[Coq-Club] Preventing pollution of typeclass resolution when Require Importing a MathClasses module
- From: Yannick Zakowski <zakowski AT seas.upenn.edu>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Preventing pollution of typeclass resolution when Require Importing a MathClasses module
- Date: Wed, 15 Jul 2020 10:32:25 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=zakowski AT seas.upenn.edu; spf=Pass smtp.mailfrom=zakowski AT seas.upenn.edu; spf=None smtp.helo=postmaster AT mail-qt1-f194.google.com
- Ironport-phdr: 9a23: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
Dear all,
Consider the following self-contained example:
From Coq Require Import
Setoid
Morphisms
RelationClasses.
Section Foo.
Variable op: nat -> nat.
Variable rel: nat -> nat -> Prop.
Context {rel_op_Proper: (Proper (rel ==> rel) op)}.
Context {rel_trans: Transitive rel}.
Goal forall (a b: nat) (REL: rel a b),
rel (op a) (op b).
Proof.
intros.
Typeclasses eauto := debug.
rewrite REL.
(* Resolution in 6 steps *)
Undo.
Require Import MathClasses.interfaces.abstract_algebra.
rewrite REL.
(* Resolution in over 100 steps *)
Abort.
End Foo.
I am looking for a way to avoid this side-effect of loading this
MathClass module.
The problem touches to the overall issues of Hints being
aggressively exported, and instances all sharing a single
namespace. A general solution would naturally be welcome, but I
would already be very happy with a hacky local solution allowing
me to get back into my proof. In this specific case, it indeed
looks to me like the main culprit that gets applied early and
completely derail the proof search is the following External Hint
declared in `abstract_algebra.v`:
Hint Extern 4 (?f _ = ?f _) => unshelve eapply (sm_proper (f:=f)).
I have given a shot at `Set Loose Hint Behavior "Strict".`
without success. For good conscience I also tried `Remove Hints
sm_proper: core_db.`, but as described in the documentation, it
does not apply to External Hints.
Any idea as to how to solve this problem would help me a great
deal.
For context, in my concrete use-case, I am proving a pass of
compilation from an existing language (Helix) to another existing
language (Vellvm) using a library (Interaction Trees).
The dependency on MathClass is transitively inherited from Helix,
but is essentially irrelevant to the proof itself.
I rewrite non-trivial relations (via the Interaction Tree library)
in fairly complex context, so that this overhead seems to become
unbearable.
I am therefore ideally really looking for a local way to prevent
this behavior, if possible without having to mess with any of the
three libraries at play.
Thanks in advance,
Best,
Yannick
P.S. : This intersects with my question on Discourse¹. I am not
sure what's the current etiquette on cross posting to try to reach
as many users as possible. Let me know if it's any issue.
¹: https://coq.discourse.group/t/preventing-pollution-of-the-instance-context-during-import/942
- [Coq-Club] Preventing pollution of typeclass resolution when Require Importing a MathClasses module, Yannick Zakowski, 07/15/2020
- Re: [Coq-Club] Preventing pollution of typeclass resolution when Require Importing a MathClasses module, Matthieu Sozeau, 07/16/2020
- Re: [Coq-Club] Preventing pollution of typeclass resolution when Require Importing a MathClasses module, Yannick Zakowski, 07/16/2020
