- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] termination when branching with fmaps
- Date: Thu, 18 Feb 2021 14:25:10 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=lysxia AT gmail.com; spf=Pass smtp.mailfrom=lysxia AT gmail.com; spf=None smtp.helo=postmaster AT mail-vs1-f49.google.com
- Ironport-phdr: 9a23:wzX9cBG+B7BuYKsXjen/4p1GYnF86YWxBRYc798ds5kLTJ7zp8ywAkXT6L1XgUPTWs2DsrQY0ruQ7PyrBjdIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TW94jEIBxrwKxd+KPjrFY7OlcS30P2594HObwlSizexfLd/IA+0oAjeucUbg4VvIbstxxXUpXdFZ/5Yzn5yK1KJmBb86Maw/Jp9/ClVpvks6c1OX7jkcqohVbBXAygoPG4z5M3wqBnMVhCP6WcGUmUXiRVHHQ7I5wznU5jrsyv6su192DSGPcDzULs5Vyiu47ttRRT1jioMKjw3/3zNisFokaxVvhyhqRx8zYDabo6aO/hxcb/Sc94BWWpMXdxcWzBdDo6ybYYCCfcKM+ZCr4n6olsDtR2wBQi1COLv0DBIgWL90qw70+s7DArL2wggHtIVsHXbrdX6LrwfUe+wzKbSzDXDa+la1iv66IjNax0sp+yHUr1sf8TL00YvCx/FgUuKqYzjJz6b2fgAvmiZ4ud8Se6hi24pph9xrDWrxMoiipTFipwbx13K+ih0wIk7KMOkRUN0btOoDJ9duSGYOoZ2TM0vXX1ktSAnwbMFoZ62ZDYGxIgjyhLFaPGKc5KE7gz+WOuTOzt1i3ZodKqiixu98EWs0PDwWtS63VpQsyZJjN3BumoQ2xDN9MSKTOZ28F271jaVzQ/T7/lJIUAqmqrfLJ4s2rswmYASsUTHByP2hl72gLKPekUq9eWl7/7rYrrhpp+bOI90jh/xPr4ylcy4BOQ0KgkOX26F9uSgzLDv41H1TbFQgvA1kqTVqo7WKdkZq6KjDAJY1p4v6xOlADen1NQYk2MHLFVAeB+fi4joO0rOIf/5DfilmFmsnzJryOrHPr3lGJnCMn/DkLL5cbZn90Fc0BYzzcxY559MFr4BJ+vzVlbtu9zcEx82KBe5w/3nCdV4zoMRQ3iDAq6fMKPIsF+H/PgjI+eWZNxdhDGoIP88ovXqkHURmFkHfKDv04FERmq/G6FCIgCIaH2kstYIWTMOrxEuTeXCh1iLUDoVbHG3CfFvrgonAZ6rWN+QDrumh6aMiX/iT89mI1teA1XJKk/GMoCNWvMCciWXe5YznTkNVLznQIgkh0j36V3KjoF/J++RwRU28JLu0N8vur/WnBA2sCJvVoGTjzDLQGZzkWcFATQx2fIn+BAv+hK4yaF9xsdgO5lL/foQC1U1MJfdy6pxDNWgAg8=
Hi Lorenzo,
For fixpoints on nested inductive types, you must make sure to apply your function to a subterm. In your case, that means `depth` must end up applied to `br x` for any `x`.
> Fixpoint depth (T : fmap_tree) : nat :=
> match T with
> | fmap_leaf n => 0
> | fmap_node n br => (maxn_f_codom id (fun x => depth (br x))).+1
> end.
Now it is clear that the only location where `depth` is called recursively is in fact good. The exact rules are a little looser than that, but then you have to be aware of those rules and of the precise definition of every function that separates `depth` from `br`; it's not sufficient to understand what those functions do extensionally.
Cheers,
Li-yao
On 2/18/2021 1:32 PM, Lorenzo Gheri wrote:
Hi All,
I have defined the following datatype:
From mathcomp.ssreflect Require Import all_ssreflect.
From mathcomp Require Import finmap.
Open Scope fset.
Open Scope fmap.
Inductive fmap_tree :=
| fmap_leaf (n : nat)
| fmap_node (n : nat) (branching : {fmap nat -> fmap_tree}).
I would really like to keep this definition, namely to use finite maps (fmap from the math-comp libraries) instead of lists. I however run into problems when defining depth:
Definition maxn_f_codom {A:Type} (f: A -> nat) (br: {fmap nat -> A}):=
foldr maxn 0 (map (fun x=> match (br.[?x]) with
| None => 0
| Some T' => f T'
end)
(enum_fset (domf br)) ).
match T with
| fmap_leaf n => 0
| fmap_node n br => (maxn_f_codom depth br).+1
end.
In particular the definition of maxn_f_codom above---which could as well be inlined in the depth definition---is accepted by Coq with no issues, but the Fixpoint for depth is ill-formed. I thought I could easily use enum_fset for turning the finite domain of the fmap into a list and then termination would have been guaranteed. I was being too naif! :)
Before I give up altogether and go back to branching with lists, is there any way for me to convince Coq that fmaps are OK as well?
Many thanks,
Lorenzo
- [Coq-Club] termination when branching with fmaps, Lorenzo Gheri, 02/18/2021
- Re: [Coq-Club] termination when branching with fmaps, Li-yao Xia, 02/18/2021
- Re: [Coq-Club] termination when branching with fmaps, Lorenzo Gheri, 02/19/2021
- Re: [Coq-Club] termination when branching with fmaps, Matthieu Sozeau, 02/19/2021
- Re: [Coq-Club] termination when branching with fmaps, Laurent Thery, 02/19/2021
- Re: [Coq-Club] termination when branching with fmaps, Lorenzo Gheri, 02/20/2021
- Re: [Coq-Club] termination when branching with fmaps, Marcel Ullrich, 02/19/2021
