- From: Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>
- To: coq-club AT inria.fr, Thorsten Altenkirch <Thorsten.Altenkirch AT nottingham.ac.uk>, agda-list <agda AT lists.chalmers.se>, "coq+miscellaneous AT discoursemail.com" <coq+miscellaneous AT discoursemail.com>, lean-user <lean-user AT googlegroups.com>
- Subject: Re: [Coq-Club] Why dependent type theory?
- Date: Wed, 4 Mar 2020 11:39:14 +0100
- Autocrypt: addr=pierre-marie.pedrot AT inria.fr; prefer-encrypt=mutual; keydata= mQINBFOFpSQBEACyDotTWHydRK+7nzdk+ULrBszrG8Eu7J59+eogMOIOQYKw/joFiTOHnJgG vUzt//PqMURC7tZ72teZHeyLKHwr3a9oOC4W36Wrt4jVGvAnYk60hF20i921ljIN8aj41UYz t+8vgsqgpTCNbcgxhhgXSQ+9n/OZs1yoy6kgIE378HsIhGoGTQxmwdz2k0Aic/qun2Z4CO9v zjTjkUYMJxs4XwVsprMkO/a6qVBkNtEjbwVDJS5d7qzfph2DHJXFyUOPc1GudPI+VW2Abi4A 2US/ycyGMUTYRVaUDUF/GqfqmYgUj4vFvANdB3Roa3XDVxAlkYcNuUqtcpQi9yoU6t+Agobp nqcn+WrtOwrJtvEh3KaaQvI4Yudz3pEmP9KL2VYenUQLuDqVL4KgdCPcAZmpkSC7KCm8Ns2v y69zHasNsPD9YiIXCgpGNZEEUjrG8Si+ej3/3MTqTBQqpSzqTagtGhGANrjEgHj6zdh+plby k/bCYHjX4oDPJZQx6GjmtGPandUAD+SImEwS6WMyCKtUSKJtqD+DVNWiwKAK3+CNxDW/DbRS /N2ACdtItJhFmPAb9Nxs6O27xyPCse4n9fMCT5pLQpDfMmkOQsjr1kCWiOWgjIgfOG64HrxQ Vcjg6mf9EEGVi4kpMhl6RzZ7wsg+ff3w/5NR1e1HX9yj/UbsLwARAQABtDNQaWVycmUtTWFy aWUgUMOpZHJvdCA8cGllcnJlLW1hcmllLnBlZHJvdEBpbnJpYS5mcj6JAj4EEwECACgFAlOF pSQCGwMFCRLMAwAGCwkIBwMCBhUIAgkKCwQWAgMBAh4BAheAAAoJEHkiwB/Zujx745sP/3JA gDdlat/mjqxgpC30Jy5Rnkgblxo/qnEmmhPxSQJKt77JaaDgRfsTrJZcO1K9LN6aLs8dPo26 V29TSt0UJhw5bQcTqi/wlD/ZfQ3I69gn9x6ln3T/7TV/g0tyObbzPYQLsi6p8wgJzO1F3Dr2 9XjEfB2jVs7ancTKbE+5yvwN0v3VCrtG5cFpAdkrMtZzXbXMAxRa7HueUjtxm/ls5zqbwTZ6 1tmJlSJJS+rL43InCxDFRbPO4YzV3z7+sEw/Kpn3HwVQz6y3aDQWqQlq/vF8r0p+3E3CB+h/ h6coMySbpwHZAAMsu9KpQBqGpbAjI5RXvcNJD+7MCqT5LYy/QmULqVaLS7zaspcZc2V2CW1w 4LaZtlMjt4gedGvd/UICuy1pw1GdR3YRlUCQGKnzVp8Cw1Bsd1SbZu0DT/DOt3DHyZLliENu P6PRPQT+Rmj21mDpj+bLJliIpRWQ99/cFA6mmKv7qYk49xWsUL0YxcGabGIObBbMpFoq+Coj 8Gmm10706NrJuhYJMxdxHQNbiV8eYnC6jKnL0F3BPeEloSpw0saq/8PVU7eTwvkrOBTVfiwa UFe7HLFDo6SaRoXJAeBa22ADM4bTQCrf856BMT/4BjHdSUAj4Sq1j1QUHVTWWRVsnNH8Nz10 /n2x8sxQIf8yVX4aN/Km/uz7Xq14hL6suQINBFOFpSQBEADMsZKO9fPtbmyMlS5YQl3B+p5E 17sEJAHSNGA4rfx7Uxij1H1PnTZ0kHhngrhEG1wzv2+1aORCg31Jqrwf//XPbcv6QL4CinD7 QUpbMdrZFo296AkAjuhO8J0LvB8CY3GY6n/G3njy9ISmemEH3dAzOM87Wt0En1dcSYJxdfM2 fmWq6ghlmcQA6A6g1vJ0iKnFcvh/IXHBm1/dtVSOj+2+S4/PLALMCUzugFQLVAKiv7pkdxPz KGxMMEnQuLXjoFivXV6i3q9+0FVVo2t9LfD1EzTNoKwx4866nVnVMU9myd6IS03lKAREmHhb YRKJt+dlmJoqttVczsruFa1SRmzhpp5O2jFWzR0C+SD23s70PXaZ4wcn4TzQKL+tGMRqELLF XepqWcmKnROvX+agmeZK1UxhaIGI0JpPtZHsNGNoU1dbzUE+opzHP5Lpouc5Te+MkXe4wSM6 WrfyTRqUfVr7CeaSozkX/AfgubNnNYmi8RduUjUBjukMEsRchirbyCh1397xK90HDpiiqPy/ PLaUx/sp2vp0TSxGPFtl9CmuSOPVi0HQI51SrnckMA/zQJu6AZyFkbb7fpUi/cPds7AVCLjd mNkLOe77sZ+/D3YKXiHujrpncau+NaQ2SKMrqcRocAeogbd+VV3DFGRgHereAZwHD87ruHeg jEO92QRw/QARAQABiQIlBBgBAgAPBQJThaUkAhsMBQkSzAMAAAoJEHkiwB/Zujx7eSsQAJnw yYs/yiYjwzYdlmGQP1fuG0RG6DwHXZDti9etXRhjgOMvE4+TKqSeM9gXCxdGE7M2aKV+PJvi twb4FRLBOl9YwlHTiV5UIJpcbJv+zvdNSDrlqSSln1Qfqq7HJUvDwSKcY8316pVuF5Q9gknX P/gRG4O8e/fBXuSiL08cDudnkbhSm6zb+VGaewivO0FuuCX4RpYtF4EULbCKof7SSCK3/WWl roX6H3S6dNo/3cUGahj7FfTaQMwHH34P6wGWtJCh7vhaxQ5QdXjj8ZkJfcE03uo+GbF7/xmo g5wxtsFUWhs5G0P534BmahBBKsINIyExt6JYASYL/oouC9c+AOjc3bON7Ae1jeHgx3BSSUju 81x+5MrXAqrLhJ6xDsQpATL7qDcBEHBodo0xlAIgb71qeIU5gZUOw/43eJOnexDFs4VWMthJ z2ot6WdRzYEKt75nuCZqaaUEM+MvOGNZZRM3Dkbqw3Jik1X+lOjc/OgUs+Xn9oaIylA1nojO 9E31ulGmniydilLd+4Vd+WQn0ZEwy75EzDTl0Ne/j8nvLyzeYIWbt5/06mR2L87DIEXmXkAM mwfFXNzzX9gVX8m7owb4CPTf5DCDrguwNdvcPePy81w+fXM7c0Dq+5hzPvh5MRruEDOfqaZw HXQ4ZkGmhsCD6dMF2cKX+EqLjopA136U
On 04/03/2020 10:42, Thorsten Altenkirch wrote:
> To me the most important feature of Type Theory is the support of
> abstraction in Mathematics and computer science. Using types instead of
> sets means that you can hide implementation choices which is essential
> if you want to build towers of abstraction. Set theory fails here badly.
This is true, but I am also afraid that "dependent type theory" is a
regression on that point, compared to, say, ML.
Conversion is a fanciful abstraction-breaker that is a well-known source
of non-modularity in dependently-typed languages. Worse, there is not
even a proper way to abstract over it, except for monstruosities such as
Extensional Type Theory, where you throw the baby with the bathwater.
The weak type system of ML is a strength in this setting. As long as you
don't touch the interface, you can mess with the implementation and it
will still compile. (Running properly is another story.)
PMP
signature.asc
Description: OpenPGP digital signature
- Re: [Coq-Club] [Agda] Why dependent type theory?, (continued)
- Re: [Coq-Club] [Agda] Why dependent type theory?, Sylvain Boulmé, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Kevin Buzzard, 03/05/2020
- Re: [Coq-Club] [lean-user] Re: [Agda] Why dependent type theory?, Bas Spitters, 03/08/2020
- Re: [Coq-Club] Why dependent type theory?, Dominique Larchey-Wendling, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Guillaume Melquiond, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Dominique Larchey-Wendling, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Pierre Courtieu, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Jeremy Dawson, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Makarius, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Thorsten Altenkirch, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Pierre-Marie Pédrot, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Dominique Unruh, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Jeremy Avigad, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Ettore Aldrovandi, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Miguel Pagano, 03/05/2020
- Re: [Coq-Club] Why dependent type theory?, Talia Ringer, 03/05/2020
- Re: [Coq-Club] Why dependent type theory?, Josef Urban, 03/05/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, James McKinna, 03/06/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Martin Escardo, 03/06/2020
