- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Announcing Tactician 1.0 beta
- Date: Sun, 6 Dec 2020 23:29:20 +0100
Hi,
maybe you can save the state of the current switch on a file
with
opam switch export state_file
and then when you are in the new switch recreate the environment with :
opam switch import state_file
On 12/6/20 11:18 PM, Agnishom Chattopadhyay wrote:
> Thanks for your responses. I believe the problem here is that my OCaml
> compiler is 4.07.
> I suppose I could create a new opam switch but I already have
> coq-platform installed on this switch, and everything works. Is it not
> possible to upgrade my ocamlc to 4.08 in the existing switch?
> On Sun, Dec 6, 2020 at 3:47 PM Lasse Blaauwbroek <lasse AT blaauwbroek.eu
> <mailto:lasse AT blaauwbroek.eu>> wrote:
> The most likely culprits are (1) Your opam version is 1.x, in which
> case you should upgrade to 2.x (2) Your OCaml compiler is too old
> (you need at least 4.08). In this case, you can try to install
> Tactician in a new switch (which will create a new stack of OCaml
> software, orthogonal to anything you might have already installed):
> opam switch create coq-tactician-switch --empty
> eval $(opam env)
> opam repo add coq-released https://coq.inria.fr/opam/released
> <https://coq.inria.fr/opam/released>
> opam install coq-tactician
> If that does not work either, please post the output of 'opam config
> report' and 'opam install coq-tactician --debug'.
> Regards,
> Lasse
> On 12/6/20 10:27 PM, Agnishom Chattopadhyay wrote:
>> Thanks for the announcement. This seems like a very useful tool.
>> When I try to install, I get a very non-descript error message.
>> agnishom@agnishomDuncan:~$ opam install coq-tactician
>> Sorry, no solution found: there seems to be a problem with your
>> request.
>> No solution found, exiting
>> I tried this after doing opam update and opam upgrade, but that
>> didn't help.
>> On Sun, Dec 6, 2020 at 2:14 PM Lasse Blaauwbroek
>> <lasse AT blaauwbroek.eu <mailto:lasse AT blaauwbroek.eu>> wrote:
>> We would like to announce Tactician 1.0 beta1, the first official
>> release of Tactician. See the website here
>> https://coq-tactician.github.io
>> <https://coq-tactician.github.io> and an online demo here
>> https://coq-tactician.github.io/demo.html
>> <https://coq-tactician.github.io/demo.html>
>> Tactician is a tactic learner and prover for the Coq Proof
>> Assistant.
>> The system will help users make tactical proof decisions while
>> they
>> retain control over the general proof strategy. To this end,
>> Tactician
>> will learn from previously written tactic scripts, and either
>> gives the
>> user suggestions about the next tactic to be executed or
>> altogether
>> takes over the burden of proof synthesis. Tactician’s goal is
>> to provide
>> the user with a seamless, interactive, and intuitive
>> experience together
>> with strong, adaptive proof automation.
>> Even though a lot still remains to be done, with this version
>> we believe
>> that the system is mature enough to be used in real
>> developments. We
>> would like to solicit any feedback on the system you might have.
>> Tactician is available for Coq v8.11, v8.12, v8.13 and master
>> and on
>> Linux, macOS and Windows. Installation instructions can be
>> found in the
>> manual (https://coq-tactician.github.io/manual
>> <https://coq-tactician.github.io/manual>). Tactician has
>> first-class support for Opam (Coq's package manager), and can
>> automatically learn from almost any Coq package. For the
>> exceptions,
>> special support can be added. Currently, special support
>> exists for the
>> HoTT homotopy type theory library. If tactician cannot
>> instrument your
>> favorite package and you would like to see support, please
>> open an issue.
>> -- Future direction --
>> This release of Tactician is aimed at providing Coq users with
>> an easy
>> to use system that can be used in real Coq developments. The
>> next step
>> in our grand plan is to transform Tactician into a machine
>> learning
>> platform, where AI-researchers can add agents to Tactician (a
>> plugin for
>> a plugin) using an easy-to-use API. The goal of this API is to
>> take away
>> the hard Coq engineering problems and only leave the hard machine
>> learning problems.
>> This API is still under heavy development. We are therefore
>> not yet
>> inviting the wider AI-community to work with Tactician.
>> However, we are
>> looking for collaborators/beta-testers. So if you have a good
>> machine
>> learning idea that you would like to implement on top of
>> Tactician,
>> please get in touch.
>> Lasse Blaauwbroek
- [Coq-Club] Announcing Tactician 1.0 beta, Lasse Blaauwbroek, 12/06/2020
- Re: [Coq-Club] Announcing Tactician 1.0 beta, Agnishom Chattopadhyay, 12/06/2020
- Re: [Coq-Club] Announcing Tactician 1.0 beta, Laurent Thery, 12/06/2020
- Re: [Coq-Club] Announcing Tactician 1.0 beta, Lasse Blaauwbroek, 12/06/2020
- Re: [Coq-Club] Announcing Tactician 1.0 beta, Agnishom Chattopadhyay, 12/07/2020
- Re: [Coq-Club] Announcing Tactician 1.0 beta, Lasse Blaauwbroek, 12/07/2020
- Re: [Coq-Club] Announcing Tactician 1.0 beta, Théo Zimmermann, 12/07/2020
