- To: coq-club AT inria.fr, Jeremy.Dawson AT anu.edu.au
- Subject: Re: [Coq-Club] _CoqProject
- Date: Sun, 26 Apr 2020 16:23:54 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=dfrumin AT cs.ru.nl; spf=Pass smtp.mailfrom=dfrumin AT cs.ru.nl; spf=Pass smtp.helo=postmaster AT smtp3.science.ru.nl
- Ironport-phdr: 9a23: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
Hi Jeremy,
I don't know why -I doesn't work, but I think using -Q does the trick (at
least with my version of Coq): I replaced
-I ../lnt/tense-logic-in-Coq/
with
-Q ../lnt/tense-logic-in-Coq/ TL
and then in dd_fc.v used `Require Import TL.genT`
Best,
Dan
On 26-04-2020 16:09, Jeremy Dawson wrote:
Hi,
I've constructed a _CoqProject file as follows
-I ../gen/
../lnt/tense-logic-in-Coq/gen.v
../lnt/tense-logic-in-Coq/genT.v
../lnt/tense-logic-in-Coq/List_lemmasT.v
../lnt/tense-logic-in-Coq/lntT.v
../lnt/tense-logic-in-Coq/swappedT.v
../lnt/tense-logic-in-Coq/ddT.v
../lnt/tense-logic-in-Coq/dd_fc.v
../lnt/tense-logic-in-Coq/lntacsT.v
../gen/rtcT.v
../gen/gstep.v
../gen/gentree.v
gen_ext.v
k4.v
k4_exch.v
k4_inv.v
k4_ctr.v
k4_ca.v
I then run
make -f Makefile
and get the following messages
COQC ../lnt/tense-logic-in-Coq/dd_fc.v
File "../lnt/tense-logic-in-Coq/dd_fc.v", line 12, characters 15-19:
Error: Unable to locate library genT.
(in fact the file
exists)
What do I need to put in the _CoqProject file to make this work?
Thanks
Jeremy
- [Coq-Club] _CoqProject, Jeremy Dawson, 04/26/2020
- Re: [Coq-Club] _CoqProject, Dan Frumin, 04/26/2020
- Re: [Coq-Club] _CoqProject, Gaëtan Gilbert, 04/26/2020
- Re: [Coq-Club] _CoqProject, Jeremy Dawson, 04/27/2020
- Re: [Coq-Club] _CoqProject, Pierre Courtieu, 04/27/2020
- Re: [Coq-Club] _CoqProject, Jeremy Dawson, 04/28/2020
- Re: [Coq-Club] _CoqProject, Christian Doczkal, 04/28/2020
- Re: [Coq-Club] _CoqProject, Benoît Viguier, 04/28/2020
- Re: [Coq-Club] _CoqProject, Gaëtan Gilbert, 04/28/2020
