coq-club - Re: [Coq-Club] Announcing Tactician 1.0 beta
  • From: Agnishom Chattopadhyay <agnishom AT cmi.ac.in>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Announcing Tactician 1.0 beta
  • Date: Mon, 7 Dec 2020 08:17:47 -0600
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=agnishom AT cmi.ac.in; spf=Pass smtp.mailfrom=agnishom AT cmi.ac.in; spf=None smtp.helo=postmaster AT mail.cmi.ac.in
  • Ironport-phdr: 9a23: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
Thanks again, everyone. When I tried --unlock-base, it finally worked.
By the way, what is the `only` tactical that Tactician seems to be suggesting? Is this something that can be used without the presence of the Tactician?
On Sun, Dec 6, 2020 at 4:29 PM Laurent Thery <Laurent.Thery AT inria.fr> wrote:
Hi,
maybe you can save the state of the current switch on a file
with
 opam switch export state_file
and then when you are in the new switch recreate the environment with :
 opam switch import state_file
On 12/6/20 11:18 PM, Agnishom Chattopadhyay wrote:
> Thanks for your responses. I believe the problem here is that my OCaml
> compiler is 4.07.
> I suppose I could create a new opam switch but I already have
> coq-platform installed on this switch, and everything works. Is it not
> possible to upgrade my ocamlc to 4.08 in the existing switch?
> On Sun, Dec 6, 2020 at 3:47 PM Lasse Blaauwbroek <lasse AT blaauwbroek.eu
> <mailto:lasse AT blaauwbroek.eu>> wrote:
>     The most likely culprits are (1) Your opam version is 1.x, in which
>     case you should upgrade to 2.x (2) Your OCaml compiler is too old
>     (you need at least 4.08). In this case, you can try to install
>     Tactician in a new switch (which will create a new stack of OCaml
>     software, orthogonal to anything you might have already installed):
>     opam switch create coq-tactician-switch --empty
>     eval $(opam env)
>     opam repo add coq-released https://coq.inria.fr/opam/released
>     <https://coq.inria.fr/opam/released>
>     opam install coq-tactician
>     If that does not work either, please post the output of 'opam config
>     report' and 'opam install coq-tactician --debug'.
>     Regards,
>     Lasse
>     On 12/6/20 10:27 PM, Agnishom Chattopadhyay wrote:
>>     Thanks for the announcement. This seems like a very useful tool.
>>     When I try to install, I get a very non-descript error message.
>>     agnishom@agnishomDuncan:~$ opam install coq-tactician
>>     Sorry, no solution found: there seems to be a problem with your
>>     request.
>>     No solution found, exiting
>>     I tried this after doing opam update and opam upgrade, but that
>>     didn't help.
>>     On Sun, Dec 6, 2020 at 2:14 PM Lasse Blaauwbroek
>>     <lasse AT blaauwbroek.eu <mailto:lasse AT blaauwbroek.eu>> wrote:
>>         We would like to announce Tactician 1.0 beta1, the first official
>>         release of Tactician. See the website here
>>         https://coq-tactician.github.io
>>         <https://coq-tactician.github.io> and an online demo here
>>         https://coq-tactician.github.io/demo.html
>>         <https://coq-tactician.github.io/demo.html>
>>         Tactician is a tactic learner and prover for the Coq Proof
>>         Assistant.
>>         The system will help users make tactical proof decisions while
>>         they
>>         retain control over the general proof strategy. To this end,
>>         Tactician
>>         will learn from previously written tactic scripts, and either
>>         gives the
>>         user suggestions about the next tactic to be executed or
>>         altogether
>>         takes over the burden of proof synthesis. Tactician’s goal is
>>         to provide
>>         the user with a seamless, interactive, and intuitive
>>         experience together
>>         with strong, adaptive proof automation.
>>         Even though a lot still remains to be done, with this version
>>         we believe
>>         that the system is mature enough to be used in real
>>         developments. We
>>         would like to solicit any feedback on the system you might have.
>>         Tactician is available for Coq v8.11, v8.12, v8.13 and master
>>         and on
>>         Linux, macOS and Windows. Installation instructions can be
>>         found in the
>>         manual (https://coq-tactician.github.io/manual
>>         <https://coq-tactician.github.io/manual>). Tactician has
>>         first-class support for Opam (Coq's package manager), and can
>>         automatically learn from almost any Coq package. For the
>>         exceptions,
>>         special support can be added. Currently, special support
>>         exists for the
>>         HoTT homotopy type theory library. If tactician cannot
>>         instrument your
>>         favorite package and you would like to see support, please
>>         open an issue.
>>         -- Future direction --
>>         This release of Tactician is aimed at providing Coq users with
>>         an easy
>>         to use system that can be used in real Coq developments. The
>>         next step
>>         in our grand plan is to transform Tactician into a machine
>>         learning
>>         platform, where AI-researchers can add agents to Tactician (a
>>         plugin for
>>         a plugin) using an easy-to-use API. The goal of this API is to
>>         take away
>>         the hard Coq engineering problems and only leave the hard machine
>>         learning problems.
>>         This API is still under heavy development. We are therefore
>>         not yet
>>         inviting the wider AI-community to work with Tactician.
>>         However, we are
>>         looking for collaborators/beta-testers. So if you have a good
>>         machine
>>         learning idea that you would like to implement on top of
>>         Tactician,
>>         please get in touch.
>>         Lasse Blaauwbroek
