coq-club - Re: [Coq-Club] Is this provable? (I'll give you credit and beer/dessert)
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Is this provable? (I'll give you credit and beer/dessert)
  • Date: Sat, 10 Oct 2020 09:52:41 -0500
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-ed1-f52.google.com
  • Ironport-phdr: 9a23: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
I have not yet looked at Gaëtan's proof, but here is the intuition:
What you have is a sort of incoherent equivalence. What would make
your proof easier is having some version of [section] such that
[forall a, f_equal f (section a) = retraction (f a)], so that you were
dealing with a coherent equivalence instead. Since your proof goal
only uses [retraction], it should be possible to "adjust" [section] so
that it satisfies this equation; I suspect that this is what most of
Gaëtan's proof is about. Once you have this additional lemma, your
goal is quite straight forward: supposing you have this lemma as [H],
you can solve your goal with [rewrite <- H; generalize (section a);
generalize (g (f a)); intros; subst; reflexivity.]
The underlying intuition that I had here is that the thing getting in
the way of the "naive proof" is that you can't just destruct an
equality [e] of type [f a0 = f a], because you can't generalize over
the two sides. But since f is an equivalence, HoTT tells us that we
can get that [e = ap f <something>] (i.e., [e = f_equal f
<something>], where <something> is going to be [ap g e] adjusted so
the endpoints line up. Once you get this, you can just destruct the
<something>, and you're golden.
(Note that if your goal also mentioned [section], then you'd almost
surely be sunk without having an extra hypothesis which related
[section] and [retraction].)
On Sat, Oct 10, 2020 at 4:00 AM Gaëtan Gilbert
<gaetan.gilbert AT skyskimmer.net> wrote:
> It's proved. HoTT is the only place I know to get lemmas about equality
> from so that's what I used, but this is axiom less so can be done without
> HoTT too.
> Thought process:
> - eq_rect is complicated, let's turn it into transport to simplify the goal
> this worked but is not actually useful in the end
> - maybe there's a fancy destruct which will work (simple proofs about
> equality are all about the well chosen destruct)
> this went nowhere fast
> - maybe I can construct a counterexample using univalence on boolean
> negation
> obviously this couldn't work
> - this looks like the incomplete IsEquiv from HoTT where we can construct
> some fancy equality proofs to get the full IsEquiv stuff
> let's look at the construction to see if I get any ideas
> a bit of messing about then leads to the solution
> Gaëtan Gilbert
> On 10/10/2020 08:11, Talia Ringer wrote:
> > Hello friends,
> > I got nerd sniped this morning on a proof task I've been at for like 11
> > hours. Most of the proof obligations are done now, but I ended up stuck
> > at one particular proof obligation that I'm not sure how to solve, or if
> > it is solvable in general. But also I need to work on job applications
> > and normal last year of grad school things, and I haven't eaten dinner.
> > So if you help me out with this one proof obligation, I'll give you
> > appropriate credit and also get you a beer or dessert.
> > For real. I don't have technical mentors or local expertise to consult.
> > Essentially, I have two types:
> > A : Type
> > B : Type
> > that are equivalent:
> > f : A -> B
> > g : B -> A
> > section : forall a, g (f a) = a.
> > retraction : forall b, f (g b) = b.
> > I know literally nothing else about my types or my equivalence. *I want
> > to know if it is possible to solve this proof obligation:*
> > *P : B -> Type
> > a : A
> > f0 : forall a : A, P (f a)
> > ______________________________________(1/1)
> > eq_rect (f (g (f a))) P (f0 (g (f a))) (f a) (retraction (f a)) = f0
> > a*
> > (I have already solved this proof obligation:
> > a : A
> > eq_rect (f (g (f a))) (fun _ : B => A) (g (f a)) (f a) (retraction (f
> > a)) = a
> > Literally just "rewrite retraction. apply section." works. But that
> > didn't help me, and I also couldn't get Coq to use the same tactics.)
> > I can't figure out whether this is me being really bad at equalities of
> > equalities and dependent rewrites, or whether there is something we must
> > know about A, B, or our equivalence for this to hold, or whether there is
> > an additional axiom we must assume for this to hold in general. And it's
> > 11:00 PM and I haven't eaten dinner, so time to ask you all:
> > * Is this provable? If so, how? (And why am I so bad at equalities of
> > equalities?)
> > * If it is not, can you explain why?
> > * Is there anything I could assume about A and B to make it provable?
> > * Is there anything I could assume about f, g, section, or retraction
> > Hopefully someone else finds this fun, too. Or really likes beer.
> > Talia
