coq-club - Re: [Coq-Club] Is this provable? (I'll give you credit and beer/dessert)
  • From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Is this provable? (I'll give you credit and beer/dessert)
  • Date: Sat, 10 Oct 2020 23:10:26 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mailinglists AT robbertkrebbers.nl; spf=Pass smtp.mailfrom=mailinglists AT robbertkrebbers.nl; spf=None smtp.helo=postmaster AT se25-yh-out2.route25.eu
  • Ironport-phdr: 9a23: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
I don't think so. This has to do with the parametrization of Iris with higher-order user-defined resources.
I feel that this is getting off-topic, so if you want to know more, please ask me in private.
On 10/10/2020 22.55, Bas Spitters wrote:
Robbert, is that related to the issues with later-s and equality, as
we have addressed in guarded cubical type theory?
https://arxiv.org/abs/1611.09263
On Sat, Oct 10, 2020 at 10:38 PM Robbert Krebbers
<mailinglists AT robbertkrebbers.nl> wrote:
Test subject volunteers.
Also Iris got infected with homotopy type theory lately :) We're
transporting equalities over our resource algebras.
See https://gitlab.mpi-sws.org/iris/iris/-/merge_requests/530#note_57508
On 10/10/2020 19.36, Xavier Leroy wrote:
At any rate, Talia's message gave me an idea for a paper:
" Q.e.d. or starve? On the feeding habits of homotopy type theorists"
I still need a few more test subjects, though :-)
- Xavier
On Sat, Oct 10, 2020 at 7:24 PM Derek Dreyer <dreyer AT mpi-sws.org
<mailto:dreyer AT mpi-sws.org>> wrote:
FYI: I don't think Talia was complaining: nerd sniping is fun. I
sometimes nerd-snipe myself.
https://www.urbandictionary.com/define.php?term=Nerd%20Sniping
Derek
On Sat, Oct 10, 2020 at 7:19 PM Larry Lee <llee454 AT gmail.com
<mailto:llee454 AT gmail.com>> wrote:
> Hey Talia,
> Sorry to hear that you were "nerd sniped" over this. It's possible to
> prove the lemma you presented below:
> 1 Require Import ProofIrrelevance.
> 1 Require Import FunctionalExtensionality.
> 2
> 3 Parameter A : Type.
> 4 Parameter B : Type.
> 5 Parameter f : A -> B.
> 6 Parameter g : B -> A.
> 7 Axiom section : forall a, g (f a) = a.
> 8 Axiom retraction : forall b, f (g b) = b.
> 9
> 10 Goal
> 11 forall (P : B -> Type) (a : A) (f0 : forall a : A, P (f a)),
> 12 eq_rect
> 13 (f (g (f a)))
> 14 P
> 15 (f0 (g (f a)))
> 16 (f a)
> 17 (retraction (f a)) =
> 18 f0 a.
> 19 Proof.
> 20 intros P a f0.
> 21 rewrite <- (f_equal_dep (fun a => P (f a)) f0 (section a)).
> 22 rewrite (proof_irrelevance (f (g (f a)) = (f a)) (retraction (f
> a)) (f_equal f (section a))).
> 23 set (b := f a).
> 24 set (a0 := g b).
> 25 set (b0 := f a0).
> 26 assert (a0 = a).
> 27 + exact (section a).
> 28 + assert (b0 = b).
> 29 - exact (retraction b).
> 30 - exact (eq_sym (rew_map P f (section a) (f0 a0))).
> 31 Qed.
> I don't drink, but a pizza would be nice.
> - Larry Lee
> (http://larrylee.tech)
> On 10/10/20, Talia Ringer <tringer AT cs.washington.edu
<mailto:tringer AT cs.washington.edu>> wrote:
> > Thanks all, love the thought processes too, and happy to ship
some beer or
> > dessert or get it next conference :)
> > On Sat, Oct 10, 2020, 7:53 AM Jason Gross
<jasongross9 AT gmail.com <mailto:jasongross9 AT gmail.com>> wrote:
> >> I have not yet looked at Gaëtan's proof, but here is the
intuition:
> >> What you have is a sort of incoherent equivalence. What would
make
> >> your proof easier is having some version of [section] such that
> >> [forall a, f_equal f (section a) = retraction (f a)], so that
you were
> >> dealing with a coherent equivalence instead. Since your proof
goal
> >> only uses [retraction], it should be possible to "adjust"
[section] so
> >> that it satisfies this equation; I suspect that this is what
most of
> >> Gaëtan's proof is about. Once you have this additional lemma,
your
> >> goal is quite straight forward: supposing you have this lemma
as [H],
> >> you can solve your goal with [rewrite <- H; generalize
(section a);
> >> generalize (g (f a)); intros; subst; reflexivity.]
> >> The underlying intuition that I had here is that the thing
getting in
> >> the way of the "naive proof" is that you can't just destruct an
> >> equality [e] of type [f a0 = f a], because you can't
generalize over
> >> the two sides. But since f is an equivalence, HoTT tells us
that we
> >> can get that [e = ap f <something>] (i.e., [e = f_equal f
> >> <something>], where <something> is going to be [ap g e]
adjusted so
> >> the endpoints line up. Once you get this, you can just
destruct the
> >> <something>, and you're golden.
> >> (Note that if your goal also mentioned [section], then you'd
almost
> >> surely be sunk without having an extra hypothesis which related
> >> [section] and [retraction].)
> >> On Sat, Oct 10, 2020 at 4:00 AM Gaëtan Gilbert
> >> <gaetan.gilbert AT skyskimmer.net
<mailto:gaetan.gilbert AT skyskimmer.net>> wrote:
> >> > It's proved. HoTT is the only place I know to get lemmas
about equality
> >> from so that's what I used, but this is axiom less so can be
done without
> >> HoTT too.
> >> > Thought process:
> >> > - eq_rect is complicated, let's turn it into transport to
simplify the
> >> goal
> >> > this worked but is not actually useful in the end
> >> > - maybe there's a fancy destruct which will work (simple
proofs about
> >> equality are all about the well chosen destruct)
> >> > this went nowhere fast
> >> > - maybe I can construct a counterexample using univalence on
boolean
> >> negation
> >> > obviously this couldn't work
> >> > - this looks like the incomplete IsEquiv from HoTT where we can
> >> construct some fancy equality proofs to get the full IsEquiv stuff
> >> > let's look at the construction to see if I get any ideas
> >> > a bit of messing about then leads to the solution
> >> > Gaëtan Gilbert
> >> > On 10/10/2020 08:11, Talia Ringer wrote:
> >> > > Hello friends,
> >> > > I got nerd sniped this morning on a proof task I've been
at for like
> >> 11 hours. Most of the proof obligations are done now, but I
ended up
> >> stuck
> >> at one particular proof obligation that I'm not sure how to
solve, or if
> >> it
> >> is solvable in general. But also I need to work on job
applications and
> >> normal last year of grad school things, and I haven't eaten
dinner. So if
> >> you help me out with this one proof obligation, I'll give you
appropriate
> >> credit and also get you a beer or dessert.
> >> > > For real. I don't have technical mentors or local expertise to
> >> > > consult.
> >> > > Essentially, I have two types:
> >> > > A : Type
> >> > > B : Type
> >> > > that are equivalent:
> >> > > f : A -> B
> >> > > g : B -> A
> >> > > I know literally nothing else about my types or my
equivalence. *I
> >> want to know if it is possible to solve this proof obligation:*
> >> > > *P : B -> Type
> >> > > a : A
> >> > > ______________________________________(1/1)
> >> > > eq_rect (f (g (f a))) P (f0 (g (f a))) (f a)
> >> f0 a*
> >> > > (I have already solved this proof obligation:
> >> > > a : A
> >> > > eq_rect (f (g (f a))) (fun _ : B => A) (g (f a)) (f a)
> >> > > (retraction
> >> (f a)) = a
> >> > > Literally just "rewrite retraction. apply section." works.
But that
> >> didn't help me, and I also couldn't get Coq to use the same
tactics.)
> >> > > I can't figure out whether this is me being really bad at
equalities
> >> of equalities and dependent rewrites, or whether there is
something we
> >> must
> >> know about A, B, or our equivalence for this to hold, or
whether there is
> >> an additional axiom we must assume for this to hold in
general. And it's
> >> 11:00 PM and I haven't eaten dinner, so time to ask you all:
> >> > > * Is this provable? If so, how? (And why am I so bad at
equalities
> >> of equalities?)
> >> > > * If it is not, can you explain why?
> >> > > * Is there anything I could assume about A and B to make it
> >> > > provable?
> >> > > * Is there anything I could assume about f, g, section, or
> >> retraction to make it provable?
> >> > > Hopefully someone else finds this fun, too. Or really
likes beer.
> >> > > Talia
