- From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] _CoqProject
- Date: Sun, 26 Apr 2020 16:26:25 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay1-d.mail.gandi.net
- Ironport-phdr: 9a23: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
Indeed -I is for ocaml files (for plugins)
Gaëtan Gilbert
On 26/04/2020 16:23, Dan Frumin wrote:
Hi Jeremy,
I don't know why -I doesn't work, but I think using -Q does the trick (at least with my version of Coq): I replaced
-I ../lnt/tense-logic-in-Coq/
with
-Q ../lnt/tense-logic-in-Coq/ TL
and then in dd_fc.v used `Require Import TL.genT`
Best,
Dan
On 26-04-2020 16:09, Jeremy Dawson wrote:
Hi,
I've constructed a _CoqProject file as follows
-I ../gen/
../lnt/tense-logic-in-Coq/gen.v
../lnt/tense-logic-in-Coq/genT.v
../lnt/tense-logic-in-Coq/List_lemmasT.v
../lnt/tense-logic-in-Coq/lntT.v
../lnt/tense-logic-in-Coq/swappedT.v
../lnt/tense-logic-in-Coq/ddT.v
../lnt/tense-logic-in-Coq/dd_fc.v
../lnt/tense-logic-in-Coq/lntacsT.v
../gen/rtcT.v
../gen/gstep.v
../gen/gentree.v
gen_ext.v
k4.v
k4_exch.v
k4_inv.v
k4_ctr.v
k4_ca.v
I then run
make -f Makefile
and get the following messages
COQC ../lnt/tense-logic-in-Coq/dd_fc.v
File "../lnt/tense-logic-in-Coq/dd_fc.v", line 12, characters 15-19:
Error: Unable to locate library genT.
(in fact the file
exists)
What do I need to put in the _CoqProject file to make this work?
Thanks
Jeremy
- [Coq-Club] _CoqProject, Jeremy Dawson, 04/26/2020
- Re: [Coq-Club] _CoqProject, Dan Frumin, 04/26/2020
- Re: [Coq-Club] _CoqProject, Gaëtan Gilbert, 04/26/2020
- Re: [Coq-Club] _CoqProject, Jeremy Dawson, 04/27/2020
- Re: [Coq-Club] _CoqProject, Pierre Courtieu, 04/27/2020
- Re: [Coq-Club] _CoqProject, Jeremy Dawson, 04/28/2020
- Re: [Coq-Club] _CoqProject, Christian Doczkal, 04/28/2020
- Re: [Coq-Club] _CoqProject, Benoît Viguier, 04/28/2020
- Re: [Coq-Club] _CoqProject, Gaëtan Gilbert, 04/28/2020
- Re: [Coq-Club] _CoqProject, Pierre Courtieu, 04/28/2020
