- From: Matthieu Sozeau <matthieu.sozeau AT inria.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] termination when branching with fmaps
- Date: Fri, 19 Feb 2021 17:17:20 +0100
Hi Lorenzo,
You can define such a function using:
Fixpoint fmap_tree_size (f : fmap_tree) : nat :=
match f with
| fmap_leaf n => 0
| fmap_node n br => foldr maxn 0 (codom (fmap_tree_size \o br)) + 1
end.
Finite maps are based on finite functions which allow such nested definitions,
You can find an example in the doc:
https://math-comp.github.io/htmldoc/mathcomp.ssreflect.finfun.html#finfun_of_tuple
— Matthieu
> On 19 Feb 2021, at 14:58, Lorenzo Gheri <lor.gheri AT gmail.com> wrote:
> Hi Li-yao and All,
> thank you very much for your answer. That was helpful indeed. However, the
> main issue there stays:
> Since `br` is not a partial function, but a fmap, I cannot really do `fun x
> => depth (br x)`, but I must do `fun x => depth (br.[? x])`, namely what
> happens is not a simple function application.
> Around fmaps nice results have been developed and that's why I was eager to
> use this type for finite branching. Has anyone tried something similar, and
> would be happy to share their experience?
> Best,
> Lorenzo
> On Thu, 18 Feb 2021 at 19:25, Li-yao Xia <lysxia AT gmail.com> wrote:
> Hi Lorenzo,
> For fixpoints on nested inductive types, you must make sure to apply
> your function to a subterm. In your case, that means `depth` must end up
> applied to `br x` for any `x`.
> > Fixpoint depth (T : fmap_tree) : nat :=
> > match T with
> > | fmap_leaf n => 0
> > | fmap_node n br => (maxn_f_codom id (fun x => depth (br x))).+1
> > end.
> Now it is clear that the only location where `depth` is called
> recursively is in fact good. The exact rules are a little looser than
> that, but then you have to be aware of those rules and of the precise
> definition of every function that separates `depth` from `br`; it's not
> sufficient to understand what those functions do extensionally.
> Cheers,
> Li-yao
> On 2/18/2021 1:32 PM, Lorenzo Gheri wrote:
> > Hi All,
> > I have defined the following datatype:
> > From mathcomp.ssreflect Require Import all_ssreflect.
> > From mathcomp Require Import finmap.
> > Open Scope fset.
> > Open Scope fmap.
> > Inductive fmap_tree :=
> > | fmap_leaf (n : nat)
> > | fmap_node (n : nat) (branching : {fmap nat -> fmap_tree}).
> > I would really like to keep this definition, namely to use finite maps
> > (fmap from the math-comp libraries) instead of lists. I however run into
> > problems when defining depth:
> > Definition maxn_f_codom {A:Type} (f: A -> nat) (br: {fmap nat -> A}):=
> > foldr maxn 0 (map (fun x=> match (br.[?x]) with
> > | None => 0
> > | Some T' => f T'
> > end)
> > (enum_fset (domf br)) ).
> > match T with
> > | fmap_leaf n => 0
> > | fmap_node n br => (maxn_f_codom depth br).+1
> > end.
> > In particular the definition of maxn_f_codom above---which could as well
> > be inlined in the depth definition---is accepted by Coq with no issues,
> > but the Fixpoint for depth is ill-formed. I thought I could easily use
> > enum_fset for turning the finite domain of the fmap into a list and then
> > termination would have been guaranteed. I was being too naif! :)
> > Before I give up altogether and go back to branching with lists, is
> > there any way for me to convince Coq that fmaps are OK as well?
> > Many thanks,
> > Lorenzo
- [Coq-Club] termination when branching with fmaps, Lorenzo Gheri, 02/18/2021
- Re: [Coq-Club] termination when branching with fmaps, Li-yao Xia, 02/18/2021
- Re: [Coq-Club] termination when branching with fmaps, Lorenzo Gheri, 02/19/2021
- Re: [Coq-Club] termination when branching with fmaps, Matthieu Sozeau, 02/19/2021
- Re: [Coq-Club] termination when branching with fmaps, Laurent Thery, 02/19/2021
- Re: [Coq-Club] termination when branching with fmaps, Lorenzo Gheri, 02/20/2021
- Re: [Coq-Club] termination when branching with fmaps, Marcel Ullrich, 02/19/2021
