- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Announcing Tactician 1.0 beta
- Date: Sun, 6 Dec 2020 23:25:20 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=lasse AT blaauwbroek.eu; spf=Pass smtp.mailfrom=lasse AT blaauwbroek.eu; spf=None smtp.helo=postmaster AT mail.blaauwbroek.eu
- Ironport-phdr: 9a23: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
This depends on wether or not one of your installed packages has a dependency on OCaml < 4.08. You can try this with
opam install coq-tactician --unlock-base
But keep in mind that this will upgrade your ocaml compiler, and
therefore all your other packages have to be recompiled.
The most likely culprits are (1) Your opam version is 1.x, in which case you should upgrade to 2.x (2) Your OCaml compiler is too old (you need at least 4.08). In this case, you can try to install Tactician in a new switch (which will create a new stack of OCaml software, orthogonal to anything you might have already installed):
opam switch create coq-tactician-switch --empty
eval $(opam env)
opam repo add coq-released https://coq.inria.fr/opam/released
If that does not work either, please post the output of 'opam config report' and 'opam install coq-tactician --debug'.
Regards,
Lasse
Thanks for the announcement. This seems like a very useful tool.
When I try to install, I get a very non-descript error message.
agnishom@agnishomDuncan:~$ opam install coq-tactician
Sorry, no solution found: there seems to be a problem with your request.
No solution found, exiting
I tried this after doing opam update and opam upgrade, but that didn't help.
On Sun, Dec 6, 2020 at 2:14 PM Lasse Blaauwbroek <lasse AT blaauwbroek.eu> wrote:We would like to announce Tactician 1.0 beta1, the first official
release of Tactician. See the website here
https://coq-tactician.github.io and an online demo here
https://coq-tactician.github.io/demo.html
Tactician is a tactic learner and prover for the Coq Proof Assistant.
The system will help users make tactical proof decisions while they
retain control over the general proof strategy. To this end, Tactician
will learn from previously written tactic scripts, and either gives the
user suggestions about the next tactic to be executed or altogether
takes over the burden of proof synthesis. Tactician’s goal is to provide
the user with a seamless, interactive, and intuitive experience together
with strong, adaptive proof automation.
Even though a lot still remains to be done, with this version we believe
that the system is mature enough to be used in real developments. We
would like to solicit any feedback on the system you might have.
Tactician is available for Coq v8.11, v8.12, v8.13 and master and on
Linux, macOS and Windows. Installation instructions can be found in the
manual (https://coq-tactician.github.io/manual). Tactician has
first-class support for Opam (Coq's package manager), and can
automatically learn from almost any Coq package. For the exceptions,
special support can be added. Currently, special support exists for the
HoTT homotopy type theory library. If tactician cannot instrument your
favorite package and you would like to see support, please open an issue.
-- Future direction --
This release of Tactician is aimed at providing Coq users with an easy
to use system that can be used in real Coq developments. The next step
in our grand plan is to transform Tactician into a machine learning
platform, where AI-researchers can add agents to Tactician (a plugin for
a plugin) using an easy-to-use API. The goal of this API is to take away
the hard Coq engineering problems and only leave the hard machine
learning problems.
This API is still under heavy development. We are therefore not yet
inviting the wider AI-community to work with Tactician. However, we are
looking for collaborators/beta-testers. So if you have a good machine
learning idea that you would like to implement on top of Tactician,
please get in touch.
Lasse Blaauwbroek
- [Coq-Club] Announcing Tactician 1.0 beta, Lasse Blaauwbroek, 12/06/2020
- Re: [Coq-Club] Announcing Tactician 1.0 beta, Agnishom Chattopadhyay, 12/06/2020
- Re: [Coq-Club] Announcing Tactician 1.0 beta, Laurent Thery, 12/06/2020
- Re: [Coq-Club] Announcing Tactician 1.0 beta, Lasse Blaauwbroek, 12/06/2020
- Re: [Coq-Club] Announcing Tactician 1.0 beta, Agnishom Chattopadhyay, 12/07/2020
- Re: [Coq-Club] Announcing Tactician 1.0 beta, Lasse Blaauwbroek, 12/07/2020
- Re: [Coq-Club] Announcing Tactician 1.0 beta, Théo Zimmermann, 12/07/2020
