- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] _CoqProject
- Date: Tue, 28 Apr 2020 11:25:10 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=beviguier AT gmail.com; spf=Pass smtp.mailfrom=beviguier AT gmail.com; spf=None smtp.helo=postmaster AT mail-wr1-f42.google.com
- Ironport-phdr: 9a23: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
Hi all,
Probably not the only way to solve the "problem" but this may be
of interest to some Coq users.
I wrote the following shell script to generate my _CoqProject:
#!/bin/sh # remove _CoqProject if it already exists [ -e _CoqProject ] && rm _CoqProject # generate the path for coqide and coqv for D in $(find * -maxdepth 1 -type d); do echo "-Q $D YOURLIB.$D" | sed 's/\//./2'>> _CoqProject done echo "" >> _CoqProject # generate the list of files for coq_makefile find * -name "*.v" -print >> _CoqProject coq_makefile INSTALLDEFAULTROOT = YOURLIB -f _CoqProject -o Makefile
So far it has been working flawlessly.
Kind Regards.
-- Benoît Viguier Software Engineer - PhD Student | Cryptography & Formal Methods Radboud University | Mercator 1, Toernooiveld 212 6525 EC Nijmegen, the Netherlands | www.viguier.nlOn 4/28/20 11:17 AM, Christian Doczkal wrote:
I think the use of "library" in the Coq context is slightly ambiguous. It can refer to a single file (as with Locate Library) or to a collection of (compiled) files sharing a common namespace. I say compiled here, because the namespace is fixed during compilation. Libraries that are set up to be used by others usually fix a namespace identifier in their Makefile and the install target then installs the library (i.e., all the compiled files) to ../coq-contrib/<namespace>. From there they can be used via "From <namespace> Require Import <lib>. In the context where you are touching files from several libraries (folders in this context) and you're not installing anything globally, the setup you describe is fine. (I actually used a setup similar to what you describe, simply ignoring the warnings) However, it may be cleaner to use a centralized build infrastructure residing in the shared top-level directory. You could try starting with a _CoqProject file containing someting along the lines of INSTALLDEFAULTROOT = mylib #silence no common root warning -R/-Q lnt/tense-logic-in-Coq -R/-Q gen -R/-Q modal plus the output of $ ls -1 lnt/tense-logic-in-Coq/*.v gen/*.v modal/*.v One advantage is that this allows make to track dependencies across the various folders and compile (in parallel) only what is necessary. (coq_makefile -h also lists an "-install none" option, but the generated Makefile in my tests still had an install target on coq-8.11.1 ...) Best, Christian On 4/28/20 8:08 AM, Jeremy Dawson wrote:
Hi Pierre, Thanks. I'm not sure what "library" means in the Coq context (and it's not in the documentation index). Locate Library seems to work for a single filename (without the v) but I'm guessing that's not what you mean. Anyway, there are 3 directories containing Coq source files, called lnt/tense-logic-in-Coq, gen and modal The one I'm most commonly making changes in, and whose Coq files depend on the other two, is modal. Can the _CoqProject file mechanism can handle this situation? It sounds from what you say that it can't. Where you say the Int directory I assume you mean lnt but going there and typing make does nothing because it does not contain a makefile. In lnt/tense-logic-in-Coq there is a Makefile but it was not produced by coq_makefile. It works nicely for compiling all the Coq files in that directory. It doesn't have a target "install" Likewise the directory gen does not have a makefile (yet). Cheers, Jeremy On 28/4/20 1:31 am, Pierre Courtieu wrote:I suppose that Int, gen, and the current directory are actually 3 different coq libraries. If this is not the case you need to tell us a bit more. If this is the case then they should not share the same _CoqProject file. 1) Go inside Int directory and type make, if it went well, then do "make install". 3) do the same in directory gen now coq knows about Int and gen without any -Q option. Write your _CoqProject by mentioning only your files. By default "make install" copies .vo files into <coq_directory>/user-contrib/<libdirectoryname>, which is searched by coq by default. Hope this helps, Pierre Le lun. 27 avr. 2020 à 16:50, Jeremy Dawson <Jeremy.Dawson AT anu.edu.au <mailto:Jeremy.Dawson AT anu.edu.au>> a écrit : Sorry, I don't understand what you are getting at. What do you mean by make *and make install* tense-logic-in-Coq ie what do I type and in what directory? What is "make install" meant to do? Thanks Jeremy On 4/28/20 12:01 AM, Pierre Courtieu wrote: > Hi > > These warnings mean that your current configuration does not allow to do > "make install" due to the lack of a main root directory. coq_makefile > does not support to install several libraries at once. However I think > you should be able to built your project without problems. > > That said if you make *and make install* tense-logic-in-Coq you could > just remove it completely from you _CoqProject file, use it in your > development and have a working "make install". > > Hope this helps, > P > > > Le lun. 27 avr. 2020 à 13:39, Jeremy Dawson <Jeremy.Dawson AT anu.edu.au <mailto:Jeremy.Dawson AT anu.edu.au> > <mailto:Jeremy.Dawson AT anu.edu.au <mailto:Jeremy.Dawson AT anu.edu.au>>> a écrit : > > Hi, > > Thanks - but this won't work because it would mean changing dd_fc.v > and all the files in that directory, which is part of other people's > work as well > > So I tried some alternatives like > -Q ../lnt/tense-logic-in-Coq/ > or > -Q ../lnt/tense-logic-in-Coq/ . > > All of these, including your suggested > -Q ../lnt/tense-logic-in-Coq/ TL > > gave a bunch or warnings, eg > > -Q ../lnt/tense-logic-in-Coq/ TL > gives > Warning: ../lnt/tense-logic-in-Coq/ (used in -R or -Q) is not a > subdirectory of the current directory > > Warning: no common logical root > Warning: in such case INSTALLDEFAULTROOT must be defined > Warning: the install-doc target is going to install files > Warning: in orphan_TL_Top > > I don't understand any of these, except the first (and I don't know > what > I should do about that), and I can't find any explanation of these in > the documentation. > > What do they all mean? > > Thanks > > Jeremy > > > On 27/4/20 12:26 am, Gaëtan Gilbert wrote: > > Indeed -I is for ocaml files (for plugins) > > > > Gaëtan Gilbert > > > > On 26/04/2020 16:23, Dan Frumin wrote: > >> Hi Jeremy, > >> > >> I don't know why -I doesn't work, but I think using -Q does the > trick > >> (at least with my version of Coq): I replaced > >> > >> -I ../lnt/tense-logic-in-Coq/ > >> > >> with > >> -Q ../lnt/tense-logic-in-Coq/ TL > >> > >> and then in dd_fc.v used `Require Import TL.genT` > >> > >> > >> > >> Best, > >> Dan > >> > >> > >> On 26-04-2020 16:09, Jeremy Dawson wrote: > >>> > >>> Hi, > >>> > >>> I've constructed a _CoqProject file as follows > >>> > >>> -I ../lnt/tense-logic-in-Coq/ > >>> -I ../gen/ > >>> ../lnt/tense-logic-in-Coq/gen.v > >>> ../lnt/tense-logic-in-Coq/genT.v > >>> ../lnt/tense-logic-in-Coq/List_lemmasT.v > >>> ../lnt/tense-logic-in-Coq/lntT.v > >>> ../lnt/tense-logic-in-Coq/swappedT.v > >>> ../lnt/tense-logic-in-Coq/ddT.v > >>> ../lnt/tense-logic-in-Coq/dd_fc.v > >>> ../lnt/tense-logic-in-Coq/lntacsT.v > >>> ../gen/rtcT.v > >>> ../gen/gstep.v > >>> ../gen/gentree.v > >>> gen_ext.v > >>> k4.v > >>> k4_exch.v > >>> k4_inv.v > >>> k4_ctr.v > >>> k4_ca.v > >>> > >>> I then run > >>> make -f Makefile > >>> and get the following messages > >>> COQC ../lnt/tense-logic-in-Coq/dd_fc.v > >>> File "../lnt/tense-logic-in-Coq/dd_fc.v", line 12, characters > 15-19: > >>> Error: Unable to locate library genT. > >>> > >>> (in fact the file > >>> ../lnt/tense-logic-in-Coq/genT.v > >>> exists) > >>> > >>> What do I need to put in the _CoqProject file to make this work? > >>> > >>> Thanks > >>> > >>> Jeremy >
- [Coq-Club] _CoqProject, Jeremy Dawson, 04/26/2020
- Re: [Coq-Club] _CoqProject, Dan Frumin, 04/26/2020
- Re: [Coq-Club] _CoqProject, Gaëtan Gilbert, 04/26/2020
- Re: [Coq-Club] _CoqProject, Jeremy Dawson, 04/27/2020
- Re: [Coq-Club] _CoqProject, Pierre Courtieu, 04/27/2020
- Re: [Coq-Club] _CoqProject, Jeremy Dawson, 04/28/2020
- Re: [Coq-Club] _CoqProject, Christian Doczkal, 04/28/2020
- Re: [Coq-Club] _CoqProject, Benoît Viguier, 04/28/2020
- Re: [Coq-Club] _CoqProject, Gaëtan Gilbert, 04/28/2020
- Re: [Coq-Club] _CoqProject, Pierre Courtieu, 04/28/2020
- Re: [Coq-Club] _CoqProject, Jason Gross, 04/28/2020
