coq-club - Re: [Coq-Club] Is this provable? (I'll give you credit and beer/dessert)
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Is this provable? (I'll give you credit and beer/dessert)
  • Date: Sat, 10 Oct 2020 13:21:26 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=llee454 AT gmail.com; spf=Pass smtp.mailfrom=llee454 AT gmail.com; spf=None smtp.helo=postmaster AT mail-il1-f194.google.com
  • Ironport-phdr: 9a23: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
Sorry for the cruft in the last snippet:
1 Require Import ProofIrrelevance.
1 Require Import FunctionalExtensionality.
2
3 Parameter A : Type.
4 Parameter B : Type.
5 Parameter f : A -> B.
6 Parameter g : B -> A.
7 Axiom section : forall a, g (f a) = a.
8 Axiom retraction : forall b, f (g b) = b.
9
10 Goal
11 forall (P : B -> Type) (a : A) (f0 : forall a : A, P (f a)),
12 eq_rect
13 (f (g (f a)))
14 P
15 (f0 (g (f a)))
16 (f a)
17 (retraction (f a)) =
18 f0 a.
19 Proof.
20 intros P a f0.
21 rewrite <- (f_equal_dep (fun a => P (f a)) f0 (section a)).
22 rewrite (proof_irrelevance (f (g (f a)) = (f a)) (retraction (f
a)) (f_equal f (section a))).
23 exact (eq_sym (rew_map P f (section a) (f0 (g (f a))))).
24 Qed.
On 10/10/20, Larry Lee <llee454 AT gmail.com> wrote:
> Hey Talia,
> Sorry to hear that you were "nerd sniped" over this. It's possible to
> prove the lemma you presented below:
> 2
> 9
> 10 Goal
> 12 eq_rect
> 13 (f (g (f a)))
> 14 P
> 15 (f0 (g (f a)))
> 16 (f a)
> 18 f0 a.
> 19 Proof.
> 20 intros P a f0.
> 23 set (b := f a).
> 24 set (a0 := g b).
> 25 set (b0 := f a0).
> 26 assert (a0 = a).
> 27 + exact (section a).
> 28 + assert (b0 = b).
> 29 - exact (retraction b).
> 30 - exact (eq_sym (rew_map P f (section a) (f0 a0))).
> 31 Qed.
> I don't drink, but a pizza would be nice.
> - Larry Lee
> (http://larrylee.tech)
> On 10/10/20, Talia Ringer <tringer AT cs.washington.edu> wrote:
>> Thanks all, love the thought processes too, and happy to ship some beer
>> or
>> dessert or get it next conference :)
>> On Sat, Oct 10, 2020, 7:53 AM Jason Gross <jasongross9 AT gmail.com> wrote:
>>> I have not yet looked at Gaëtan's proof, but here is the intuition:
>>> What you have is a sort of incoherent equivalence. What would make
>>> your proof easier is having some version of [section] such that
>>> [forall a, f_equal f (section a) = retraction (f a)], so that you were
>>> dealing with a coherent equivalence instead. Since your proof goal
>>> only uses [retraction], it should be possible to "adjust" [section] so
>>> that it satisfies this equation; I suspect that this is what most of
>>> Gaëtan's proof is about. Once you have this additional lemma, your
>>> goal is quite straight forward: supposing you have this lemma as [H],
>>> you can solve your goal with [rewrite <- H; generalize (section a);
>>> generalize (g (f a)); intros; subst; reflexivity.]
>>> The underlying intuition that I had here is that the thing getting in
>>> the way of the "naive proof" is that you can't just destruct an
>>> equality [e] of type [f a0 = f a], because you can't generalize over
>>> the two sides. But since f is an equivalence, HoTT tells us that we
>>> can get that [e = ap f <something>] (i.e., [e = f_equal f
>>> <something>], where <something> is going to be [ap g e] adjusted so
>>> the endpoints line up. Once you get this, you can just destruct the
>>> <something>, and you're golden.
>>> (Note that if your goal also mentioned [section], then you'd almost
>>> surely be sunk without having an extra hypothesis which related
>>> [section] and [retraction].)
>>> On Sat, Oct 10, 2020 at 4:00 AM Gaëtan Gilbert
>>> <gaetan.gilbert AT skyskimmer.net> wrote:
>>> > It's proved. HoTT is the only place I know to get lemmas about
>>> > equality
>>> from so that's what I used, but this is axiom less so can be done
>>> without
>>> HoTT too.
>>> > Thought process:
>>> > - eq_rect is complicated, let's turn it into transport to simplify the
>>> goal
>>> > this worked but is not actually useful in the end
>>> > - maybe there's a fancy destruct which will work (simple proofs about
>>> equality are all about the well chosen destruct)
>>> > this went nowhere fast
>>> > - maybe I can construct a counterexample using univalence on boolean
>>> negation
>>> > obviously this couldn't work
>>> > - this looks like the incomplete IsEquiv from HoTT where we can
>>> construct some fancy equality proofs to get the full IsEquiv stuff
>>> > let's look at the construction to see if I get any ideas
>>> > a bit of messing about then leads to the solution
>>> > Gaëtan Gilbert
>>> > On 10/10/2020 08:11, Talia Ringer wrote:
>>> > > Hello friends,
>>> > > I got nerd sniped this morning on a proof task I've been at for like
>>> 11 hours. Most of the proof obligations are done now, but I ended up
>>> stuck
>>> at one particular proof obligation that I'm not sure how to solve, or if
>>> it
>>> is solvable in general. But also I need to work on job applications and
>>> normal last year of grad school things, and I haven't eaten dinner. So
>>> if
>>> you help me out with this one proof obligation, I'll give you
>>> appropriate
>>> credit and also get you a beer or dessert.
>>> > > For real. I don't have technical mentors or local expertise to
>>> > > consult.
>>> > > Essentially, I have two types:
>>> > > A : Type
>>> > > B : Type
>>> > > that are equivalent:
>>> > > f : A -> B
>>> > > g : B -> A
>>> > > I know literally nothing else about my types or my equivalence. *I
>>> want to know if it is possible to solve this proof obligation:*
>>> > > *P : B -> Type
>>> > > a : A
>>> > > ______________________________________(1/1)
>>> > > eq_rect (f (g (f a))) P (f0 (g (f a))) (f a) (retraction (f a))
>>> f0 a*
>>> > > (I have already solved this proof obligation:
>>> > > a : A
>>> > > eq_rect (f (g (f a))) (fun _ : B => A) (g (f a)) (f a)
>>> > > (retraction
>>> (f a)) = a
>>> > > Literally just "rewrite retraction. apply section." works. But that
>>> didn't help me, and I also couldn't get Coq to use the same tactics.)
>>> > > I can't figure out whether this is me being really bad at equalities
>>> of equalities and dependent rewrites, or whether there is something we
>>> must
>>> know about A, B, or our equivalence for this to hold, or whether there
>>> is
>>> an additional axiom we must assume for this to hold in general. And it's
>>> 11:00 PM and I haven't eaten dinner, so time to ask you all:
>>> > > * Is this provable? If so, how? (And why am I so bad at equalities
>>> of equalities?)
>>> > > * If it is not, can you explain why?
>>> > > * Is there anything I could assume about A and B to make it
>>> > > provable?
>>> > > * Is there anything I could assume about f, g, section, or
>>> retraction to make it provable?
>>> > > Hopefully someone else finds this fun, too. Or really likes beer.
>>> > > Talia
