- From: Sylvain Boulmé <Sylvain.Boulme AT univ-grenoble-alpes.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] [Agda] Why dependent type theory?
- Date: Wed, 4 Mar 2020 10:11:00 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=Pass smtp.mailfrom=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=None smtp.helo=postmaster AT zm-mta-out-3.u-ga.fr
Hello,
My short answer: dependent type theory is a good compromise to formalize "informal reasonings in naive set-theory" with a computer. Because it combines two key-features:
- types are values: you can compute on types and for example, define a family of types indexed by naturals.
- typechecking remains decidable.
If you compare this to untyped set theory (like promoted by Lamport), then membership in set-theory is undecidable, and I do not know whether there is a clear notion of computation in the logic...
Regards,
Sylvain.
Le 03/03/2020 à 23:45, Martin Escardo a écrit :
Dependent types are good for pure mathematics (classical or constructive). They are the natural home to define group, ring, metric space, topological space, poset, lattice, category, etc, and study them. Mathematicians that use(d) dependent types include Voevodsky (in Coq) and Kevin Buzzard (in Lean), among others. Kevin and his team defined, in particular, perfectoid spaces in dependent type theory. Martin
On 03/03/2020 19:43,
jasongross9 AT gmail.com
wrote:
I'm in the process of writing my thesis on proof assistant performance bottlenecks (with a focus on Coq), and there's a large class of performance bottlenecks that come from (mis)using the power of dependent types. So in writing the introduction, I want to provide some justification for the design decision of using dependent types, rather than, say, set theory or classical logic (as in, e.g., Isabelle/HOL). And the only reasons I can come up with are "it's fun" and "lots of people do it"
So I'm asking these mailing lists: why do we base proof assistants on dependent type theory? What are the trade-offs involved?
I'm interested both in explanations and arguments given on list, as well as in references to papers that discuss these sorts of choices.
Thanks,
Jason
_______________________________________________
Agda mailing list
Agda AT lists.chalmers.se
https://lists.chalmers.se/mailman/listinfo/agda
Lors de son assemblée générale annuelle le 13/02/2020, le laboratoire Verimag a décidé, à l'unanimité des présents, de soutenir la motion du CPCN du CNRS sur les "dispositions attendues de la LPPR" du 17 janvier 2020 (http://www.c3n-cn.fr/attendusLPPR) et de demander:
- la création massive d'emplois statutaires dans l'ESR pour résorber la précarité galopante de ces dernières décennies;
- une augmentation forte des crédits de base des laboratoires pour leur permettre de faire de la recherche scientifique plutôt que de la recherche de financement;
- le retrait du projet de réforme des retraites, qui met en péril le principe de solidarité entre générations par l'incertitude sur le niveau des pensions.
- Re: [Coq-Club] Why dependent type theory?, (continued)
- Re: [Coq-Club] Why dependent type theory?, Jesper Cockx, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Ralf Jung, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Christian Doczkal, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Ken Kubota, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, jonikelee AT gmail.com, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Daniel Schepler, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, mechvel, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Steven Shaw, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Martin Escardo, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Sylvain Boulmé, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Kevin Buzzard, 03/05/2020
- Re: [Coq-Club] [lean-user] Re: [Agda] Why dependent type theory?, Bas Spitters, 03/08/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Thorsten Altenkirch, 03/12/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Mario Carneiro, 03/13/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Kevin Buzzard, 03/13/2020
- Message not available
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Bas Spitters, 03/17/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Thorsten Altenkirch, 03/18/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Stefan Monnier, 03/15/2020
- Re: [Coq-Club] Why dependent type theory?, Guillaume Melquiond, 03/04/2020
