Re: [Coq-Club] Preventing pollution of typeclass resolution when Require Importing a MathClasses module
- From: Matthieu Sozeau <matthieu.sozeau AT inria.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Preventing pollution of typeclass resolution when Require Importing a MathClasses module
- Date: Thu, 16 Jul 2020 18:16:58 +0200
> Le 16 juil. 2020 à 15:45, Yannick Zakowski <zakowski AT seas.upenn.edu> a
> écrit :
> Hello,
> That's a sensible suggestion, unfortunately I do not quite understand why
> this hint gets applied. In the minimal example from my original message,
> the beginning of the debug trace goes as follows:
> Debug: 1: looking for (Proper (rel ==> ?r) op) with backtracking
> Debug: 1.1: exact rel_op_Proper on (Proper (rel ==> ?r) op), 0 subgoal(s)
> Debug: 2: looking for (Proper (rel ==> ?r ==> flip impl) rel) with
> backtracking
> Debug: 2.1: simple apply @sm_proper on (Proper (rel ==> ?r ==> flip impl)
> rel), 1 subgoal(s)
> Debug: 2.1-1 : (Setoid_Morphism rel)
> We are looking for a Proper instance as expected, nothing in this goal
> explicitly refers to equiv (i.e. "=" from MathClasses perspective), and yet
> `sm_proper` gets applied.
Maybe then declaring `Typeclasses Opaque equiv` will avoid this unexpected
unification. Also, it looks like this application
(`simple apply @sm_proper`) is coming from a regular hint rather than the
extern hint you mentioned (they are marked with
*external* in the traces).
— Matthieu
> Yannick
> On 7/16/20 6:23 AM, Matthieu Sozeau wrote:
>> Dear Yannick,
>>> Le 15 juil. 2020 à 16:32, Yannick Zakowski <zakowski AT seas.upenn.edu>
>>> a écrit :
>>> Dear all,
>>> Consider the following self-contained example:
>>> From Coq Require Import
>>> Setoid
>>> Morphisms
>>> RelationClasses.
>>> Section Foo.
>>> Variable op: nat -> nat.
>>> Variable rel: nat -> nat -> Prop.
>>> Context {rel_op_Proper: (Proper (rel ==> rel) op)}.
>>> Context {rel_trans: Transitive rel}.
>>> Goal forall (a b: nat) (REL: rel a b),
>>> rel (op a) (op b).
>>> Proof.
>>> intros.
>>> Typeclasses eauto := debug.
>>> rewrite REL.
>>> (* Resolution in 6 steps *)
>>> Undo.
>>> Require Import MathClasses.interfaces.abstract_algebra.
>>> rewrite REL.
>>> (* Resolution in over 100 steps *)
>>> Abort.
>>> End Foo.
>>> I am looking for a way to avoid this side-effect of loading this
>>> MathClass module.
>>> The problem touches to the overall issues of Hints being aggressively
>>> exported, and instances all sharing a single namespace. A general
>>> solution would naturally be welcome, but I would already be very happy
>>> with a hacky local solution allowing me to get back into my proof. In
>>> this specific case, it indeed looks to me like the main culprit that gets
>>> applied early and completely derail the proof search is the following
>>> External Hint declared in `abstract_algebra.v`:
>>> Hint Extern 4 (?f _ = ?f _) => unshelve eapply (sm_proper (f:=f)).
>>> I have given a shot at `Set Loose Hint Behavior "Strict".` without
>>> success. For good conscience I also tried `Remove Hints sm_proper:
>>> core_db.`, but as described in the documentation, it does not apply to
>>> External Hints.
>>> Any idea as to how to solve this problem would help me a great deal.
>> I don’t see a way to avoid the import of instances from math-classes if
>> you have to Require Import.
>> However, the shape of the hint here might leave some hope for finding a
>> workaround, because generalized
>> rewriting itself does not generate `(_ = _)` subgoals to be solved by type
>> class resolution, only
>> `Proper R f`, `ProperProxy R f` and `subrelation R R’` goals. So you might
>> have more luck disabling
>> the hint that produces the `(_ = _)` subgoal?
>> Best,
>> — Matthieu
- [Coq-Club] Preventing pollution of typeclass resolution when Require Importing a MathClasses module, Yannick Zakowski, 07/15/2020
- Re: [Coq-Club] Preventing pollution of typeclass resolution when Require Importing a MathClasses module, Matthieu Sozeau, 07/16/2020
- Re: [Coq-Club] Preventing pollution of typeclass resolution when Require Importing a MathClasses module, Yannick Zakowski, 07/16/2020
