- From: Arthur Azevedo de Amorim <arthur.aa AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>, Jason Gross <jasongross9 AT gmail.com>
- Subject: Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}
- Date: Sat, 22 Feb 2020 16:43:09 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=arthur.aa AT gmail.com; spf=Pass smtp.mailfrom=arthur.aa AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt1-f170.google.com
- Ironport-phdr: 9a23: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
Actually the type [bar = bar] is isomorphic to the type [eq_refl nat =
eq_refl nat].
On Sat, Feb 22, 2020 at 4:25 PM Hugo Herbelin
<Hugo.Herbelin AT inria.fr>
wrote:
> Hi,
> That's an interesting question!
> I think that Jason's initial intuition was actually right. All of
> [B nat], [B2 nat] and [nat = nat] are easily shown equivalent in
> CIC. And, by relying on a univalent model, they cannot be proved
> equivalent to Talia's type [C tt] which is on the contrary equivalent
> to [unit] (thanks to eta for unit as well as, indeed, that all proofs
> of eta for unit are equal -- this is required since Coq has no
> definitional eta for unit yet).
> My own interpretation of what happens is that the image of [bar]
> through the isomorphism between [B nat] and [B2 nat] is not just
> [bar2 nat eq_refl] but [bar2 nat eq_refl] composed with a proof of
> [nat=nat] (since the elimination from [B X] to [B2 X] tacitly includes
> a coercion from [X] to [nat] for the [bar] case).
> Best,
> Hugo
> On Fri, Feb 21, 2020 at 09:00:59PM -0600, Jason Gross wrote:
> > > What is the intuition behind this?
> > The intuition is that all indexed types are isomorphic to corresponding
> > parametric types that use proofs of equality in the constructors. So
> > Inductive B : Type -> Type :=
> > | bar : B nat.
> > is equivalent to
> > Inductive B2 (T : Type) : Type :=
> > | bar2 : T = nat -> B2 T.
> > This equivalence should be quite straightforward, unless I'm imagining
> > things
> > incorrectly. But then the image of [bar] under this isomorphism is [@bar2
> > nat
> > refl]. So now we need to ask what the equality type here is. Well, this
> > should be the same as asking about the loop space based at (nat; refl) in
> > the
> > sigma type { T : Type | T = nat }, because this is the data the
> > constructor
> > carries. I don't quite have all the details of this part of the proof
> > worked
> > out in my head, so it's about to get more hand-wavy. My intuition here
> > is that
> > certainly from any loop based at (nat; refl), we can project out a loop
> > nat=
> > nat. The question that now remains is whether we can go back the other
> > way:
> > can we turn a loop based at nat into a loop based at (nat; refl). I have
> > conflicting intuitions about this. My initial intuition was that we
> > could.
> > But now I'm thinking that maybe we can't, because { T : Type | T = nat }
> > is
> > contractible, so we shouldn't be about to find any higher structure here.
> > So it looks like I was actually wrong, initially, and perhaps this gives
> > you
> > the sort of structure/proof you were wanting?
> > On Fri, Feb 21, 2020, 13:20 Talia Ringer
> > <tringer AT cs.washington.edu>
> > wrote:
> > Interesting feedback. Does anyone have any examples that don't use
> > SSReflect? I am really not used to SSReflect, and I find it hard to
> > understand what is happening in proofs written in that style.
> > Is there a useful induction principle for { l : list T & length l = n
> > that people use in general? For example if you'd like to write your
> > list
> > functions and proofs separately from the invariants about their
> > lengths and
> > proofs about those invariants. Is there an easy way to glue them
> > together
> > in general? Could I define this as a single induction principle,
> > something
> > that takes separately a proof about lists and a proof about its
> > lengths?
> > It should be pretty easy to show that the equality type [bar =
> > bar] is
> > isomorphic to the equality type [nat = nat], which is nontrivial
> > if you
> > assume univalence. Does this help?
> > Interesting, so the type of your index really matters, not just the
> > structure? What is the intuition behind this? It's just weird to me
> > because
> > I could define another type:
> > Inductive C : unit -> Type :=
> > | baz : C tt.
> > and then you could define indexer functions between B and C that let
> > you
> > prove an equivalence between B and C at those indices. It should be
> > very
> > easy to work over equalities between C (because all proofs of unit are
> > equal to each other). What happens when you transport those
> > equalities to
> > proofs about equalities between B?
> > Talia
> > On Fri, Feb 21, 2020 at 9:04 AM Valentin Robert <
> > valentin.robert.42 AT gmail.com>
> > wrote:
> > Very nice, indeed fixing `n`, unlike in the more general
> > `Vector.caseS
> > `, makes the problems I had go away!
> > - Valentin
> > On Fri, 21 Feb 2020 at 17:34, Daniel Schepler
> > <dschepler AT gmail.com>
> > wrote:
> > On Fri, Feb 21, 2020 at 2:42 AM Valentin Robert
> > <valentin.robert.42 AT gmail.com>
> > wrote:
> > > Or I have to painfully roll my own inversion:
> > > Goal forall T (P : Vector.t T 2 -> Type) v, P v.
> > > move => T P v.
> > > pose goal :=
> > > fun n v =>
> > > match n as n' return Vector.t T n' -> Type with
> > > | 2 => P
> > > | _ => fun _ => True
> > > end v
> > What if instead, you rolled the basic vectorS_inv and
> > vector0_inv
> > once, and then used those as building blocks? e.g.
> > Definition vectorS_inv {X:Type} {n:nat} :
> > forall P : Vector.t X (S n) -> Type,
> > (forall (h : X) (t : Vector.t X n), P (Vector.cons _ h _
> > t)) ->
> > forall v : Vector.t X (S n), P v.
> > Admitted.
> > Definition vector0_inv {X:Type} :
> > forall P : Vector.t X O -> Type,
> > P (Vector.nil _) -> forall v : Vector.t X O, P v.
> > Admitted.
> > Goal forall {X:Type} (P : Vector.t X 2 -> Type),
> > (forall a b : X, P (Vector.cons _ a _ (Vector.cons _ b _
> > (Vector.nil _)))) ->
> > forall v : Vector.t X 2, P v.
> > intros X P f v. destruct v as [a0 v'] using @vectorS_inv.
> > destruct v' as [b0 v''] using @vectorS_inv.
> > inversion v'' using @vector0_inv. apply f.
> > Defined.
> > Daniel Schepler
From mathcomp Require Import all_ssreflect. Inductive B : Type -> Type := bar : B nat. Definition eq_of_B T (b : B T) : nat = T :> Type := match b with bar => erefl end. Definition B_of_eq T (e : nat = T :> Type) : B T := match e with erefl => bar end. Definition B_of_eqK T : cancel (@B_of_eq T) (@eq_of_B T) := fun e => match e return eq_of_B _ (B_of_eq _ e) = e with erefl => erefl end. Definition eq_of_BK T : cancel (@eq_of_B T) (@B_of_eq T) := fun e => match e return B_of_eq _ (eq_of_B _ e) = e with bar => erefl end. Definition B_of_eq2 (e : @erefl Type nat = erefl) : bar = bar := congr1 (B_of_eq nat) e. Definition eq_of_B2 (e : bar = bar) : @erefl Type nat = erefl := congr1 (eq_of_B nat) e. Lemma congr1_ext T S (f g : T -> S) (efg : f =1 g) (x y : T) (exy : x = y) : congr1 f exy = etrans (efg x) (etrans (congr1 g exy) (esym (efg y))). Proof. by case: y / exy=> /=; case: (g x) / (efg x). Qed. Definition congr1D (T S R : Type) (g : S -> R) (f : T -> S) (x y : T) (e : x = y) : congr1 g (congr1 f e) = congr1 (g \o f) e := match e with erefl => erefl end. Definition congr11 T (x y : T) (e : x = y) : congr1 id e = e := match e with erefl => erefl end. Definition etrans1e T (x y : T) (e : x = y) : etrans erefl e = e := match e with erefl => erefl end. Lemma B_of_eq2K : cancel B_of_eq2 eq_of_B2. Proof. move=> e. rewrite /eq_of_B2 /B_of_eq2. rewrite (congr1D _ _ _ (eq_of_B nat) (B_of_eq nat) _ _ e). by rewrite (congr1_ext _ _ _ id (B_of_eqK nat)) /= congr11 etrans1e. Qed. Lemma eq_of_B2K : cancel eq_of_B2 B_of_eq2. Proof. move=> e. rewrite /eq_of_B2 /B_of_eq2. rewrite (congr1D _ _ _ (B_of_eq nat) (eq_of_B nat) _ _ e). by rewrite (congr1_ext _ _ _ id (eq_of_BK nat)) /= congr11 etrans1e. Qed.
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, (continued)
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Jason Gross, 02/21/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Valentin Robert, 02/21/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Daniel Schepler, 02/21/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Talia Ringer, 02/21/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Dominique Larchey-Wendling, 02/21/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Emilio Jesús Gallego Arias, 02/22/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Jason Gross, 02/22/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Hugo Herbelin, 02/22/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Arthur Azevedo de Amorim, 02/22/2020
- Re: [Coq-Club] Ideal eliminator for { l : list T & length l = n}, Talia Ringer, 02/23/2020
