Re: [Coq-Club] Preventing pollution of typeclass resolution when Require Importing a MathClasses module
- From: Matthieu Sozeau <matthieu.sozeau AT inria.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Preventing pollution of typeclass resolution when Require Importing a MathClasses module
- Date: Thu, 16 Jul 2020 12:23:43 +0200
Dear Yannick,
> Le 15 juil. 2020 à 16:32, Yannick Zakowski <zakowski AT seas.upenn.edu> a
> écrit :
> Dear all,
> Consider the following self-contained example:
> From Coq Require Import
> Setoid
> Morphisms
> RelationClasses.
> Section Foo.
> Variable op: nat -> nat.
> Variable rel: nat -> nat -> Prop.
> Context {rel_op_Proper: (Proper (rel ==> rel) op)}.
> Context {rel_trans: Transitive rel}.
> Goal forall (a b: nat) (REL: rel a b),
> rel (op a) (op b).
> Proof.
> intros.
> Typeclasses eauto := debug.
> rewrite REL.
> (* Resolution in 6 steps *)
> Undo.
> Require Import MathClasses.interfaces.abstract_algebra.
> rewrite REL.
> (* Resolution in over 100 steps *)
> Abort.
> End Foo.
> I am looking for a way to avoid this side-effect of loading this MathClass
> module.
> The problem touches to the overall issues of Hints being aggressively
> exported, and instances all sharing a single namespace. A general solution
> would naturally be welcome, but I would already be very happy with a hacky
> local solution allowing me to get back into my proof. In this specific
> case, it indeed looks to me like the main culprit that gets applied early
> and completely derail the proof search is the following External Hint
> declared in `abstract_algebra.v`:
> Hint Extern 4 (?f _ = ?f _) => unshelve eapply (sm_proper (f:=f)).
> I have given a shot at `Set Loose Hint Behavior "Strict".` without success.
> For good conscience I also tried `Remove Hints sm_proper: core_db.`, but as
> described in the documentation, it does not apply to External Hints.
> Any idea as to how to solve this problem would help me a great deal.
I don’t see a way to avoid the import of instances from math-classes if you
have to Require Import.
However, the shape of the hint here might leave some hope for finding a
workaround, because generalized
rewriting itself does not generate `(_ = _)` subgoals to be solved by type
class resolution, only
`Proper R f`, `ProperProxy R f` and `subrelation R R’` goals. So you might
have more luck disabling
the hint that produces the `(_ = _)` subgoal?
Best,
— Matthieu
- [Coq-Club] Preventing pollution of typeclass resolution when Require Importing a MathClasses module, Yannick Zakowski, 07/15/2020
- Re: [Coq-Club] Preventing pollution of typeclass resolution when Require Importing a MathClasses module, Matthieu Sozeau, 07/16/2020
- Re: [Coq-Club] Preventing pollution of typeclass resolution when Require Importing a MathClasses module, Yannick Zakowski, 07/16/2020
