- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>, agda-list <agda AT lists.chalmers.se>, Coq Discourse <coq+miscellaneous AT discoursemail.com>
- Subject: Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?
- Date: Wed, 04 Mar 2020 20:07:41 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mechvel AT scico.botik.ru; spf=Pass smtp.mailfrom=mechvel AT scico.botik.ru; spf=None smtp.helo=postmaster AT mail.botik.ru
- Ironport-phdr: 9a23:AJ6HBxLtlHAKK8WdDNmcpTZWNBhigK39O0sv0rFitYgRI/7xwZ3uMQTl6Ol3ixeRBMOHsq4C0rKG+PG9EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i764jEdAAjwOhRoLerpBIHSk9631+ev8JHPfglEnjWwba59IRmssAndqsobjYRmJ6sx1xDEvmZGd+NKyGxnIl6egwzy7dqq8p559CRQtfMh98peXqj/Yq81U79WAik4Pm4s/MHkugXNQgWJ5nsHT2UZiQFIDBTf7BH7RZj+rC33vfdg1SaAPM32Sbc0WSm+76puVRTlhjsLOyI//WrKkcF7kr5Vrwy9qBx+247UYZ+aNPxifqPGYNgWQXNNUttNWyBdB4+xaZYEAegcMuZCt4TyqEcBoxSwCwesGu3h1z1HhnH106w13essCh3G0Q4iH94SrHjZtsv5OaEPWu611qnIyjDDYutT2Tjj9IfIcg4hru+IXb9rasre1UgvGB/CjlmKsoPlOC+V1uUOs2SB9epgSOSigHMppQF2pzig3MYsio/Ri40OzVDE6SR5wIUvKd2iVU52Z8OvHphItyyCM4Z7QtkuT3x2tCs+0LEKpJC2cSoQxJg6xhPSauSLfoyI7x75SeqdPzN1iGh4dL+xhRu+61Wsx+nhWsSyzV1EtDBKksPWuXAIzxHT6taISv96/kq53DaAzQHT6uVeLU8vkqrbN58hwr0qmpoJrETPBi72mEPog6+Kbkgp/uil5/76brn4opKQLZJ4hw/8P6g0h8CyAOU1PhALX2eB+OS80LPj/Vf+QLVPlvA2l7fWv4zaJcQFuKG5BxRY0p0/5Ba+Ezim184UkmIALFJZeRKHjJLlO0vTIPzgF/ewn0yskCt3x/DBJrDuHpLNLmHanLj9ebZ99lVTxREozdFf4pJUEqsOLOjyWk/3rtzYDwU2Pxa6w+b9W51B0dY8UHmIBOe2KqTJqhfc5Os0JO+DfogOo2fVJP0s5vqohng8zwwzZ66siJ4aY3CmE/BOOE6Yan2qiNAdEGRMpBdtH6TRlFSeXGsLND6JVKUm62R+Udr+VNqRdsWWmLWEmRyDMNhWa2RBUw3eFH7pc8OOXOsNa2SIP505y21WZf2aU4YkkCqWmkr/wrtjIPDT/3RG54no1dNyoefUiRAxsyZpXZ3EjzO9Clpsl2ZNfAcYmbhlqBUjmEyI0KN/xfZfCd1QoelUAF83
On 2020-03-04 14:22,
wrote:
On 2020-03-04 02:04, Jason Gross wrote:
I'm confused by this. Are you saying that in Agda typechecking is
exponential in the number of files? Or exponential in the number of
nested abstractions? Or something else? Do you have a toy example
demonstrating this behavior?
No toy example, so far, but I think such can be provided.
I have a real-world example of the DoCon-A library for algebra:
http://www.botik.ru/pub/local/Mechveliani/docon-A/2.02/
This is a small part of the intended general purpose library for algebra
(for algebra methods, it is very small, but comparing to the Agda
practice, it is large).
It is written in install.txt
"for the -M15G key (15 Gb heap) installation takes about 50 minutes on a
3 GHz personal computer.
I am sorry.
I need to add the following.
This as about the Agda versions of about 2017.
It may occur that the current Agda version improves something there.
This needs testing, needs more effort in porting the library.
I use the last Agda versions, but on certain smaller projects.
Sergei
It looks like the type checker has exponential cost in the depth of
the tree of the
introduced parametric module instances.
There is a hierarchy of "classes" (classical abstract structures):
Magma, (commutative)Semigroup, (Commutative)Monoid, (Commutative)Group, ... ,
(Commutative)Ring, Field, IntegralDomain, EuclideanDomain, GCDDomain,
LeftModuleOverARing ...
-- this tree depth may grow up to, may be, about 25.
And there are domain constructors: integer, vector, fraction,
polynomial, residueRing ...
And these constructors are provided with instances of some of the
above abstract structures.
These instances include implementation for their needed operations, with proofs.
The type checker deals with a hierarchy of such instances. And it
performs evaluation
(normalization ...) with very large terms representing these instances.
For example, the Integer domain has may be 20 instances in it, and
this large term is
substituted many times on other terms, because almost every domain
uses some features of
the Integer domain. Anyway there appear internally very large terms
that repeat many
times, and their embracing terms need to normalize.
Further, the domain
Vector (EuclideanRingResidue f (Polynomial (Fraction Integer))) (D)
is supplied with five instances of Magma, five instances of Semigroup,
five instances of CommutativeSemigroup, five instances of Monoid,
five instances of CommutativeMonoid, and also many other instances.
And the class operations in these instances (and their proofs) are implemented
each in its individual way.
The number of different instances of the classical operations grows
exponentially
in the constructor depth for the domains like (D).
I do not expect that in mathematical textbooks appear domain constructs as (D)
of the level greater than 10.
But Agda has practical difficulties with the level of about 4.
Because each construct like (D) is further substituted to different
parametric modules.
Because the method M1 uses one item from (D), so it is implemented in
the environment of
a parametric program module to which (D) is substituted for a parameter,
the method M2 uses another item from (D), and so on. And large
subterms get internally copied.
In a mathematical textbook, all these substitutions are mentioned or
presumed, and are
understood by the reader. So the informal "rigorous" proofs fit, say, 200 pages
(~ 100 Kb of memory).
But when a type checker tries to understand these constructions, it
creates many copies of large subterms and spends the cost in
normalizing them.
And formal proofs take 15 Gb memory to check.
First, this copy eagerness can probably be reduced (probably, this is
not easy to implement).
Second, something can be needed to arrange in the style of the
application programs.
There is a paper of Coq about this style, I recall A.Mahboubi is among
the authors.
So, there is a fundamental restriction -- which hopefully can be
handled by introducing a certain
programming style (I never looked into this).
And also there is probably something to fix in the type checker in Agda.
- [Coq-Club] Why dependent type theory?, Jason Gross, 03/03/2020
- Re: [Coq-Club] [lean-user] Why dependent type theory?, Colin Stebbins Gordon, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Viktor Kunčak, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Jason Gross, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Patricia Peratto, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, mechvel, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Jason Gross, 03/04/2020
- Re: [Coq-Club] [lean-user] Re: [Agda] Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, mechvel, 03/06/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, mechvel, 03/07/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Ralf Jung, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Ulf Norell, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Pierre Courtieu, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Pierre-Marie Pédrot, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Jesper Cockx, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Ralf Jung, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Jesper Cockx, 03/04/2020
