
> > | _ => fun _ => True
> > end v
> What if instead, you rolled the basic vectorS_inv and
> vector0_inv
> once, and then used those as building blocks? e.g.
> Definition vectorS_inv {X:Type} {n:nat} :
> forall P : Vector.t X (S n) -> Type,
> (forall (h : X) (t : Vector.t X n), P (Vector.cons _ h _ t))
> forall v : Vector.t X (S n), P v.
> Admitted.
> Definition vector0_inv {X:Type} :
> forall P : Vector.t X O -> Type,
> P (Vector.nil _) -> forall v : Vector.t X O, P v.
> Admitted.
> Goal forall {X:Type} (P : Vector.t X 2 -> Type),
> (forall a b : X, P (Vector.cons _ a _ (Vector.cons _ b _
> (Vector.nil _)))) ->
> forall v : Vector.t X 2, P v.
> intros X P f v. destruct v as [a0 v'] using @vectorS_inv.
> destruct v' as [b0 v''] using @vectorS_inv.
> inversion v'' using @vector0_inv. apply f.
> Defined.
> Daniel Schepler
Hi,
I think that your intuition was right. All of "B nat", "B2 nat" and
"nat = nat" are equivalent.
What seems wrong below is that the image of [bar] is not just
of [nat=nat] (since the elimination from [B X] to [B2 X] includes
a coercion from [X] to [nat]).
Hugo
- [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Talia Ringer, 02/21/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Jason Gross, 02/21/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Valentin Robert, 02/21/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Daniel Schepler, 02/21/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Talia Ringer, 02/21/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Dominique Larchey-Wendling, 02/21/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Emilio Jesús Gallego Arias, 02/22/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Jason Gross, 02/22/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Hugo Herbelin, 02/22/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Arthur Azevedo de Amorim, 02/22/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Talia Ringer, 02/23/2020
